[petsc-users] Segmentation error when calling PetscBarrier
TAY wee-beng zonexo at gmail.com
Mon Jan 4 19:41:28 CST 2016
Hi Matt,
In that case, what would be a good or accurate way to debug the MPI
code? I'm trying to determine where the fault lies.
Thank you
Yours sincerely,
TAY wee-beng
On 5/1/2016 9:31 AM, Matthew Knepley wrote:
> On Mon, Jan 4, 2016 at 7:28 PM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     Hi,
>     I am trying to debug my CFD Fortran MPI code. I tried to add:
>     call PetscBarrier(PETSC_NULL_OBJECT); if (myid==0) print *, "xx"
>     to do a rough check on where the error is. xx is a different
>     number for each line.
>     I found that whenever I add this line, the code aborts with
>     segmentation error.
>     I am using the Intel compiler. Is there any error with my usage?
> I don't think this makes sense since it will try to pull a
> communicator out of the NULL_OBJECT.
>    Matt
>     Thank you
>     Yours sincerely,
>     TAY wee-beng
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160105/021a8eb2/attachment.html>
