[petsc-users] Doubt in MPIPreallocation
John Albequerque johncfdcfd at gmail.com
Fri Feb 19 04:34:46 CST 2016
Currently I have used single processor. And without the Preallocation it
works fine. And gives me the correct output as well. I have posted the full
code for reference.
*Here:* http://pastebin.com/kWUGHqSM
On Fri, Feb 19, 2016 at 3:01 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Feb 19, 2016 at 3:27 AM, John Albequerque <johncfdcfd at gmail.com>
> wrote:
>> I came up with this could you please have a look at it as I am not
>> getting it. I am getting an error
>> *New nonzero at (0,4) caused a malloc*http://pastebin.com/ZxT7SWtc
>> Could you please have a look at it.
> It looks like you are only allocating the upper triangle:
> if((j-i<=3) && (j>=i))
>             values[(i-low)*nc+j]=1;
> else
> values[(i-low)*nc+j]=0;
>    Matt
>> Thanks,
>> John Albequerque
>> On Fri, Feb 19, 2016 at 1:25 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Fri, Feb 19, 2016 at 1:50 AM, John Albequerque <johncfdcfd at gmail.com>
>>> wrote:
>>>> Could someone help me setting up this matrix i.e from preallocation to
>>>> Set Values for an MPIAIJ matrix which has its entries.
>>>> *1  1  1  1  0  0  0  00  1  1  1  1  0  0  00  0  1  1  1  1  0  00
>>>> 0  0  1  1  1  1  00  0  0  0  1  1  1  1*
>>>> I am trying to do it from 3 days now but not able to figure it out.
>>>> Could someone please help me do this.
>>> It will be enough to say that each row has 3 off-diagonal values, so you
>>> can use the simplified preallocation rather
>>> than giving a value for each row individually.
>>>    Matt
>>>> Thanks.
>>>> John Albequerque.
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160219/0510232b/attachment-0001.html>
