[petsc-users] Segmentation error when calling PetscBarrier
Mon Jan 4 19:51:47 CST 2016
On Mon, Jan 4, 2016 at 7:41 PM, TAY wee-beng <zonexo at gmail.com> wrote:
> Hi Matt,
> In that case, what would be a good or accurate way to debug the MPI code?
> I'm trying to determine where the fault lies.
Is there a problem with -start_in_debugger? Also valgrind
--trace-children=yes is great.
    Matt
> Thank you
> Yours sincerely,
> TAY wee-beng
> On 5/1/2016 9:31 AM, Matthew Knepley wrote:
> On Mon, Jan 4, 2016 at 7:28 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>> Hi,
>> I am trying to debug my CFD Fortran MPI code. I tried to add:
>> call PetscBarrier(PETSC_NULL_OBJECT); if (myid==0) print *, "xx"
>> to do a rough check on where the error is. xx is a different number for
>> each line.
>> I found that whenever I add this line, the code aborts with segmentation
>> error.
>> I am using the Intel compiler. Is there any error with my usage?
> I don't think this makes sense since it will try to pull a communicator
> out of the NULL_OBJECT.
>    Matt
>> Thank you
>> Yours sincerely,
>> TAY wee-beng
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160104/898ec9f4/attachment.html>
