[petsc-users] Doubt in MPIPreallocation
Fri Feb 19 05:45:50 CST 2016
On Fri, Feb 19, 2016 at 5:09 AM, John Albequerque <johncfdcfd at gmail.com>
wrote:
> Dear Matt,
> Sorry, I am not able to get you, as if I do not provide i>=j then the
> matrix mentioned in the earlier mail won't be generated. For the code I
> mentioned earlier, the output obtained is as follows -
> *Mat Object: 1 MPI processes  type: mpiaijrow 0: (0, 1)  (1, 1)  (2, 1)
> (3, 1)  (4, 0)  (5, 0)  (6, 0)  (7, 0) row 1: (0, 0)  (1, 1)  (2, 1)  (3,
> 1)  (4, 1)  (5, 0)  (6, 0)  (7, 0) row 2: (0, 0)  (1, 0)  (2, 1)  (3, 1)
> (4, 1)  (5, 1)  (6, 0)  (7, 0) row 3: (0, 0)  (1, 0)  (2, 0)  (3, 1)  (4,
> 1)  (5, 1)  (6, 1)  (7, 0) row 4: (0, 0)  (1, 0)  (2, 0)  (3, 0)  (4, 1)
> (5, 1)  (6, 1)  (7, 1)*
> which is satisfactory, but once I use *MatMPIAIJSetPreallocation(A,0,d_nnz,0,o_nnz);
> *the code encounters a runtime error. And throws a malloc error as -
> *[0]PETSC ERROR: New nonzero at (0,4) caused a mallocUse MatSetOption(A,
> MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn off this check*
Print out your dnz and onz. You can clearly see they are wrong. The error
is your condition which I pointed out above.
   Matt
> Thanks
> John Albequerque.
> On Fri, Feb 19, 2016 at 4:17 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Fri, Feb 19, 2016 at 4:34 AM, John Albequerque <johncfdcfd at gmail.com>
>> wrote:
>>> Currently I have used single processor. And without the Preallocation it
>>> works fine. And gives me the correct output as well. I have posted the full
>>> code for reference.
>>> *Here:* http://pastebin.com/kWUGHqSM
>> Look at the last row. Your condition 'j >= i' will produce no
>> off-diagonal rows here, but
>> clearly you have them, and this is the error you are getting.
>>    Matt
>>> On Fri, Feb 19, 2016 at 3:01 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Fri, Feb 19, 2016 at 3:27 AM, John Albequerque <johncfdcfd at gmail.com
>>>> > wrote:
>>>>> I came up with this could you please have a look at it as I am not
>>>>> getting it. I am getting an error
>>>>> *New nonzero at (0,4) caused a malloc*http://pastebin.com/ZxT7SWtc
>>>>> Could you please have a look at it.
>>>> It looks like you are only allocating the upper triangle:
>>>> if((j-i<=3) && (j>=i))
>>>>             values[(i-low)*nc+j]=1;
>>>> else
>>>> values[(i-low)*nc+j]=0;
>>>>    Matt
>>>>> Thanks,
>>>>> John Albequerque
>>>>> On Fri, Feb 19, 2016 at 1:25 PM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Fri, Feb 19, 2016 at 1:50 AM, John Albequerque <
>>>>>> johncfdcfd at gmail.com> wrote:
>>>>>>> Could someone help me setting up this matrix i.e from preallocation
>>>>>>> to Set Values for an MPIAIJ matrix which has its entries.
>>>>>>> *1  1  1  1  0  0  0  00  1  1  1  1  0  0  00  0  1  1  1  1  0
>>>>>>> 00  0  0  1  1  1  1  00  0  0  0  1  1  1  1*
>>>>>>> I am trying to do it from 3 days now but not able to figure it out.
>>>>>>> Could someone please help me do this.
>>>>>> It will be enough to say that each row has 3 off-diagonal values, so
>>>>>> you can use the simplified preallocation rather
>>>>>> than giving a value for each row individually.
>>>>>>    Matt
>>>>>>> Thanks.
>>>>>>> John Albequerque.
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160219/23f7aef3/attachment-0001.html>
