[petsc-users] Convergence trouble with SNES and CG
David Knezevic david.knezevic at akselos.com
Mon Feb 22 18:27:16 CST 2016
On Mon, Feb 22, 2016 at 7:10 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Feb 22, 2016 at 6:02 PM, David Knezevic <
> david.knezevic at akselos.com> wrote:
>> On Mon, Feb 22, 2016 at 6:57 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>   Add -ksp_converged_reason
>> That gives "DIVERGED_INDEFINITE_PC". The full output is below:
> Just for testing, replace CG with GMRES.
With GMRES the first four nonlinear iterations behave much that same as
before, converging at KSP iteration 150 or so.
On the 5th nonlinear iteration, GMRES doesn't give a KSP convergence
failure, but the convergence seems to stagnate. It's currently at KSP
iteration 2000, and tolerance of 6e-3 (and still running).
David
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160222/c1bb5268/attachment.html>
