[petsc-users] Array of SNES's
Timothée Nicolas timothee.nicolas at gmail.com
Tue Jan 5 22:28:50 CST 2016
(Sorry I forgot to answer all in the first message)
Well I have never used Petsc in python, but in FORTRAN, it seems to work
like any array. So why not use a python list for instance ? You would start
with SNESs = [], create a new snes and append it to the list with
SNESs.append(snes). Then you can use your list. That would not do it ?
Timothee
2016-01-06 13:24 GMT+09:00 Justin Chang <jychang48 at gmail.com>:
> Timothee,
> No i haven't tried, mainly because I don't know how. Btw I am not doing
> this in C or FORTRAN, I want to do this in python (via petsc4py) since I am
> trying to make this compatible with Firedrake (which is also python-based).
> Thanks,
> Justin
> On Tue, Jan 5, 2016 at 8:57 PM, Timothée Nicolas <
> timothee.nicolas at gmail.com> wrote:
>> Hello and happy new year,
>> Have you actually tried ? I just declared an array of 10 snes and created
>> them, and there is no complaint whatsoever. Also, something I do usually is
>> that I declare a derived type which contains some Petsc Objects (like SNES,
>> KSP, matrices, vectors, whatever), and create arrays of this derived types.
>> This works perfectly fine in my case (I use FORTRAN btw).
>> Best wishes
>> Timothee
>> 2016-01-06 11:53 GMT+09:00 Justin Chang <jychang48 at gmail.com>:
>>> Hi all,
>>> Is it possible to create an array of SNES's? If I have a problem size N
>>> degrees of freedom, I want each dof to have its own SNES solver (basically
>>> a pointer to N SNES's). Reason for this is because I am performing a
>>> "post-processing" step where after my global solve, each entry of my
>>> solution vector of size N will go through some algebraic manipulation.
>>> If I did a standard LU solve for these individual SNES's, I could use
>>> the same snes and this issue would be moot. But i am using the Variational
>>> Inequality, which basically requires a fresh SNES for each problem.
>>> Thanks,
>>> Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160106/502d641b/attachment-0001.html>
