[petsc-users] HPCToolKit/HPCViewer on OS X
Bhalla, Amneet Pal S amneetb at live.unc.edu
Thu Jan 14 18:36:14 CST 2016
And the PETSc log summary for comparison
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./main2d on a linux-opt named aorta with 1 processor, by amneetb Thu Jan 14 19:34:38 2016
Using Petsc Development GIT revision: v3.6.3-3098-ga3ecda2  GIT Date: 2016-01-13 21:30:26 -0600
                         Max       Max/Min        Avg      Total
Time (sec):           6.223e-01      1.00000   6.223e-01
Objects:              2.618e+03      1.00000   2.618e+03
Flops:                1.948e+08      1.00000   1.948e+08  1.948e+08
Flops/sec:            3.129e+08      1.00000   3.129e+08  3.129e+08
MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Reductions:       0.000e+00      0.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 6.2232e-01 100.0%  1.9476e+08 100.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
VecDot                 4 1.0 2.9087e-05 1.0 3.31e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1139
VecDotNorm2          180 1.0 1.0626e-03 1.0 3.17e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0  2983
VecMDot              288 1.0 3.8970e-03 1.0 2.38e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0   611
VecNorm              113 1.0 9.6560e-04 1.0 1.36e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   140
VecScale              66 1.0 4.0913e-04 1.0 1.21e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   295
VecCopy               24 1.0 3.8338e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet             12855 1.0 1.0173e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
VecAXPY              607 1.0 2.9583e-03 1.0 4.97e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   0  3  0  0  0  1680
VecAYPX              169 1.0 8.6975e-04 1.0 6.41e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   737
VecAXPBYCZ            34 1.0 1.1325e-04 1.0 2.77e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2443
VecWAXPY              54 1.0 1.4043e-04 1.0 2.30e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1637
VecMAXPY             301 1.0 5.6567e-03 1.0 2.38e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0   421
VecSwap              103 1.0 3.2711e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyBegin     561 1.0 3.5629e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecAssemblyEnd       561 1.0 6.4468e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin    18427 1.0 1.5277e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
BuildTwoSidedF       554 1.0 1.9150e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMult              361 1.0 6.2765e-02 1.0 5.80e+07 1.0 0.0e+00 0.0e+00 0.0e+00 10 30  0  0  0  10 30  0  0  0   924
MatSolve            6108 1.0 6.3529e-02 1.0 9.53e+07 1.0 0.0e+00 0.0e+00 0.0e+00 10 49  0  0  0  10 49  0  0  0  1500
MatLUFactorSym        85 1.0 2.0353e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
MatLUFactorNum        85 1.0 2.2882e-02 1.0 2.28e+07 1.0 0.0e+00 0.0e+00 0.0e+00  4 12  0  0  0   4 12  0  0  0   995
MatScale               4 1.0 2.2912e-04 1.0 2.51e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1096
MatAssemblyBegin     108 1.0 6.7949e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd       108 1.0 2.9209e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRow          33120 1.0 2.0407e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
MatGetRowIJ           85 1.0 1.2467e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice       4 1.0 8.2304e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatGetOrdering        85 1.0 7.8776e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatAXPY                4 1.0 4.9517e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  8  0  0  0  0   8  0  0  0  0     0
MatPtAP                4 1.0 4.4372e-02 1.0 4.99e+06 1.0 0.0e+00 0.0e+00 0.0e+00  7  3  0  0  0   7  3  0  0  0   112
MatPtAPSymbolic        4 1.0 2.7586e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   4  0  0  0  0     0
MatPtAPNumeric         4 1.0 1.6756e-02 1.0 4.99e+06 1.0 0.0e+00 0.0e+00 0.0e+00  3  3  0  0  0   3  3  0  0  0   298
MatGetSymTrans         4 1.0 3.6120e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPGMRESOrthog        12 1.0 4.9458e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
KSPSetUp              90 1.0 5.6815e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 3.8819e-01 1.0 1.89e+08 1.0 0.0e+00 0.0e+00 0.0e+00 62 97  0  0  0  62 97  0  0  0   488
PCSetUp               90 1.0 6.4402e-02 1.0 2.28e+07 1.0 0.0e+00 0.0e+00 0.0e+00 10 12  0  0  0  10 12  0  0  0   354
PCSetUpOnBlocks       84 1.0 5.2499e-02 1.0 2.28e+07 1.0 0.0e+00 0.0e+00 0.0e+00  8 12  0  0  0   8 12  0  0  0   434
PCApply               12 1.0 3.4369e-01 1.0 1.89e+08 1.0 0.0e+00 0.0e+00 0.0e+00 55 97  0  0  0  55 97  0  0  0   549
SNESSolve              1 1.0 3.9208e-01 1.0 1.89e+08 1.0 0.0e+00 0.0e+00 0.0e+00 63 97  0  0  0  63 97  0  0  0   483
SNESFunctionEval       2 1.0 3.2527e-03 1.0 4.68e+04 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0    14
SNESJacobianEval       1 1.0 4.6706e-04 1.0 4.26e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     9
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Vector   739            639      9087400     0.
      Vector Scatter   290            289       189584     0.
           Index Set  1086            738       885136     0.
   IS L to G Mapping   110            109      2156656     0.
   Application Order     6              6        99952     0.
             MatMFFD     1              1          776     0.
              Matrix   189            189     19106368     0.
   Matrix Null Space     4              4         2432     0.
       Krylov Solver    90             90       122720     0.
     DMKSP interface     1              1          648     0.
      Preconditioner    90             90        89864     0.
                SNES     1              1         1328     0.
      SNESLineSearch     1              1          984     0.
              DMSNES     1              1          664     0.
    Distributed Mesh     2              2         9168     0.
Star Forest Bipartite Graph     4              4         3168     0.
     Discrete System     2              2         1712     0.
              Viewer     1              0            0     0.
Average time to get PetscTime(): 7.15256e-07
#PETSc Option Table entries:
-ib_ksp_converged_reason
-ib_ksp_monitor_true_residual
-ib_snes_type ksponly
-log_summary
-stokes_ib_pc_level_ksp_richardson_self_scale
-stokes_ib_pc_level_ksp_type richardson
-stokes_ib_pc_level_pc_asm_local_type additive
-stokes_ib_pc_level_pc_asm_type interpolate
-stokes_ib_pc_level_sub_pc_factor_shift_type nonzero
-stokes_ib_pc_level_sub_pc_type lu
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --CC=mpicc --CXX=mpicxx --FC=mpif90 --with-default-arch=0 --PETSC_ARCH=linux-opt --with-debugging=0 --with-c++-support=1 --with-hypre=1 --download-hypre=1 --with-hdf5=yes --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3
Libraries compiled on Thu Jan 14 01:29:56 2016 on aorta
Machine characteristics: Linux-3.13.0-63-generic-x86_64-with-Ubuntu-14.04-trusty
Using PETSc directory: /not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc
Using PETSc arch: linux-opt
Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -Qunused-arguments -O3  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: mpif90  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -O3   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/linux-opt/include -I/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/include -I/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/include -I/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/linux-opt/include -I/not_backed_up/softwares/MPICH/include
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries: -Wl,-rpath,/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/linux-opt/lib -L/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/linux-opt/lib -lpetsc -Wl,-rpath,/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/linux-opt/lib -L/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/linux-opt/lib -lHYPRE -Wl,-rpath,/not_backed_up/softwares/MPICH/lib -L/not_backed_up/softwares/MPICH/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.8 -L/usr/lib/gcc/x86_64-linux-gnu/4.8 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lmpicxx -lstdc++ -llapack -lblas -lpthread -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -lX11 -lm -lmpifort -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpicxx -lstdc++ -Wl,-rpath,/not_backed_up/softwares/MPICH/lib -L/not_backed_up/softwares/MPICH/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.8 -L/usr/lib/gcc/x86_64-linux-gnu/4.8 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -Wl,-rpath,/not_backed_up/softwares/MPICH/lib -lmpi -lgcc_s -ldl
On Jan 14, 2016, at 4:31 PM, Bhalla, Amneet Pal Singh <amneetb at ad.unc.edu<mailto:amneetb at ad.unc.edu>> wrote:
On Jan 14, 2016, at 11:24 AM, Barry Smith <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>> wrote:
Also getting the results with Instruments or HPCToolkit would be useful (so long as we don't need to install HPCTool ourselves to see the results).
@Barry — Attached is the
<main2dProfiling.numbers>
output from HPCToolkit profiler for all the operations done in solving 1 timestep Stokes+IB simulation.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160115/48a75119/attachment-0001.html>
