[petsc-users] memory scalable AO
Jed Brown jed at jedbrown.org
Wed Feb 17 22:45:07 CST 2016
Randall Mackie <rlmackie862 at gmail.com> writes:
> this leads to the error ‘bin/maint/generatefortranstubs.py’ …No such file.
> there is no maint directory under bin.
Ah, I missed that you have a tarball, not a clone of the repository.
Then you'll have to fix the file manually.  I would start from a clean
tarball because we have no idea what state your source tree is in after
applying the match and manually editing files.  Note that this would be
easy and completely reliable if you used a clone instead of tarball.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160217/bbab49bc/attachment.pgp>
