[petsc-users] Error - Out of memory. This could be due to allocating too large an object or bleeding by not properly ...
Wed Feb 24 07:12:45 CST 2016
On Wed, Feb 24, 2016 at 1:54 AM, TAY wee-beng <zonexo at gmail.com> wrote:
> On 24/2/2016 10:28 AM, Matthew Knepley wrote:
> On Tue, Feb 23, 2016 at 7:50 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>> Hi,
>> I got this error (also attached, full) when running my code. It happens
>> after a few thousand time steps.
>> The strange thing is that for 2 different clusters, it stops at 2
>> different time steps.
>> I wonder if it's related to DM since this happens after I added DM into
>> my code.
>> In this case, how can I find out the error? I'm thinking valgrind may
>> take very long and gives too many false errors.
> It is very easy to find leaks. You just run a few steps with -malloc_dump
> and see what is left over.
>    Matt
> Hi Matt,
> Do you mean running my a.out with the -malloc_dump and stop after a few
> time steps?
> What and how should I "see" then?
-malloc_dump outputs all unfreed memory to the screen after
PetscFinalize(), so you should see the leak.
I guess it might be possible to keep creating things that you freed all at
once at the end, but that is less likely.
   Matt
>> Thank you
>> Yours sincerely,
>> TAY wee-beng
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160224/b6890158/attachment.html>
