[petsc-users] memory scalable AO
Randall Mackie rlmackie862 at gmail.com
Wed Feb 17 19:29:11 CST 2016
Unfortunately I am getting exactly the same result.
I applied the patch (patch -p1 < fix-fortran-dmdasetaotype.patch)
Then I recompiled the library, and my code, but the error remains.
Perhaps there is something else I’m missing?
Randy
> On Feb 17, 2016, at 3:15 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  Here is  patch. <fix-fortran-dmdasetaotype.patch>
>  If it works for you I'll put it in maint and master tomorrow.
>  Barry
>> On Feb 17, 2016, at 3:46 PM, Randall Mackie <rlmackie862 at gmail.com> wrote:
>> The attached test program demonstrates the problem. When I run it, I get the following output:
>> [0]PETSC ERROR: ------------------------------------------------------------------------
>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>> [0]PETSC ERROR: likely location of problem given in stack below
>> [0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
>> [0]PETSC ERROR:       is given.
>> [0]PETSC ERROR: [0] PetscStrlen line 150 /home/rmackie/PETSc/petsc-3.6.3/src/sys/utils/str.c
>> [0]PETSC ERROR: [0] PetscStrallocpy line 185 /home/rmackie/PETSc/petsc-3.6.3/src/sys/utils/str.c
>> [0]PETSC ERROR: [0] DMDASetAOType line 84 /home/rmackie/PETSc/petsc-3.6.3/src/dm/impls/da/daindex.c
>> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>> [0]PETSC ERROR: Signal received
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>> Randy
>>> On Feb 17, 2016, at 11:35 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> Should be ok. Do you have implicit none and the correct include files so AOMEMORYSCALABLE is defined?
>>> I think you need to run in the debugger next to track why this happens.
>>> Barry
>>>> On Feb 17, 2016, at 11:33 AM, Randall Mackie <rlmackie862 at gmail.com> wrote:
>>>> What is the correct way to set the AO for a DMDA to be the memory scalable version?
>>>> I have tried this:
>>>> call DMDASetAOType(da,AOMEMORYSCALABLE,ierr)
>>>> call DMDAGetAO(da,ao,ierr)
>>>> The code compiles fine, but I simply get a Segmentation Violation when I run it:
>>>> [3]PETSC ERROR: ------------------------------------------------------------------------
>>>> [3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>>>> [3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>> [3]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>> [3]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>>>> [3]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
>>>> [3]PETSC ERROR: to get more information on the crash.
>>>> [3]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>>>> [3]PETSC ERROR: Signal received
>>>> [3]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>>>> [3]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
>>>> [3]PETSC ERROR: Configure options PETSC_ARCH=linux-gfortran-opt --with-clean=1 --with-scalar-type=complex --with-debugging=0 --with-fortran=1 --download-mpich=./mpich-3.1.3.tar.gz --FOPTFLAGS=-O3 --COPTFLAGS=-O3
>>>> [3]PETSC ERROR: #1 User provided function() line 0 in  unknown file
>>>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 3
>>>> [cli_3]: aborting job:
>>>> In fact, I get the same thing even if I set the AOType to AOBASIC, in other words
>>>> call DMDASetAOTYPE(da,AOBASIC,ierr)
>>>> Previously, I did not set an AOType, and only called DMDAGetAO, which works fine, and from what I can tell sets the type to basic.
>>>> Thanks, Randy M.
>> <test.F90><makefile>
