[petsc-users] Doubt in MPIPreallocation
John Albequerque johncfdcfd at gmail.com
Fri Feb 19 08:01:26 CST 2016
I am really sorry Matthew but I am not able to get your point. It would be
very kind of you if you could show me the changes in the code.
Thanks
John Albequerque.
Materials Science Lab,
UIUC
On Fri, Feb 19, 2016 at 5:15 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Feb 19, 2016 at 5:09 AM, John Albequerque <johncfdcfd at gmail.com>
> wrote:
>> Dear Matt,
>> Sorry, I am not able to get you, as if I do not provide i>=j then the
>> matrix mentioned in the earlier mail won't be generated. For the code I
>> mentioned earlier, the output obtained is as follows -
>> *Mat Object: 1 MPI processes  type: mpiaijrow 0: (0, 1)  (1, 1)  (2, 1)
>> (3, 1)  (4, 0)  (5, 0)  (6, 0)  (7, 0) row 1: (0, 0)  (1, 1)  (2, 1)  (3,
>> 1)  (4, 1)  (5, 0)  (6, 0)  (7, 0) row 2: (0, 0)  (1, 0)  (2, 1)  (3, 1)
>> (4, 1)  (5, 1)  (6, 0)  (7, 0) row 3: (0, 0)  (1, 0)  (2, 0)  (3, 1)  (4,
>> 1)  (5, 1)  (6, 1)  (7, 0) row 4: (0, 0)  (1, 0)  (2, 0)  (3, 0)  (4, 1)
>> (5, 1)  (6, 1)  (7, 1)*
>> which is satisfactory, but once I use *MatMPIAIJSetPreallocation(A,0,d_nnz,0,o_nnz);
>> *the code encounters a runtime error. And throws a malloc error as -
>> *[0]PETSC ERROR: New nonzero at (0,4) caused a mallocUse MatSetOption(A,
>> MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn off this check*
> Print out your dnz and onz. You can clearly see they are wrong. The error
> is your condition which I pointed out above.
>    Matt
>> Thanks
>> John Albequerque.
>> On Fri, Feb 19, 2016 at 4:17 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Fri, Feb 19, 2016 at 4:34 AM, John Albequerque <johncfdcfd at gmail.com>
>>> wrote:
>>>> Currently I have used single processor. And without the Preallocation
>>>> it works fine. And gives me the correct output as well. I have posted the
>>>> full code for reference.
>>>> *Here:* http://pastebin.com/kWUGHqSM
>>> Look at the last row. Your condition 'j >= i' will produce no
>>> off-diagonal rows here, but
>>> clearly you have them, and this is the error you are getting.
>>>    Matt
>>>> On Fri, Feb 19, 2016 at 3:01 PM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Fri, Feb 19, 2016 at 3:27 AM, John Albequerque <
>>>>> johncfdcfd at gmail.com> wrote:
>>>>>> I came up with this could you please have a look at it as I am not
>>>>>> getting it. I am getting an error
>>>>>> *New nonzero at (0,4) caused a malloc*http://pastebin.com/ZxT7SWtc
>>>>>> Could you please have a look at it.
>>>>> It looks like you are only allocating the upper triangle:
>>>>> if((j-i<=3) && (j>=i))
>>>>>             values[(i-low)*nc+j]=1;
>>>>> else
>>>>> values[(i-low)*nc+j]=0;
>>>>>    Matt
>>>>>> Thanks,
>>>>>> John Albequerque
>>>>>> On Fri, Feb 19, 2016 at 1:25 PM, Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Fri, Feb 19, 2016 at 1:50 AM, John Albequerque <
>>>>>>>> Could someone help me setting up this matrix i.e from preallocation
>>>>>>>> to Set Values for an MPIAIJ matrix which has its entries.
>>>>>>>> *1  1  1  1  0  0  0  00  1  1  1  1  0  0  00  0  1  1  1  1  0
>>>>>>>> 00  0  0  1  1  1  1  00  0  0  0  1  1  1  1*
>>>>>>>> I am trying to do it from 3 days now but not able to figure it out.
>>>>>>>> Could someone please help me do this.
>>>>>>> It will be enough to say that each row has 3 off-diagonal values, so
>>>>>>> you can use the simplified preallocation rather
>>>>>>> than giving a value for each row individually.
>>>>>>>    Matt
>>>>>>>> Thanks.
>>>>>>>> John Albequerque.
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160219/5400f534/attachment.html>
