[petsc-users] memory scalable AO
Wed Feb 17 22:54:20 CST 2016
Attached are the modified src/dm/impls/da/ftn-auto/daindexf.c and
src/dm/impls/da/ftn-custom/zdaindexf.c files.
Satish
On Wed, 17 Feb 2016, Jed Brown wrote:
> Randall Mackie <rlmackie862 at gmail.com> writes:
> > this leads to the error ‘bin/maint/generatefortranstubs.py’ …No such file.
> > there is no maint directory under bin.
> Ah, I missed that you have a tarball, not a clone of the repository.
> Then you'll have to fix the file manually.  I would start from a clean
> tarball because we have no idea what state your source tree is in after
> applying the match and manually editing files.  Note that this would be
> easy and completely reliable if you used a clone instead of tarball.
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160217/f81eb507/attachment.c>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160217/f81eb507/attachment-0001.c>
