[petsc-users] Convergence trouble with SNES and CG
Mon Feb 22 19:06:55 CST 2016
On Mon, Feb 22, 2016 at 6:27 PM, David Knezevic <david.knezevic at akselos.com>
wrote:
> On Mon, Feb 22, 2016 at 7:10 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, Feb 22, 2016 at 6:02 PM, David Knezevic <
>> david.knezevic at akselos.com> wrote:
>>> On Mon, Feb 22, 2016 at 6:57 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>   Add -ksp_converged_reason
>>> That gives "DIVERGED_INDEFINITE_PC". The full output is below:
>> Just for testing, replace CG with GMRES.
> With GMRES the first four nonlinear iterations behave much that same as
> before, converging at KSP iteration 150 or so.
> On the 5th nonlinear iteration, GMRES doesn't give a KSP convergence
> failure, but the convergence seems to stagnate. It's currently at KSP
> iteration 2000, and tolerance of 6e-3 (and still running).
Can you use LU? The idea is to determine is the linear system becomes
(almost) rank deficient or if the nonlinear problem is just hard.
   Matt
> David
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160222/0a892ba1/attachment-0001.html>
