[petsc-users] memory scalable AO
Wed Feb 17 20:31:41 CST 2016
  It is probably my fault. Edit src/dm/impls/da/ftn-auto/daindexf.c and remove the function function from that file and then run make on the library again. If that does not work then run in the debugger and put a break point in dmdasetaotype_ once it is there in the debugger you can make sure it is the right function and step until it crashes to see what I have done wrong.
   Baryr
> On Feb 17, 2016, at 7:29 PM, Randall Mackie <rlmackie862 at gmail.com> wrote:
> Unfortunately I am getting exactly the same result.
> I applied the patch (patch -p1 < fix-fortran-dmdasetaotype.patch)
> Then I recompiled the library, and my code, but the error remains.
> Perhaps there is something else I’m missing?
> Randy
>> On Feb 17, 2016, at 3:15 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> Here is  patch. <fix-fortran-dmdasetaotype.patch>
>> If it works for you I'll put it in maint and master tomorrow.
>> Barry
>>> On Feb 17, 2016, at 3:46 PM, Randall Mackie <rlmackie862 at gmail.com> wrote:
>>> The attached test program demonstrates the problem. When I run it, I get the following output:
>>> [0]PETSC ERROR: ------------------------------------------------------------------------
>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>>> [0]PETSC ERROR: likely location of problem given in stack below
>>> [0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>>> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
>>> [0]PETSC ERROR:       is given.
>>> [0]PETSC ERROR: [0] PetscStrlen line 150 /home/rmackie/PETSc/petsc-3.6.3/src/sys/utils/str.c
>>> [0]PETSC ERROR: [0] PetscStrallocpy line 185 /home/rmackie/PETSc/petsc-3.6.3/src/sys/utils/str.c
>>> [0]PETSC ERROR: [0] DMDASetAOType line 84 /home/rmackie/PETSc/petsc-3.6.3/src/dm/impls/da/daindex.c
>>> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>>> [0]PETSC ERROR: Signal received
>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>>> Randy
>>>> On Feb 17, 2016, at 11:35 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> Should be ok. Do you have implicit none and the correct include files so AOMEMORYSCALABLE is defined?
>>>> I think you need to run in the debugger next to track why this happens.
>>>> Barry
>>>>> On Feb 17, 2016, at 11:33 AM, Randall Mackie <rlmackie862 at gmail.com> wrote:
>>>>> What is the correct way to set the AO for a DMDA to be the memory scalable version?
>>>>> I have tried this:
>>>>> call DMDASetAOType(da,AOMEMORYSCALABLE,ierr)
>>>>> call DMDAGetAO(da,ao,ierr)
>>>>> The code compiles fine, but I simply get a Segmentation Violation when I run it:
>>>>> [3]PETSC ERROR: ------------------------------------------------------------------------
>>>>> [3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>>>>> [3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>>> [3]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>> [3]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>>>>> [3]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
>>>>> [3]PETSC ERROR: to get more information on the crash.
>>>>> [3]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>>>>> [3]PETSC ERROR: Signal received
>>>>> [3]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>>>>> [3]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
>>>>> [3]PETSC ERROR: Configure options PETSC_ARCH=linux-gfortran-opt --with-clean=1 --with-scalar-type=complex --with-debugging=0 --with-fortran=1 --download-mpich=./mpich-3.1.3.tar.gz --FOPTFLAGS=-O3 --COPTFLAGS=-O3
>>>>> [3]PETSC ERROR: #1 User provided function() line 0 in  unknown file
>>>>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 3
>>>>> [cli_3]: aborting job:
>>>>> In fact, I get the same thing even if I set the AOType to AOBASIC, in other words
>>>>> call DMDASetAOTYPE(da,AOBASIC,ierr)
>>>>> Previously, I did not set an AOType, and only called DMDAGetAO, which works fine, and from what I can tell sets the type to basic.
>>>>> Thanks, Randy M.
>>> <test.F90><makefile>
