[petsc-users] Doubt in MPIPreallocation
Fri Feb 19 04:47:07 CST 2016
On Fri, Feb 19, 2016 at 4:34 AM, John Albequerque <johncfdcfd at gmail.com>
wrote:
> Currently I have used single processor. And without the Preallocation it
> works fine. And gives me the correct output as well. I have posted the full
> code for reference.
> *Here:* http://pastebin.com/kWUGHqSM
Look at the last row. Your condition 'j >= i' will produce no off-diagonal
rows here, but
clearly you have them, and this is the error you are getting.
   Matt
> On Fri, Feb 19, 2016 at 3:01 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Fri, Feb 19, 2016 at 3:27 AM, John Albequerque <johncfdcfd at gmail.com>
>> wrote:
>>> I came up with this could you please have a look at it as I am not
>>> getting it. I am getting an error
>>> *New nonzero at (0,4) caused a malloc*http://pastebin.com/ZxT7SWtc
>>> Could you please have a look at it.
>> It looks like you are only allocating the upper triangle:
>> if((j-i<=3) && (j>=i))
>>             values[(i-low)*nc+j]=1;
>> else
>> values[(i-low)*nc+j]=0;
>>    Matt
>>> Thanks,
>>> John Albequerque
>>> On Fri, Feb 19, 2016 at 1:25 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Fri, Feb 19, 2016 at 1:50 AM, John Albequerque <johncfdcfd at gmail.com
>>>> > wrote:
>>>>> Could someone help me setting up this matrix i.e from preallocation to
>>>>> Set Values for an MPIAIJ matrix which has its entries.
>>>>> *1  1  1  1  0  0  0  00  1  1  1  1  0  0  00  0  1  1  1  1  0  00
>>>>> 0  0  1  1  1  1  00  0  0  0  1  1  1  1*
>>>>> I am trying to do it from 3 days now but not able to figure it out.
>>>>> Could someone please help me do this.
>>>> It will be enough to say that each row has 3 off-diagonal values, so
>>>> you can use the simplified preallocation rather
>>>> than giving a value for each row individually.
>>>>    Matt
>>>>> Thanks.
>>>>> John Albequerque.
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160219/fe88df23/attachment.html>
