[petsc-users] Segmentation error when calling PetscBarrier
Mon Jan 4 22:16:19 CST 2016
  You could try instead -on_error_attach_debugger and see if that is better at catching the code when the error occurs
   If the code runs valgrind clean (when it runs) then I would say it is reasonable for you to conclude that the current trouble is due to a Intel optimization error and not debug further,
  Barry
> On Jan 4, 2016, at 9:34 PM, TAY wee-beng <zonexo at gmail.com> wrote:
> Hi,
> Ya sorry, that should be the tool to use. Was having some problems using MPI with the debugger.
> I managed to run it as a serial code now.
> My problem is that on the cluster, it works with the gnu fortran. But using Intel compiler, I get segmentation error at some point when running the opt ver. The debug ver works fine.
> I am trying to find if the error is due to a bug in Intel, or it's my own problem.
> Another thing is that on another cluster, the Intel opt ver works, but that's using a newer ver of the compiler.
> I hope to get the Intel one working if possible, because it's about 30% faster.
> So now coming back to the gdb, it worked fine using the debug ver of the code. But when using the opt ver, it only shows segmentation fault. When the X-window appears, the code has already exited. I am already using -g during compile.
> So how should I debug it? The error seems to be when I tried to call DMDAVecRestoreArrayF90, although I still need to be more certain.
> Thank you
> Yours sincerely,
> TAY wee-beng
> On 5/1/2016 10:32 AM, Barry Smith wrote:
>>   You are missing the ,ierr which BTW you would have caught immediately if you used the debugger.
>>   Barry
>>   The debugger is not a scary monster, it is one of your best friends.
>>> On Jan 4, 2016, at 7:28 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>> Hi,
>>> I am trying to debug my CFD Fortran MPI code. I tried to add:
>>> call PetscBarrier(PETSC_NULL_OBJECT); if (myid==0) print *, "xx"
>>> to do a rough check on where the error is. xx is a different number for each line.
>>> I found that whenever I add this line, the code aborts with segmentation error.
>>> I am using the Intel compiler. Is there any error with my usage?
>>> Thank you
>>> Yours sincerely,
>>> TAY wee-beng
