[petsc-users] PCFIELDSPLIT question
Tue Feb 16 19:27:31 CST 2016
On Tue, Feb 16, 2016 at 1:46 PM, Hom Nath Gharti <hng.email at gmail.com>
wrote:
> Hi Matt,
> Finally I was able to run my program with field split option. But it
> is very slow. One KSP iteration takes about 5mins! For comparison,
> without field split it would take couple of seconds.
> I have set three fields corresponding to solid displacement (u), fluid
> pressure (p), and fluid potential (\xi). The  matrix is symmetric and
> has  following structure:
>  K_{uu}              0                       K_{u\chi}
>  0                      K_{pp}              K_{p\chi}
>  (K_{u\chi})^T     (K_{p\chi})^T     K_{\chi\chi}
> For testing purpose I use the command:
> srun -n 96 ./bin/xspecfem3D -ksp_monitor -ksp_type fgmres
> -fieldsplit_0_pc_type jacobi -fieldsplit_1_pc_type jacobi
> -fieldsplit_2_pc_type jacobi
> It seems that I may be doing something wrong. Any help would be
> greatly appreciated.
1) When trying something new,  I would try it on 1 process to make sure i
was doing the right thing
2) I would send the output of -ksp_view, so that other people could see
what I was doing
3) For performance questions, I would attach the output of -log_summary.
  Matt
> Thanks,
> Hom Nath
> On Thu, Feb 11, 2016 at 1:41 PM, Hom Nath Gharti <hng.email at gmail.com>
> wrote:
> > Perfect! Thanks a lot Matt!
> > Hom Nath
> > On Thu, Feb 11, 2016 at 1:34 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> >> On Thu, Feb 11, 2016 at 11:47 AM, Hom Nath Gharti <hng.email at gmail.com>
> >> wrote:
> >>> Thanks all. With further help from Stefano Zhampini I was able to
> >>> solve my small test case using PCFieldSPlit option. I had to add
> >>> call PCSetType(pc,PCFIELDSPLIT,ierr)
> >>> Now I am trying to use same technique in my actual problem and got the
> >>> error:
> >>> PETSC ERROR: Fields must be sorted when creating split
> >>> Does this mean I have to sort the global matrix rows according the
> split
> >>> fields?
> >> You have to sort the IS you pass to PCFieldSplitSetIS() which can be
> done
> >> using ISSort()
> >>   Thanks,
> >>     Matt
> >>> Thanks
> >>> Hom Nath
> >>> On Tue, Feb 9, 2016 at 10:57 AM, Hom Nath Gharti <hng.email at gmail.com>
> >>> wrote:
> >>> > Sounds interesting! Thanks a lot Matt! I will have a look.
> >>> > Hom Nath
> >>> > On Tue, Feb 9, 2016 at 10:36 AM, Matthew Knepley <knepley at gmail.com>
> >>> > wrote:
> >>> >> On Tue, Feb 9, 2016 at 9:31 AM, Hom Nath Gharti <
> >>> >> wrote:
> >>> >>> Thanks a lot Matt!
> >>> >>> Were you referring to
> http://www.mcs.anl.gov/petsc/petsc-current/src/snes/examples/tutorials/ex62.c.html
> >>> >>> I do not see any statements related to PCFieldSplit there. Am I
> >>> >>> missing something here?
> >>> >> Yes. The whole point is not to put anything specific to FIELDSPLIT
> in
> >>> >> the
> >>> >> code. It is all in options. For example,
> >>> >>   ./ex62 -run_type full -refinement_limit 0.00625 -bc_type dirichlet
> >>> >> -interpolate 1 -vel_petscspace_order 2 -pres_petscspace_order 1
> >>> >> -ksp_type
> >>> >> fgmres -ksp_gmres_restart 100 -ksp_rtol 1.0e-9 -pc_type fieldsplit
> >>> >> -pc_fieldsplit_type schur -pc_fieldsplit_schur_factorization_type
> upper
> >>> >> -fieldsplit_pressure_ksp_rtol 1e-10 -fieldsplit_velocity_ksp_type
> gmres
> >>> >> -fieldsplit_velocity_pc_type lu -fieldsplit_pressure_pc_type jacobi
> >>> >> -snes_monitor_short -ksp_monitor_short -snes_converged_reason
> >>> >> -ksp_converged_reason -snes_view -show_solution 0
> >>> >> The reason that it works is that the DM calls PCFIeldSplitSetIS()
> for
> >>> >> each
> >>> >> field in the DM.
> >>> >>   Thanks,
> >>> >>     Matt
> >>> >>> Thanks,
> >>> >>> Hom Nath
> >>> >>> On Tue, Feb 9, 2016 at 10:19 AM, Matthew Knepley <
> >>> >>> wrote:
> >>> >>> > On Tue, Feb 9, 2016 at 9:10 AM, Hom Nath Gharti
> >>> >>> > wrote:
> >>> >>> >> Thank you so much Barry!
> >>> >>> >> For my small test case, with -pc_fieldsplit_block_size 4, the
> >>> >>> >> program
> >>> >>> >> runs, although the answer was not correct. At least now I get
> >>> >>> >> something to look upon. I am using PCFieldSplitSetIS to set the
> >>> >>> >> fields. Do I still need to use -pc_fieldsplit_block_size?
> >>> >>> > No, this is only for co-located discretizations.
> >>> >>> >> In my case each grid point may have different variable sets. For
> >>> >>> >> example, the grid point in the solid region has displacement and
> >>> >>> >> gravity potential: ux, uy, uz, and \phi. Whereas the grid point
> in
> >>> >>> >> the
> >>> >>> >> fluid region has scalar potential, pressure and gravity
> potential:
> >>> >>> >> \chi, p, and \phi. And the solid-fluid interface has all of
> them.
> >>> >>> >> Do
> >>> >>> >> you think I can still use PCFIELDSPLIT in this situation?
> >>> >>> > We have examples, like SNES ex62, which do exactly this.
> >>> >>> >   Thanks,
> >>> >>> >     Matt
> >>> >>> >> Best,
> >>> >>> >> Hom Nath
> >>> >>> >> On Mon, Feb 8, 2016 at 2:27 PM, Barry Smith <bsmith at mcs.anl.gov
> >>> >>> >> wrote:
> >>> >>> >> >    In this case you need to provide two pieces of information
> to
> >>> >>> >> > the
> >>> >>> >> > PCFIELDSPLIT. What we call the "block size" or bs which is the
> >>> >>> >> > number
> >>> >>> >> > of
> >>> >>> >> > "basic fields" in the problem. For example if at each grid
> point
> >>> >>> >> > you
> >>> >>> >> > have
> >>> >>> >> > x-velocity, y-velocity, and pressure the block size is 3. The
> >>> >>> >> > second
> >>> >>> >> > is you
> >>> >>> >> > need to tell PCFIELDSPLIT what "basic fields" are in each
> split
> >>> >>> >> > you
> >>> >>> >> > want to
> >>> >>> >> > use.
> >>> >>> >> >    In your case you can do this with
> -pc_fieldsplit_block_size 4.
> >>> >>> >> > (Note if you use a DM to define your problem the PCFIELDSPLIT
> >>> >>> >> > will
> >>> >>> >> > automatically get the bs from the DM so you do not need to
> >>> >>> >> > provide
> >>> >>> >> > it.
> >>> >>> >> > Similarly if you set a block size on your Mat the PCFIELDSPLIT
> >>> >>> >> > will
> >>> >>> >> > use that
> >>> >>> >> > so you don't need to set it).
> >>> >>> >> >    Then use -pc_fieldsplit_0_fields 0,1 to indicate your first
> >>> >>> >> > split
> >>> >>> >> > is
> >>> >>> >> > the 0 and 1 basic fields and -pc_fieldsplit_1_fields 2,3 to
> >>> >>> >> > indicate
> >>> >>> >> > the
> >>> >>> >> > second split is the 2 and 3 basic fields.
> >>> >>> >> > (By default if you do not provide this then PCFIELDSPLIT will
> use
> >>> >>> >> > bs
> >>> >>> >> > splits (4 in your case) one for each basic field.
> >>> >>> >> >    Barry
> >>> >>> >> >> On Feb 8, 2016, at 11:20 AM, Hom Nath Gharti
> >>> >>> >> >> wrote:
> >>> >>> >> >> Hi Matt, Hi all,
> >>> >>> >> >> I am trying to have some feel for PCFIELDSPLIT testing on a
> very
> >>> >>> >> >> small
> >>> >>> >> >> matrix (attached below). I have 4 degrees of freedoms. I use
> 4
> >>> >>> >> >> processors. I want to split 4 dofs into two fields each
> having
> >>> >>> >> >> two
> >>> >>> >> >> dofs. I don't know whether this my be a problem for petsc.
> When
> >>> >>> >> >> I
> >>> >>> >> >> use
> >>> >>> >> >> the command:
> >>> >>> >> >> srun -n 4 ./xtestfs -ksp_monitor -ksp_view
> >>> >>> >> >> It runs fine.
> >>> >>> >> >> But when I want to use field split options using the command:
> >>> >>> >> >> srun -n 4 ./xtestfs -ksp_monitor -ksp_type fgmres -pc_type
> >>> >>> >> >> fieldsplit
> >>> >>> >> >> -fieldsplit_0_ksp_type gmres -fieldsplit_0_pc_type bjacobi
> >>> >>> >> >> I get the following error message:
> >>> >>> >> >> [0]PETSC ERROR: Petsc has generated inconsistent data
> >>> >>> >> >> [0]PETSC ERROR: Unhandled case, must have at least two
> fields,
> >>> >>> >> >> not 1
> >>> >>> >> >> [0]PETSC ERROR: See
> >>> >>> >> >> http://www.mcs.anl.gov/petsc/documentation/faq.html for
> trouble
> >>> >>> >> >> shooting.
> >>> >>> >> >> [0]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
> >>> >>> >> >> [0]PETSC ERROR: /tigress/hgharti/test/testfs/./xtestfs on a
> >>> >>> >> >> arch-linux2-c-debug named tiger-r11n1 by hgharti Mon Feb  8
> >>> >>> >> >> 11:40:03
> >>> >>> >> >> 2016
> >>> >>> >> >> [0]PETSC ERROR: Configure options
> --with-blas-lapack-dir=/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64/
> >>> >>> >> >> --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
> >>> >>> >> >> --with-mpiexec=mpiexec --with-debugging=1
> --download-scalapack
> >>> >>> >> >> --download-mumps --download-pastix --download-superlu
> >>> >>> >> >> --download-superlu_dist --download-metis --download-parmetis
> >>> >>> >> >> --download-ptscotch --download-hypre
> >>> >>> >> >> [0]PETSC ERROR: #1 PCFieldSplitSetDefaults() line 469 in
> /home/hgharti/lsoft/petsc-3.6.3-intel16-mpi5/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> >>> >>> >> >> [0]PETSC ERROR: #2 PCSetUp_FieldSplit() line 486 in
> >>> >>> >> >> [0]PETSC ERROR: #3 PCSetUp() line 983 in
> /home/hgharti/lsoft/petsc-3.6.3-intel16-mpi5/src/ksp/pc/interface/precon.c
> >>> >>> >> >> [0]PETSC ERROR: #4 KSPSetUp() line 332 in
> /home/hgharti/lsoft/petsc-3.6.3-intel16-mpi5/src/ksp/ksp/interface/itfunc.c
> >>> >>> >> >> [0]PETSC ERROR: #5 KSPSolve() line 546 in
> >>> >>> >> >> WARNING! There are options you set that were not used!
> >>> >>> >> >> WARNING! could be spelling mistake, etc!
> >>> >>> >> >> Option left: name:-fieldsplit_0_ksp_type value: gmres
> >>> >>> >> >> Option left: name:-fieldsplit_0_pc_type value: bjacobi
> >>> >>> >> >> Option left: name:-fieldsplit_1_pc_type value: jacobi
> >>> >>> >> >> forrtl: error (76): Abort trap signal
> >>> >>> >> >> I tried several trials but could not fix the problem. Is it
> the
> >>> >>> >> >> FORTRAN problem or am I doing something wrong? Any
> suggestions
> >>> >>> >> >> would
> >>> >>> >> >> be greatly appreciated.
> >>> >>> >> >> For your information I use:
> >>> >>> >> >> PETSc-3.6.3
> >>> >>> >> >> intel-16.0 compiler
> >>> >>> >> >> intel-mpi-5.1.1
> >>> >>> >> >> Program
> >>> >>> >> >> Best,
> >>> >>> >> >> Hom Nath
> >>> >>> >> >> ! simple test case for PCFIELDSPLIT
> >>> >>> >> >> program testfs
> >>> >>> >> >> implicit none
> >>> >>> >> >> #include "petsc/finclude/petscsys.h"
> >>> >>> >> >> #include "petsc/finclude/petscvec.h"
> >>> >>> >> >> #include "petsc/finclude/petscvec.h90"
> >>> >>> >> >> #include "petsc/finclude/petscmat.h"
> >>> >>> >> >> #include "petsc/finclude/petscksp.h"
> >>> >>> >> >> #include "petsc/finclude/petscpc.h"
> >>> >>> >> >> #include "petsc/finclude/petscviewer.h"
> >>> >>> >> >> #include "petsc/finclude/petscviewer.h90"
> >>> >>> >> >> Vec              x,b,u
> >>> >>> >> >> Mat              A
> >>> >>> >> >> KSP              ksp
> >>> >>> >> >> PC               pc
> >>> >>> >> >> PetscErrorCode   ierr
> >>> >>> >> >> PetscBool        flg
> >>> >>> >> >> PetscInt         errcode,its,maxitr,myrank,nproc
> >>> >>> >> >> PetscInt
>  nedof,nelmt,ndof,nenod,ngdof,fixdof,nsparse,neq
> >>> >>> >> >> PetscInt,allocatable  :: krow_sparse(:),ggdof_elmt(:,:),
> >>> >>> >> >> inode_elmt(:,:)
> >>> >>> >> >> PetscReal,allocatable :: storef(:,:),storekmat(:,:,:)
> >>> >>> >> >> PetscInt gdof0(2),gdof1(2)
> >>> >>> >> >> ! initialize MPI
> >>> >>> >> >> call MPI_INIT(errcode)
> >>> >>> >> >> if(errcode /= 0)stop 'ERROR: cannot initialize MPI!'
> >>> >>> >> >> call MPI_COMM_RANK(MPI_COMM_WORLD,myrank,errcode)
> >>> >>> >> >> if(errcode /= 0)stop 'ERROR: cannot find processor ID'
> >>> >>> >> >> call MPI_COMM_SIZE(MPI_COMM_WORLD,nproc,errcode)
> >>> >>> >> >> if(errcode /= 0)stop 'ERROR: cannot find number of
> processors!'
> >>> >>> >> >> ! define some parameters
> >>> >>> >> >> ! 1D model with 4 elements. Each elements consits of 2 nodes.
> >>> >>> >> >> Node 0
> >>> >>> >> >> is
> >>> >>> >> >> fixed.
> >>> >>> >> >> ! 1-----------2-----------3-----------4-----------5
> >>> >>> >> >> nelmt=1 ! per processor
> >>> >>> >> >> nenod=2 ! number of nodes per element
> >>> >>> >> >> nedof=2 ! number of DOFs per element
> >>> >>> >> >> ndof=2  ! number of DOFs
> >>> >>> >> >> ngdof=4 ! total number of global DOFs
> >>> >>> >> >> fixdof=1
> >>> >>> >> >> if(myrank==0)then
> >>> >>> >> >>  neq=1 ! number of equations
> >>> >>> >> >>  nsparse=1
> >>> >>> >> >> else
> >>> >>> >> >>  neq=2 ! number of equations
> >>> >>> >> >>  nsparse=4
> >>> >>> >> >> endif
> >>> >>> >> >> allocate(storef(nedof,nelmt),storekmat(nedof,nedof,nelmt),
> ggdof_elmt(nedof,nelmt),inode_elmt(nenod,nelmt),krow_sparse(nsparse))
> >>> >>> >> >> storef=0.0_8 ! local RHS vector
> >>> >>> >> >> storekmat=0.0_8 ! local stiffness matrix
> >>> >>> >> >> if(myrank==0)then
> >>> >>> >> >>  krow_sparse(:)=1
> >>> >>> >> >>  storef(:,1)=(/12.5000_8, 12.5000_8/)
> >>> >>> >> >>  storekmat(:,:,1) = reshape((/1.2333333332_8,
> 0.0166666667_8, &
> >>> >>> >> >>                               0.0166666667_8,
> >>> >>> >> >> 1.2333333332_8/),(/nedof,nedof/))
> >>> >>> >> >>  inode_elmt(:,1)  = (/1,2/)
> >>> >>> >> >>  ggdof_elmt(:,1)  = (/0,1/) ! 0 because left node is fixed
> >>> >>> >> >> elseif(myrank==1)then
> >>> >>> >> >>  krow_sparse(:)=(/1,1,2,2/)
> 0.0166666667_8, &
> >>> >>> >> >>                               0.0166666667_8,
> >>> >>> >> >>  ggdof_elmt(:,1)  = (/1,2/)
> >>> >>> >> >> elseif(myrank==2)then
> 0.0166666667_8, &
> >>> >>> >> >>                               0.0166666667_8,
> >>> >>> >> >>  ggdof_elmt(:,1)  = (/2,3/)
> >>> >>> >> >> elseif(myrank==3)then
> >>> >>> >> >>  storef(:,1)=(/12.5000_8, 22.5000_8/)
> 0.0166666667_8, &
> >>> >>> >> >>                               0.0166666667_8,
> >>> >>> >> >>  ggdof_elmt(:,1)  = (/3,4/)
> >>> >>> >> >> endif
> >>> >>> >> >> call petsc_initialize
> >>> >>> >> >> call petsc_set_matrix
> >>> >>> >> >> call petsc_set_vector
> >>> >>> >> >> call petsc_solve
> >>> >>> >> >> call petsc_finalize
> >>> >>> >> >> ! deallocate
> >>> >>> >> >> deallocate(storef,storekmat,ggdof_elmt,inode_elmt)
> >>> >>> >> >> deallocate(krow_sparse)
> >>> >>> >> >> contains
> >>> >>> >> >> subroutine petsc_initialize()
> >>> >>> >> >> implicit none
> >>> >>> >> >> PetscInt :: istart,iend
> >>> >>> >> >> PetscInt :: nzeros_max,nzeros_min
> >>> >>> >> >> PetscReal :: atol,dtol,rtol
> >>> >>> >> >> PetscInt,allocatable :: nzeros(:)
> >>> >>> >> >> IS gdof0_is,gdof1_is
> >>> >>> >> >> call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
> >>> >>> >> >> call
> >>> >>> >> >> PetscOptionsGetInt(PETSC_NULL_CHARACTER,'-n',ngdof,flg,ierr)
> >>> >>> >> >> ! count number of nonzeros per row
> >>> >>> >> >> allocate(nzeros(neq))
> >>> >>> >> >> nzeros=0
> >>> >>> >> >> nzeros(krow_sparse)=nzeros(krow_sparse)+1
> >>> >>> >> >> nzeros_max=maxval(nzeros)
> >>> >>> >> >> nzeros_min=minval(nzeros)
> >>> >>> >> >> ! create matrix
> >>> >>> >> >> call MatCreate(PETSC_COMM_WORLD,A,ierr)
> >>> >>> >> >> call MatSetType(A,MATMPIAIJ,ierr)
> >>> >>> >> >> CHKERRQ(ierr)
> >>> >>> >> >> call
> MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,ngdof,ngdof,ierr)
> >>> >>> >> >> CHKERRQ(ierr)
> >>> >>> >> >> ! preallocation
> >>> >>> >> >> call
> MatMPIAIJSetPreallocation(A,nzeros_max,PETSC_NULL_INTEGER,nzeros_max,     &
> >>> >>> >> >> PETSC_NULL_INTEGER,ierr)
> >>> >>> >> >> CHKERRQ(ierr)
> >>> >>> >> >> call MatGetOwnershipRange(A,istart,iend,ierr)
> >>> >>> >> >> CHKERRQ(ierr)
> >>> >>> >> >> print*,'ownership:',myrank,istart,iend
> >>> >>> >> >> ! create vector
> >>> >>> >> >> call VecCreate(PETSC_COMM_WORLD,x,ierr)
> >>> >>> >> >> call VecSetSizes(x,PETSC_DECIDE,ngdof,ierr)
> >>> >>> >> >> call VecSetType(x,VECMPI,ierr)
> >>> >>> >> >> call VecDuplicate(x,b,ierr)
> >>> >>> >> >> call VecDuplicate(x,u,ierr)
> >>> >>> >> >> ! get IS for split fields
> >>> >>> >> >> gdof0=(/0,1/)
> >>> >>> >> >> gdof1=(/2,3/)
> >>> >>> >> >> call
> ISCreateGeneral(PETSC_COMM_WORLD,2,gdof0,PETSC_COPY_VALUES,gdof0_is,ierr)
> >>> >>> >> >> CHKERRQ(ierr)
> >>> >>> >> >> call
> ISCreateGeneral(PETSC_COMM_WORLD,2,gdof1,PETSC_COPY_VALUES,gdof1_is,ierr)
> >>> >>> >> >> CHKERRQ(ierr)
> >>> >>> >> >> ! Create linear solver context
> >>> >>> >> >> call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
> >>> >>> >> >> call KSPSetOperators(ksp,A,A,ierr)
> >>> >>> >> >> call KSPGetPC(ksp,pc,ierr)
> >>> >>> >> >> CHKERRQ(ierr)
> >>> >>> >> >> ! split PC
> >>> >>> >> >> call PCFieldSplitSetIS(pc,"0",gdof0_is,ierr);
> >>> >>> >> >> CHKERRQ(ierr)
> >>> >>> >> >> call ISDestroy(gdof0_is,ierr)
> >>> >>> >> >> CHKERRQ(ierr)
> >>> >>> >> >> call PCFieldSplitSetIS(pc,"1",gdof1_is,ierr);
> >>> >>> >> >> CHKERRQ(ierr)
> >>> >>> >> >> call ISDestroy(gdof1_is,ierr)
> >>> >>> >> >> CHKERRQ(ierr)
> >>> >>> >> >> rtol = 1.0d-6
> >>> >>> >> >> atol = 1.0d-6
> >>> >>> >> >> dtol = 1.0d10
> >>> >>> >> >> maxitr = 1000
> >>> >>> >> >> call KSPSetTolerances(ksp,rtol,atol,dtol,maxitr,ierr)
> >>> >>> >> >> CHKERRQ(ierr)
> >>> >>> >> >> call KSPSetFromOptions(ksp,ierr)
> >>> >>> >> >> end subroutine petsc_initialize
> >>> >>> >> >> subroutine petsc_set_matrix()
> >>> >>> >> >> implicit none
> >>> >>> >> >> integer :: i,i_elmt,j,ncount
> >>> >>> >> >> integer :: ggdof(NEDOF),idof(NEDOF),igdof(NEDOF)
> >>> >>> >> >> ! Set and assemble matrix.
> >>> >>> >> >> call MatZeroEntries(A,ierr)
> >>> >>> >> >> CHKERRQ(ierr)
> >>> >>> >> >> do i_elmt=1,nelmt
> >>> >>> >> >>  ggdof(:)=ggdof_elmt(:,i_elmt)
> >>> >>> >> >>  ggdof(:)=ggdof(:)-1 ! petsc index starts from 0
> >>> >>> >> >>  ncount=0; idof=-1; igdof=-1
> >>> >>> >> >>  do i=1,NEDOF
> >>> >>> >> >>    do j=1,NEDOF
> >>> >>> >> >>    if(ggdof(i).ge.0.and.ggdof(j).ge.0)then
> >>> >>> >> >>      call
> >>> >>> >> >> MatSetValues(A,1,ggdof(i),1,ggdof(j),storekmat(i,j,i_elmt),
> >>> >>> >> >>      ADD_VALUES,ierr)
> >>> >>> >> >>      CHKERRQ(ierr)
> >>> >>> >> >>    endif
> >>> >>> >> >>    enddo
> >>> >>> >> >>  enddo
> >>> >>> >> >> enddo
> >>> >>> >> >> call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
> >>> >>> >> >> call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
> >>> >>> >> >> if(myrank==0)print*,'matrix setting & assembly complete!'
> >>> >>> >> >> end subroutine petsc_set_matrix
> >>> >>> >> >> subroutine petsc_set_vector()
> >>> >>> >> >> implicit none
> >>> >>> >> >> PetscScalar      zero
> >>> >>> >> >> integer :: i,i_elmt,ncount
> >>> >>> >> >> ! set vector
> >>> >>> >> >> zero=0.0_8
> >>> >>> >> >> call VecSet(b,zero,ierr)
> >>> >>> >> >> do i_elmt=1,nelmt
> >>> >>> >> >>  do i=1,NEDOF
> >>> >>> >> >>    if(ggdof(i).ge.0)then
> >>> >>> >> >>      call
> >>> >>> >> >> VecSetValues(b,1,ggdof(i),storef(i,i_elmt),ADD_VALUES,ierr);
> >>> >>> >> >>      CHKERRQ(ierr)
> >>> >>> >> >>    endif
> >>> >>> >> >>  enddo
> >>> >>> >> >> enddo
> >>> >>> >> >> ! assemble vector
> >>> >>> >> >> call VecAssemblyBegin(b,ierr)
> >>> >>> >> >> call VecAssemblyEnd(b,ierr)
> >>> >>> >> >> if(myrank==0)print*,'vector setting & assembly complete!'
> >>> >>> >> >> end subroutine petsc_set_vector
> >>> >>> >> >> subroutine petsc_solve()
> >>> >>> >> >> implicit none
> >>> >>> >> >> PetscInt ireason
> >>> >>> >> >> PetscScalar a_v(1)
> >>> >>> >> >> PetscOffset a_i
> >>> >>> >> >> PetscInt n
> >>> >>> >> >> PetscReal,allocatable :: sdata(:)
> >>> >>> >> >> call VecGetSize(b,n,ierr)
> >>> >>> >> >> CHKERRQ(ierr)
> >>> >>> >> >> allocate(sdata(n))
> >>> >>> >> >> sdata=0.0_8
> >>> >>> >> >> call VecGetArray(b,a_v,a_i,ierr)
> >>> >>> >> >> CHKERRQ(ierr)
> >>> >>> >> >> sdata(1:n)=a_v(a_i+1:a_i+n)
> >>> >>> >> >> call VecRestoreArray(b,a_v,a_i,ierr)
> >>> >>> >> >> CHKERRQ(ierr)
> >>> >>> >> >> print*,'rhs:',sdata
> >>> >>> >> >> call KSPSolve(ksp,b,x,ierr)
> >>> >>> >> >> sdata=0.0_8
> >>> >>> >> >> call VecGetArray(x,a_v,a_i,ierr)
> >>> >>> >> >> CHKERRQ(ierr)
> >>> >>> >> >> CHKERRQ(ierr)
> >>> >>> >> >> print*,'solution:',sdata
> >>> >>> >> >> ! Check convergence
> >>> >>> >> >> call KSPGetConvergedReason(ksp,ireason,ierr)
> >>> >>> >> >> if(myrank==0)print*,'converges reason',myrank,ireason
> >>> >>> >> >> call KSPGetIterationNumber(ksp,its,ierr)
> >>> >>> >> >> if(myrank==0)print*,'Iterations:',its
> >>> >>> >> >> deallocate(sdata)
> >>> >>> >> >> end subroutine petsc_solve
> >>> >>> >> >> subroutine petsc_finalize()
> >>> >>> >> >> implicit none
> >>> >>> >> >> ! Free work space.
> >>> >>> >> >> call VecDestroy(x,ierr)
> >>> >>> >> >> call VecDestroy(u,ierr)
> >>> >>> >> >> call VecDestroy(b,ierr)
> >>> >>> >> >> call MatDestroy(A,ierr)
> >>> >>> >> >> call KSPDestroy(ksp,ierr)
> >>> >>> >> >> call PetscFinalize(ierr)
> >>> >>> >> >> CHKERRQ(ierr)
> >>> >>> >> >> end subroutine petsc_finalize
> >>> >>> >> >> end program testfs
> >>> >>> >> >> On Tue, Feb 2, 2016 at 4:54 PM, Matthew Knepley
> >>> >>> >> >> wrote:
> >>> >>> >> >>> On Tue, Feb 2, 2016 at 3:11 PM, Hom Nath Gharti
> >>> >>> >> >>> wrote:
> >>> >>> >> >>>> Thanks a lot. I will try.
> >>> >>> >> >>> Also, if you send a small test case, we can run it and tell
> you
> >>> >>> >> >>> the
> >>> >>> >> >>> problem.
> >>> >>> >> >>>  Matt
> >>> >>> >> >>>> Hom Nath
> >>> >>> >> >>>> On Tue, Feb 2, 2016 at 4:02 PM, Matthew Knepley
> >>> >>> >> >>>> wrote:
> >>> >>> >> >>>>> On Tue, Feb 2, 2016 at 3:01 PM, Hom Nath Gharti
> >>> >>> >> >>>>> wrote:
> >>> >>> >> >>>>>> Thanks again Matt. Unfortunately got the same errors with
> >>> >>> >> >>>>>> '0'. I
> >>> >>> >> >>>>>> think
> >>> >>> >> >>>>>> both are valid in Fortran.
> >>> >>> >> >>>>> Then you will have to go in the debugger and see why its
> not
> >>> >>> >> >>>>> creating 4
> >>> >>> >> >>>>> splits, since this is exactly
> >>> >>> >> >>>>> what it does in our tests. This is how all the SNES tests
> >>> >>> >> >>>>> that I
> >>> >>> >> >>>>> use
> >>> >>> >> >>>>> work. I
> >>> >>> >> >>>>> am sure its a Fortran
> >>> >>> >> >>>>> problem.
> >>> >>> >> >>>>>  Thanks,
> >>> >>> >> >>>>>     Matt
> >>> >>> >> >>>>>> Hom Nath
> >>> >>> >> >>>>>> On Tue, Feb 2, 2016 at 3:42 PM, Matthew Knepley
> >>> >>> >> >>>>>> wrote:
> >>> >>> >> >>>>>>> On Tue, Feb 2, 2016 at 2:35 PM, Hom Nath Gharti
> >>> >>> >> >>>>>>> wrote:
> >>> >>> >> >>>>>>>> Thank you so much Matt.
> >>> >>> >> >>>>>>>> I now tried the following:
> >>> >>> >> >>>>>>>> call PCFieldSplitSetIS(pc,"0",gdofu_is,ierr);
> >>> >>> >> >>>>>>>> call ISDestroy(gdofu_is,ierr)
> >>> >>> >> >>>>>>>> call PCFieldSplitSetIS(pc,"1",gdofchi_is,ierr);
> >>> >>> >> >>>>>>>> call ISDestroy(gdofchi_is,ierr)
> >>> >>> >> >>>>>>>> call PCFieldSplitSetIS(pc,"2",gdofp_is,ierr);
> >>> >>> >> >>>>>>>> call ISDestroy(gdofp_is,ierr)
> >>> >>> >> >>>>>>>> call PCFieldSplitSetIS(pc,"3",gdofphi_is,ierr);
> >>> >>> >> >>>>>>>> call ISDestroy(gdofphi_is,ierr)
> >>> >>> >> >>>>>>>> ! Amat changes in each time steps
> >>> >>> >> >>>>>>>> call KSPSetOperators(ksp,Amat,Amat,ierr) !version >=
> 3.5.0
> >>> >>> >> >>>>>>>> call KSPSolve(ksp,bvec,xvec,ierr)
> >>> >>> >> >>>>>>> I am guessing that "0" is not a valid string for your
> >>> >>> >> >>>>>>> Fortran
> >>> >>> >> >>>>>>> compiler.
> >>> >>> >> >>>>>>> Are
> >>> >>> >> >>>>>>> you sure
> >>> >>> >> >>>>>>> its not single quotes '0'?
> >>> >>> >> >>>>>>>  Matt
> >>> >>> >> >>>>>>>> But I get the following error:
> >>> >>> >> >>>>>>>> [0]PETSC ERROR: --------------------- Error Message
> >>> >>> >> >>>>>>>> fields,
> >>> >>> >> >>>>>>>> not 1
> >>> >>> >> >>>>>>>> [0]PETSC ERROR: See
> for
> >>> >>> >> >>>>>>>> trouble
> >>> >>> >> >>>>>>>> shooting.
> 2015
> >>> >>> >> >>>>>>>> [0]PETSC ERROR:
> /tigress/hgharti/gitwork/SPECFEM3D_GLOBEVSPP/./bin/xspecfem3D
> >>> >>> >> >>>>>>>> on
> >>> >>> >> >>>>>>>> a
> >>> >>> >> >>>>>>>> arch-linux2-c-debug named tiger-r3c1n7 by hgharti Tue
> Feb
> >>> >>> >> >>>>>>>> 2
> >>> >>> >> >>>>>>>> 15:
> >>> >>> >> >>>>>>>> 29:30 2016
> >>> >>> >> >>>>>>>> h-fc=mpif90 --with-mpiexec=mpiexec --with-debugging=1
> >>> >>> >> >>>>>>>> --download-scalapack --download-mumps --download-pastix
> >>> >>> >> >>>>>>>> --download-superlu --download-superlu_dist
> >>> >>> >> >>>>>>>> --download-metis
> >>> >>> >> >>>>>>>> --download-parmetis --download-ptscotch
> --download-hypre
> in
> >>> >>> >> >>>>>>>> Am I missing something?
> >>> >>> >> >>>>>>>> Thanks,
> >>> >>> >> >>>>>>>> Hom Nath
> >>> >>> >> >>>>>>>> On Tue, Feb 2, 2016 at 3:24 PM, Matthew Knepley
> >>> >>> >> >>>>>>>> wrote:
> >>> >>> >> >>>>>>>>> On Tue, Feb 2, 2016 at 2:20 PM, Hom Nath Gharti
> >>> >>> >> >>>>>>>>> wrote:
> >>> >>> >> >>>>>>>>>> Hi Matt, hi all,
> >>> >>> >> >>>>>>>>>> I am trying to use PCFIELDSPLIT for my solver which
> >>> >>> >> >>>>>>>>>> consists
> >>> >>> >> >>>>>>>>>> of
> >>> >>> >> >>>>>>>>>> 4
> >>> >>> >> >>>>>>>>>> different variables, namely, u (displacement vector),
> >>> >>> >> >>>>>>>>>> \chi
> >>> >>> >> >>>>>>>>>> (displacement potential), p(pressure), and \phi
> (gravity
> >>> >>> >> >>>>>>>>>> potential).
> >>> >>> >> >>>>>>>>>> My code segment looks like the following:
> >>> >>> >> >>>>>>>>>> nsplit=4
> >>> >>> >> >>>>>>>>>> call PCFieldSplitSetBlockSize(pc,nsplit,ierr);
> >>> >>> >> >>>>>>>>> You do not need the statement above.
> >>> >>> >> >>>>>>>>>> call PCFieldSplitGetSubKSP(pc,nsplit,subksp,ierr);
> >>> >>> >> >>>>>>>>> These SetOperators() calls are wrong. I am not sure
> why
> >>> >>> >> >>>>>>>>> you
> >>> >>> >> >>>>>>>>> want
> >>> >>> >> >>>>>>>>> them
> >>> >>> >> >>>>>>>>> here.
> >>> >>> >> >>>>>>>>> Also, that means you do not need the call above.
> >>> >>> >> >>>>>>>>>  Thanks,
> >>> >>> >> >>>>>>>>>     Matt
> >>> >>> >> >>>>>>>>>> call KSPSetOperators(subksp(1),Amat,Amat,ierr);
> >>> >>> >> >>>>>>>>>> call KSPSetOperators(subksp(2),Amat,Amat,ierr);
> >>> >>> >> >>>>>>>>>> call KSPSetOperators(subksp(3),Amat,Amat,ierr);
> >>> >>> >> >>>>>>>>>> call KSPSetOperators(subksp(4),Amat,Amat,ierr);
> >>> >>> >> >>>>>>>>>> But I am getting the following error:
> >>> >>> >> >>>>>>>>>> [79]PETSC ERROR: Null argument, when expecting valid
> >>> >>> >> >>>>>>>>>> pointer
> >>> >>> >> >>>>>>>>>> [79]PETSC ERROR: Null Object: Parameter # 1
> >>> >>> >> >>>>>>>>>> [79]PETSC ERROR: #1 KSPSetOperators() line 536 in
> >>> >>> >> >>>>>>>>>> It looks like I am doing something wrong in "call
> >>> >>> >> >>>>>>>>>> KSPSetOperators"
> >>> >>> >> >>>>>>>>>> but
> >>> >>> >> >>>>>>>>>> I could not figure that out.
> >>> >>> >> >>>>>>>>>> Could anybody help me to fix this problem? I looked
> into
> >>> >>> >> >>>>>>>>>> almost
> >>> >>> >> >>>>>>>>>> all
> >>> >>> >> >>>>>>>>>> related examples but I could not really figure out
> the
> >>> >>> >> >>>>>>>>>> correct
> >>> >>> >> >>>>>>>>>> steps
> >>> >>> >> >>>>>>>>>> after "call PCFieldSplitSetIS".
> >>> >>> >> >>>>>>>>>> Any help will be greatly appreciated.
> >>> >>> >> >>>>>>>>>> Best,
> >>> >>> >> >>>>>>>>>> Hom nath
> >>> >>> >> >>>>>>>>>> On Sun, Jan 24, 2016 at 7:14 PM, Hom Nath Gharti
> >>> >>> >> >>>>>>>>>> wrote:
> >>> >>> >> >>>>>>>>>>> Thank you so much Matt! I will try.
> >>> >>> >> >>>>>>>>>>> Hom Nath
> >>> >>> >> >>>>>>>>>>> On Sun, Jan 24, 2016 at 6:26 AM, Matthew Knepley
> >>> >>> >> >>>>>>>>>>> wrote:
> >>> >>> >> >>>>>>>>>>>> On Fri, Jan 22, 2016 at 2:19 PM, Hom Nath Gharti
> >>> >>> >> >>>>>>>>>>>> wrote:
> >>> >>> >> >>>>>>>>>>>>> Dear all,
> >>> >>> >> >>>>>>>>>>>>> I am new to PcFieldSplit.
> >>> >>> >> >>>>>>>>>>>>> I have a matrix formed using MATMPIAIJ. Is it
> >>> >>> >> >>>>>>>>>>>>> possible to
> >>> >>> >> >>>>>>>>>>>>> use
> >>> >>> >> >>>>>>>>>>>>> PCFIELDSPLIT operations in this type of matrix? Or
> >>> >>> >> >>>>>>>>>>>>> does
> >>> >>> >> >>>>>>>>>>>>> it
> >>> >>> >> >>>>>>>>>>>>> have
> >>> >>> >> >>>>>>>>>>>>> to
> >>> >>> >> >>>>>>>>>>>>> be
> >>> >>> >> >>>>>>>>>>>>> MATMPIBIJ or MATNEST format?
> >>> >>> >> >>>>>>>>>>>> Yes, you can split AIJ.
> >>> >>> >> >>>>>>>>>>>>> If possible for MATMPIAIJ, could anybody provide
> me a
> >>> >>> >> >>>>>>>>>>>>> simple
> >>> >>> >> >>>>>>>>>>>>> example
> >>> >>> >> >>>>>>>>>>>>> or few steps? Variables in the equations are
> >>> >>> >> >>>>>>>>>>>>> displacement
> >>> >>> >> >>>>>>>>>>>>> vector,
> >>> >>> >> >>>>>>>>>>>>> scalar potential and pressure.
> >>> >>> >> >>>>>>>>>>>> If you do not have a collocated discretization,
> then
> >>> >>> >> >>>>>>>>>>>> you
> >>> >>> >> >>>>>>>>>>>> have
> >>> >>> >> >>>>>>>>>>>> to
> >>> >>> >> >>>>>>>>>>>> use
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetIS.html
> >>> >>> >> >>>>>>>>>>>>  Thanks,
> >>> >>> >> >>>>>>>>>>>>     Matt
> >>> >>> >> >>>>>>>>>>>>> Thanks for help.
> >>> >>> >> >>>>>>>>>>>>> Hom Nath
> >>> >>> >> >>>>>>>>>>>> What most experimenters take for granted before
> they
> >>> >>> >> >>>>>>>>>>>> begin
> >>> >>> >> >>>>>>>>>>>> their
> >>> >>> >> >>>>>>>>>>>> experiments
> >>> >>> >> >>>>>>>>>>>> is infinitely more interesting than any results to
> >>> >>> >> >>>>>>>>>>>> which
> >>> >>> >> >>>>>>>>>>>> their
> >>> >>> >> >>>>>>>>>>>> experiments
> >>> >>> >> >>>>>>>>>>>> lead.
> >>> >>> >> >>>>>>>>>>>> -- Norbert Wiener
> >>> >>> >> >>>>>>>>> What most experimenters take for granted before they
> >>> >>> >> >>>>>>>>> begin
> >>> >>> >> >>>>>>>>> their
> >>> >>> >> >>>>>>>>> experiments
> which
> >>> >>> >> >>>>>>>>> their
> >>> >>> >> >>>>>>>>> experiments
> >>> >>> >> >>>>>>>>> lead.
> >>> >>> >> >>>>>>>>> -- Norbert Wiener
> begin
> >>> >>> >> >>>>>>> their
> >>> >>> >> >>>>>>> experiments
> >>> >>> >> >>>>>>> is infinitely more interesting than any results to which
> >>> >>> >> >>>>>>> their
> >>> >>> >> >>>>>>> experiments
> >>> >>> >> >>>>>>> lead.
> >>> >>> >> >>>>>>> -- Norbert Wiener
> >>> >>> >> >>>>> What most experimenters take for granted before they begin
> >>> >>> >> >>>>> their
> >>> >>> >> >>>>> experiments
> >>> >>> >> >>>>> their
> >>> >>> >> >>>>> experiments
> >>> >>> >> >>>>> lead.
> >>> >>> >> >>>>> -- Norbert Wiener
> >>> >>> >> >>> their
> >>> >>> >> >>> experiments
> their
> >>> >>> >> >>> experiments
> >>> >>> >> >>> lead.
> >>> >>> >> >>> -- Norbert Wiener
> >>> >>> > What most experimenters take for granted before they begin their
> >>> >>> > experiments
> >>> >>> > is infinitely more interesting than any results to which their
> >>> >>> > experiments
> >>> >>> > lead.
> >>> >>> > -- Norbert Wiener
> >>> >> experiments
> >>> >> experiments
> >>> >> lead.
> >>> >> -- Norbert Wiener
> experiments
> experiments
> >> lead.
> >> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160216/fd2eb7c4/attachment-0001.html>
