[petsc-users] PCFIELDSPLIT question
Hom Nath Gharti hng.email at gmail.com
Tue Feb 16 13:46:42 CST 2016
Hi Matt,
Finally I was able to run my program with field split option. But it
is very slow. One KSP iteration takes about 5mins! For comparison,
without field split it would take couple of seconds.
I have set three fields corresponding to solid displacement (u), fluid
pressure (p), and fluid potential (\xi). The  matrix is symmetric and
has  following structure:
 K_{uu}              0                       K_{u\chi}
 0                      K_{pp}              K_{p\chi}
 (K_{u\chi})^T     (K_{p\chi})^T     K_{\chi\chi}
For testing purpose I use the command:
srun -n 96 ./bin/xspecfem3D -ksp_monitor -ksp_type fgmres
-fieldsplit_0_pc_type jacobi -fieldsplit_1_pc_type jacobi
-fieldsplit_2_pc_type jacobi
It seems that I may be doing something wrong. Any help would be
greatly appreciated.
Hom Nath
On Thu, Feb 11, 2016 at 1:41 PM, Hom Nath Gharti <hng.email at gmail.com> wrote:
> Perfect! Thanks a lot Matt!
> Hom Nath
> On Thu, Feb 11, 2016 at 1:34 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Feb 11, 2016 at 11:47 AM, Hom Nath Gharti <hng.email at gmail.com>
>> wrote:
>>> Thanks all. With further help from Stefano Zhampini I was able to
>>> solve my small test case using PCFieldSPlit option. I had to add
>>> call PCSetType(pc,PCFIELDSPLIT,ierr)
>>> Now I am trying to use same technique in my actual problem and got the
>>> error:
>>> PETSC ERROR: Fields must be sorted when creating split
>>> Does this mean I have to sort the global matrix rows according the split
>>> fields?
>> You have to sort the IS you pass to PCFieldSplitSetIS() which can be done
>> using ISSort()
>>   Thanks,
>>     Matt
>>> Thanks
>>> Hom Nath
>>> On Tue, Feb 9, 2016 at 10:57 AM, Hom Nath Gharti <hng.email at gmail.com>
>>> wrote:
>>> > Sounds interesting! Thanks a lot Matt! I will have a look.
>>> > Hom Nath
>>> > On Tue, Feb 9, 2016 at 10:36 AM, Matthew Knepley <knepley at gmail.com>
>>> > wrote:
>>> >> On Tue, Feb 9, 2016 at 9:31 AM, Hom Nath Gharti <hng.email at gmail.com>
>>> >> wrote:
>>> >>> Thanks a lot Matt!
>>> >>> Were you referring to
>>> >>> http://www.mcs.anl.gov/petsc/petsc-current/src/snes/examples/tutorials/ex62.c.html
>>> >>> I do not see any statements related to PCFieldSplit there. Am I
>>> >>> missing something here?
>>> >> Yes. The whole point is not to put anything specific to FIELDSPLIT in
>>> >> the
>>> >> code. It is all in options. For example,
>>> >>   ./ex62 -run_type full -refinement_limit 0.00625 -bc_type dirichlet
>>> >> -interpolate 1 -vel_petscspace_order 2 -pres_petscspace_order 1
>>> >> -ksp_type
>>> >> fgmres -ksp_gmres_restart 100 -ksp_rtol 1.0e-9 -pc_type fieldsplit
>>> >> -pc_fieldsplit_type schur -pc_fieldsplit_schur_factorization_type upper
>>> >> -fieldsplit_pressure_ksp_rtol 1e-10 -fieldsplit_velocity_ksp_type gmres
>>> >> -fieldsplit_velocity_pc_type lu -fieldsplit_pressure_pc_type jacobi
>>> >> -snes_monitor_short -ksp_monitor_short -snes_converged_reason
>>> >> -ksp_converged_reason -snes_view -show_solution 0
>>> >> The reason that it works is that the DM calls PCFIeldSplitSetIS() for
>>> >> each
>>> >> field in the DM.
>>> >>   Thanks,
>>> >>     Matt
>>> >>> Thanks,
>>> >>> Hom Nath
>>> >>> On Tue, Feb 9, 2016 at 10:19 AM, Matthew Knepley <knepley at gmail.com>
>>> >>> wrote:
>>> >>> > On Tue, Feb 9, 2016 at 9:10 AM, Hom Nath Gharti
>>> >>> > wrote:
>>> >>> >> Thank you so much Barry!
>>> >>> >> For my small test case, with -pc_fieldsplit_block_size 4, the
>>> >>> >> program
>>> >>> >> runs, although the answer was not correct. At least now I get
>>> >>> >> something to look upon. I am using PCFieldSplitSetIS to set the
>>> >>> >> fields. Do I still need to use -pc_fieldsplit_block_size?
>>> >>> > No, this is only for co-located discretizations.
>>> >>> >> In my case each grid point may have different variable sets. For
>>> >>> >> example, the grid point in the solid region has displacement and
>>> >>> >> gravity potential: ux, uy, uz, and \phi. Whereas the grid point in
>>> >>> >> the
>>> >>> >> fluid region has scalar potential, pressure and gravity potential:
>>> >>> >> \chi, p, and \phi. And the solid-fluid interface has all of them.
>>> >>> >> Do
>>> >>> >> you think I can still use PCFIELDSPLIT in this situation?
>>> >>> > We have examples, like SNES ex62, which do exactly this.
>>> >>> >   Thanks,
>>> >>> >     Matt
>>> >>> >> Best,
>>> >>> >> Hom Nath
>>> >>> >> On Mon, Feb 8, 2016 at 2:27 PM, Barry Smith <bsmith at mcs.anl.gov>
>>> >>> >> wrote:
>>> >>> >> >    In this case you need to provide two pieces of information to
>>> >>> >> > the
>>> >>> >> > PCFIELDSPLIT. What we call the "block size" or bs which is the
>>> >>> >> > number
>>> >>> >> > of
>>> >>> >> > "basic fields" in the problem. For example if at each grid point
>>> >>> >> > you
>>> >>> >> > have
>>> >>> >> > x-velocity, y-velocity, and pressure the block size is 3. The
>>> >>> >> > second
>>> >>> >> > is you
>>> >>> >> > need to tell PCFIELDSPLIT what "basic fields" are in each split
>>> >>> >> > you
>>> >>> >> > want to
>>> >>> >> > use.
>>> >>> >> >    In your case you can do this with -pc_fieldsplit_block_size 4.
>>> >>> >> > (Note if you use a DM to define your problem the PCFIELDSPLIT
>>> >>> >> > will
>>> >>> >> > automatically get the bs from the DM so you do not need to
>>> >>> >> > provide
>>> >>> >> > it.
>>> >>> >> > Similarly if you set a block size on your Mat the PCFIELDSPLIT
>>> >>> >> > will
>>> >>> >> > use that
>>> >>> >> > so you don't need to set it).
>>> >>> >> >    Then use -pc_fieldsplit_0_fields 0,1 to indicate your first
>>> >>> >> > split
>>> >>> >> > is
>>> >>> >> > the 0 and 1 basic fields and -pc_fieldsplit_1_fields 2,3 to
>>> >>> >> > indicate
>>> >>> >> > the
>>> >>> >> > second split is the 2 and 3 basic fields.
>>> >>> >> > (By default if you do not provide this then PCFIELDSPLIT will use
>>> >>> >> > bs
>>> >>> >> > splits (4 in your case) one for each basic field.
>>> >>> >> >    Barry
>>> >>> >> >> On Feb 8, 2016, at 11:20 AM, Hom Nath Gharti
>>> >>> >> >> wrote:
>>> >>> >> >> Hi Matt, Hi all,
>>> >>> >> >> I am trying to have some feel for PCFIELDSPLIT testing on a very
>>> >>> >> >> small
>>> >>> >> >> matrix (attached below). I have 4 degrees of freedoms. I use 4
>>> >>> >> >> processors. I want to split 4 dofs into two fields each having
>>> >>> >> >> two
>>> >>> >> >> dofs. I don't know whether this my be a problem for petsc. When
>>> >>> >> >> I
>>> >>> >> >> use
>>> >>> >> >> the command:
>>> >>> >> >> srun -n 4 ./xtestfs -ksp_monitor -ksp_view
>>> >>> >> >> It runs fine.
>>> >>> >> >> But when I want to use field split options using the command:
>>> >>> >> >> srun -n 4 ./xtestfs -ksp_monitor -ksp_type fgmres -pc_type
>>> >>> >> >> fieldsplit
>>> >>> >> >> -fieldsplit_0_ksp_type gmres -fieldsplit_0_pc_type bjacobi
>>> >>> >> >> I get the following error message:
>>> >>> >> >> [0]PETSC ERROR: Petsc has generated inconsistent data
>>> >>> >> >> [0]PETSC ERROR: Unhandled case, must have at least two fields,
>>> >>> >> >> not 1
>>> >>> >> >> [0]PETSC ERROR: See
>>> >>> >> >> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>> >>> >> >> shooting.
>>> >>> >> >> [0]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
>>> >>> >> >> [0]PETSC ERROR: /tigress/hgharti/test/testfs/./xtestfs on a
>>> >>> >> >> arch-linux2-c-debug named tiger-r11n1 by hgharti Mon Feb  8
>>> >>> >> >> 11:40:03
>>> >>> >> >> 2016
>>> >>> >> >> [0]PETSC ERROR: Configure options
>>> >>> >> >> --with-blas-lapack-dir=/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64/
>>> >>> >> >> --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
>>> >>> >> >> --with-mpiexec=mpiexec --with-debugging=1 --download-scalapack
>>> >>> >> >> --download-mumps --download-pastix --download-superlu
>>> >>> >> >> --download-superlu_dist --download-metis --download-parmetis
>>> >>> >> >> --download-ptscotch --download-hypre
>>> >>> >> >> [0]PETSC ERROR: #1 PCFieldSplitSetDefaults() line 469 in
>>> >>> >> >> /home/hgharti/lsoft/petsc-3.6.3-intel16-mpi5/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>>> >>> >> >> [0]PETSC ERROR: #2 PCSetUp_FieldSplit() line 486 in
>>> >>> >> >> [0]PETSC ERROR: #3 PCSetUp() line 983 in
>>> >>> >> >> /home/hgharti/lsoft/petsc-3.6.3-intel16-mpi5/src/ksp/pc/interface/precon.c
>>> >>> >> >> [0]PETSC ERROR: #4 KSPSetUp() line 332 in
>>> >>> >> >> /home/hgharti/lsoft/petsc-3.6.3-intel16-mpi5/src/ksp/ksp/interface/itfunc.c
>>> >>> >> >> [0]PETSC ERROR: #5 KSPSolve() line 546 in
>>> >>> >> >> WARNING! There are options you set that were not used!
>>> >>> >> >> WARNING! could be spelling mistake, etc!
>>> >>> >> >> Option left: name:-fieldsplit_0_ksp_type value: gmres
>>> >>> >> >> Option left: name:-fieldsplit_0_pc_type value: bjacobi
>>> >>> >> >> Option left: name:-fieldsplit_1_pc_type value: jacobi
>>> >>> >> >> forrtl: error (76): Abort trap signal
>>> >>> >> >> I tried several trials but could not fix the problem. Is it the
>>> >>> >> >> FORTRAN problem or am I doing something wrong? Any suggestions
>>> >>> >> >> would
>>> >>> >> >> be greatly appreciated.
>>> >>> >> >> For your information I use:
>>> >>> >> >> PETSc-3.6.3
>>> >>> >> >> intel-16.0 compiler
>>> >>> >> >> intel-mpi-5.1.1
>>> >>> >> >> Program
>>> >>> >> >> Best,
>>> >>> >> >> Hom Nath
>>> >>> >> >> ! simple test case for PCFIELDSPLIT
>>> >>> >> >> program testfs
>>> >>> >> >> implicit none
>>> >>> >> >> #include "petsc/finclude/petscsys.h"
>>> >>> >> >> #include "petsc/finclude/petscvec.h"
>>> >>> >> >> #include "petsc/finclude/petscvec.h90"
>>> >>> >> >> #include "petsc/finclude/petscmat.h"
>>> >>> >> >> #include "petsc/finclude/petscksp.h"
>>> >>> >> >> #include "petsc/finclude/petscpc.h"
>>> >>> >> >> #include "petsc/finclude/petscviewer.h"
>>> >>> >> >> #include "petsc/finclude/petscviewer.h90"
>>> >>> >> >> Vec              x,b,u
>>> >>> >> >> Mat              A
>>> >>> >> >> KSP              ksp
>>> >>> >> >> PC               pc
>>> >>> >> >> PetscErrorCode   ierr
>>> >>> >> >> PetscBool        flg
>>> >>> >> >> PetscInt         errcode,its,maxitr,myrank,nproc
>>> >>> >> >> PetscInt         nedof,nelmt,ndof,nenod,ngdof,fixdof,nsparse,neq
>>> >>> >> >> PetscInt,allocatable  :: krow_sparse(:),ggdof_elmt(:,:),
>>> >>> >> >> inode_elmt(:,:)
>>> >>> >> >> PetscReal,allocatable :: storef(:,:),storekmat(:,:,:)
>>> >>> >> >> PetscInt gdof0(2),gdof1(2)
>>> >>> >> >> ! initialize MPI
>>> >>> >> >> call MPI_INIT(errcode)
>>> >>> >> >> if(errcode /= 0)stop 'ERROR: cannot initialize MPI!'
>>> >>> >> >> call MPI_COMM_RANK(MPI_COMM_WORLD,myrank,errcode)
>>> >>> >> >> if(errcode /= 0)stop 'ERROR: cannot find processor ID'
>>> >>> >> >> call MPI_COMM_SIZE(MPI_COMM_WORLD,nproc,errcode)
>>> >>> >> >> if(errcode /= 0)stop 'ERROR: cannot find number of processors!'
>>> >>> >> >> ! define some parameters
>>> >>> >> >> ! 1D model with 4 elements. Each elements consits of 2 nodes.
>>> >>> >> >> Node 0
>>> >>> >> >> is
>>> >>> >> >> fixed.
>>> >>> >> >> ! 1-----------2-----------3-----------4-----------5
>>> >>> >> >> nelmt=1 ! per processor
>>> >>> >> >> nenod=2 ! number of nodes per element
>>> >>> >> >> nedof=2 ! number of DOFs per element
>>> >>> >> >> ndof=2  ! number of DOFs
>>> >>> >> >> ngdof=4 ! total number of global DOFs
>>> >>> >> >> fixdof=1
>>> >>> >> >> if(myrank==0)then
>>> >>> >> >>  neq=1 ! number of equations
>>> >>> >> >>  nsparse=1
>>> >>> >> >> else
>>> >>> >> >>  neq=2 ! number of equations
>>> >>> >> >>  nsparse=4
>>> >>> >> >> endif
>>> >>> >> >> allocate(storef(nedof,nelmt),storekmat(nedof,nedof,nelmt),
>>> >>> >> >> ggdof_elmt(nedof,nelmt),inode_elmt(nenod,nelmt),krow_sparse(nsparse))
>>> >>> >> >> storef=0.0_8 ! local RHS vector
>>> >>> >> >> storekmat=0.0_8 ! local stiffness matrix
>>> >>> >> >> if(myrank==0)then
>>> >>> >> >>  krow_sparse(:)=1
>>> >>> >> >>  storef(:,1)=(/12.5000_8, 12.5000_8/)
>>> >>> >> >>  storekmat(:,:,1) = reshape((/1.2333333332_8, 0.0166666667_8, &
>>> >>> >> >>                               0.0166666667_8,
>>> >>> >> >> 1.2333333332_8/),(/nedof,nedof/))
>>> >>> >> >>  inode_elmt(:,1)  = (/1,2/)
>>> >>> >> >>  ggdof_elmt(:,1)  = (/0,1/) ! 0 because left node is fixed
>>> >>> >> >> elseif(myrank==1)then
>>> >>> >> >>  krow_sparse(:)=(/1,1,2,2/)
>>> >>> >> >>                               0.0166666667_8,
>>> >>> >> >>  ggdof_elmt(:,1)  = (/1,2/)
>>> >>> >> >> elseif(myrank==2)then
>>> >>> >> >>                               0.0166666667_8,
>>> >>> >> >>  ggdof_elmt(:,1)  = (/2,3/)
>>> >>> >> >> elseif(myrank==3)then
>>> >>> >> >>  storef(:,1)=(/12.5000_8, 22.5000_8/)
>>> >>> >> >>                               0.0166666667_8,
>>> >>> >> >>  ggdof_elmt(:,1)  = (/3,4/)
>>> >>> >> >> endif
>>> >>> >> >> call petsc_initialize
>>> >>> >> >> call petsc_set_matrix
>>> >>> >> >> call petsc_set_vector
>>> >>> >> >> call petsc_solve
>>> >>> >> >> call petsc_finalize
>>> >>> >> >> ! deallocate
>>> >>> >> >> deallocate(storef,storekmat,ggdof_elmt,inode_elmt)
>>> >>> >> >> deallocate(krow_sparse)
>>> >>> >> >> contains
>>> >>> >> >> subroutine petsc_initialize()
>>> >>> >> >> implicit none
>>> >>> >> >> PetscInt :: istart,iend
>>> >>> >> >> PetscInt :: nzeros_max,nzeros_min
>>> >>> >> >> PetscReal :: atol,dtol,rtol
>>> >>> >> >> PetscInt,allocatable :: nzeros(:)
>>> >>> >> >> IS gdof0_is,gdof1_is
>>> >>> >> >> call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
>>> >>> >> >> call
>>> >>> >> >> PetscOptionsGetInt(PETSC_NULL_CHARACTER,'-n',ngdof,flg,ierr)
>>> >>> >> >> ! count number of nonzeros per row
>>> >>> >> >> allocate(nzeros(neq))
>>> >>> >> >> nzeros=0
>>> >>> >> >> nzeros(krow_sparse)=nzeros(krow_sparse)+1
>>> >>> >> >> nzeros_max=maxval(nzeros)
>>> >>> >> >> nzeros_min=minval(nzeros)
>>> >>> >> >> ! create matrix
>>> >>> >> >> call MatCreate(PETSC_COMM_WORLD,A,ierr)
>>> >>> >> >> call MatSetType(A,MATMPIAIJ,ierr)
>>> >>> >> >> CHKERRQ(ierr)
>>> >>> >> >> call MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,ngdof,ngdof,ierr)
>>> >>> >> >> CHKERRQ(ierr)
>>> >>> >> >> ! preallocation
>>> >>> >> >> call
>>> >>> >> >> MatMPIAIJSetPreallocation(A,nzeros_max,PETSC_NULL_INTEGER,nzeros_max,     &
>>> >>> >> >> PETSC_NULL_INTEGER,ierr)
>>> >>> >> >> CHKERRQ(ierr)
>>> >>> >> >> call MatGetOwnershipRange(A,istart,iend,ierr)
>>> >>> >> >> CHKERRQ(ierr)
>>> >>> >> >> print*,'ownership:',myrank,istart,iend
>>> >>> >> >> ! create vector
>>> >>> >> >> call VecCreate(PETSC_COMM_WORLD,x,ierr)
>>> >>> >> >> call VecSetSizes(x,PETSC_DECIDE,ngdof,ierr)
>>> >>> >> >> call VecSetType(x,VECMPI,ierr)
>>> >>> >> >> call VecDuplicate(x,b,ierr)
>>> >>> >> >> call VecDuplicate(x,u,ierr)
>>> >>> >> >> ! get IS for split fields
>>> >>> >> >> gdof0=(/0,1/)
>>> >>> >> >> gdof1=(/2,3/)
>>> >>> >> >> call
>>> >>> >> >> ISCreateGeneral(PETSC_COMM_WORLD,2,gdof0,PETSC_COPY_VALUES,gdof0_is,ierr)
>>> >>> >> >> CHKERRQ(ierr)
>>> >>> >> >> call
>>> >>> >> >> ISCreateGeneral(PETSC_COMM_WORLD,2,gdof1,PETSC_COPY_VALUES,gdof1_is,ierr)
>>> >>> >> >> CHKERRQ(ierr)
>>> >>> >> >> ! Create linear solver context
>>> >>> >> >> call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
>>> >>> >> >> call KSPSetOperators(ksp,A,A,ierr)
>>> >>> >> >> call KSPGetPC(ksp,pc,ierr)
>>> >>> >> >> CHKERRQ(ierr)
>>> >>> >> >> ! split PC
>>> >>> >> >> call PCFieldSplitSetIS(pc,"0",gdof0_is,ierr);
>>> >>> >> >> CHKERRQ(ierr)
>>> >>> >> >> call ISDestroy(gdof0_is,ierr)
>>> >>> >> >> CHKERRQ(ierr)
>>> >>> >> >> call PCFieldSplitSetIS(pc,"1",gdof1_is,ierr);
>>> >>> >> >> CHKERRQ(ierr)
>>> >>> >> >> call ISDestroy(gdof1_is,ierr)
>>> >>> >> >> CHKERRQ(ierr)
>>> >>> >> >> rtol = 1.0d-6
>>> >>> >> >> atol = 1.0d-6
>>> >>> >> >> dtol = 1.0d10
>>> >>> >> >> maxitr = 1000
>>> >>> >> >> call KSPSetTolerances(ksp,rtol,atol,dtol,maxitr,ierr)
>>> >>> >> >> CHKERRQ(ierr)
>>> >>> >> >> call KSPSetFromOptions(ksp,ierr)
>>> >>> >> >> end subroutine petsc_initialize
>>> >>> >> >> subroutine petsc_set_matrix()
>>> >>> >> >> implicit none
>>> >>> >> >> integer :: i,i_elmt,j,ncount
>>> >>> >> >> integer :: ggdof(NEDOF),idof(NEDOF),igdof(NEDOF)
>>> >>> >> >> ! Set and assemble matrix.
>>> >>> >> >> call MatZeroEntries(A,ierr)
>>> >>> >> >> CHKERRQ(ierr)
>>> >>> >> >> do i_elmt=1,nelmt
>>> >>> >> >>  ggdof(:)=ggdof_elmt(:,i_elmt)
>>> >>> >> >>  ggdof(:)=ggdof(:)-1 ! petsc index starts from 0
>>> >>> >> >>  ncount=0; idof=-1; igdof=-1
>>> >>> >> >>  do i=1,NEDOF
>>> >>> >> >>    do j=1,NEDOF
>>> >>> >> >>    if(ggdof(i).ge.0.and.ggdof(j).ge.0)then
>>> >>> >> >>      call
>>> >>> >> >> MatSetValues(A,1,ggdof(i),1,ggdof(j),storekmat(i,j,i_elmt),
>>> >>> >> >>      ADD_VALUES,ierr)
>>> >>> >> >>      CHKERRQ(ierr)
>>> >>> >> >>    endif
>>> >>> >> >>    enddo
>>> >>> >> >>  enddo
>>> >>> >> >> enddo
>>> >>> >> >> call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
>>> >>> >> >> call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
>>> >>> >> >> if(myrank==0)print*,'matrix setting & assembly complete!'
>>> >>> >> >> end subroutine petsc_set_matrix
>>> >>> >> >> subroutine petsc_set_vector()
>>> >>> >> >> implicit none
>>> >>> >> >> PetscScalar      zero
>>> >>> >> >> integer :: i,i_elmt,ncount
>>> >>> >> >> ! set vector
>>> >>> >> >> zero=0.0_8
>>> >>> >> >> call VecSet(b,zero,ierr)
>>> >>> >> >> do i_elmt=1,nelmt
>>> >>> >> >>  do i=1,NEDOF
>>> >>> >> >>    if(ggdof(i).ge.0)then
>>> >>> >> >>      call
>>> >>> >> >> VecSetValues(b,1,ggdof(i),storef(i,i_elmt),ADD_VALUES,ierr);
>>> >>> >> >>      CHKERRQ(ierr)
>>> >>> >> >>    endif
>>> >>> >> >>  enddo
>>> >>> >> >> enddo
>>> >>> >> >> ! assemble vector
>>> >>> >> >> call VecAssemblyBegin(b,ierr)
>>> >>> >> >> call VecAssemblyEnd(b,ierr)
>>> >>> >> >> if(myrank==0)print*,'vector setting & assembly complete!'
>>> >>> >> >> end subroutine petsc_set_vector
>>> >>> >> >> subroutine petsc_solve()
>>> >>> >> >> implicit none
>>> >>> >> >> PetscInt ireason
>>> >>> >> >> PetscScalar a_v(1)
>>> >>> >> >> PetscOffset a_i
>>> >>> >> >> PetscInt n
>>> >>> >> >> PetscReal,allocatable :: sdata(:)
>>> >>> >> >> call VecGetSize(b,n,ierr)
>>> >>> >> >> CHKERRQ(ierr)
>>> >>> >> >> allocate(sdata(n))
>>> >>> >> >> sdata=0.0_8
>>> >>> >> >> call VecGetArray(b,a_v,a_i,ierr)
>>> >>> >> >> CHKERRQ(ierr)
>>> >>> >> >> sdata(1:n)=a_v(a_i+1:a_i+n)
>>> >>> >> >> call VecRestoreArray(b,a_v,a_i,ierr)
>>> >>> >> >> CHKERRQ(ierr)
>>> >>> >> >> print*,'rhs:',sdata
>>> >>> >> >> call KSPSolve(ksp,b,x,ierr)
>>> >>> >> >> sdata=0.0_8
>>> >>> >> >> call VecGetArray(x,a_v,a_i,ierr)
>>> >>> >> >> CHKERRQ(ierr)
>>> >>> >> >> CHKERRQ(ierr)
>>> >>> >> >> print*,'solution:',sdata
>>> >>> >> >> ! Check convergence
>>> >>> >> >> call KSPGetConvergedReason(ksp,ireason,ierr)
>>> >>> >> >> if(myrank==0)print*,'converges reason',myrank,ireason
>>> >>> >> >> call KSPGetIterationNumber(ksp,its,ierr)
>>> >>> >> >> if(myrank==0)print*,'Iterations:',its
>>> >>> >> >> deallocate(sdata)
>>> >>> >> >> end subroutine petsc_solve
>>> >>> >> >> subroutine petsc_finalize()
>>> >>> >> >> implicit none
>>> >>> >> >> ! Free work space.
>>> >>> >> >> call VecDestroy(x,ierr)
>>> >>> >> >> call VecDestroy(u,ierr)
>>> >>> >> >> call VecDestroy(b,ierr)
>>> >>> >> >> call MatDestroy(A,ierr)
>>> >>> >> >> call KSPDestroy(ksp,ierr)
>>> >>> >> >> call PetscFinalize(ierr)
>>> >>> >> >> CHKERRQ(ierr)
>>> >>> >> >> end subroutine petsc_finalize
>>> >>> >> >> end program testfs
>>> >>> >> >> On Tue, Feb 2, 2016 at 4:54 PM, Matthew Knepley
>>> >>> >> >> wrote:
>>> >>> >> >>> On Tue, Feb 2, 2016 at 3:11 PM, Hom Nath Gharti
>>> >>> >> >>> wrote:
>>> >>> >> >>>> Thanks a lot. I will try.
>>> >>> >> >>> Also, if you send a small test case, we can run it and tell you
>>> >>> >> >>> the
>>> >>> >> >>> problem.
>>> >>> >> >>>  Matt
>>> >>> >> >>>> Hom Nath
>>> >>> >> >>>> On Tue, Feb 2, 2016 at 4:02 PM, Matthew Knepley
>>> >>> >> >>>> wrote:
>>> >>> >> >>>>> On Tue, Feb 2, 2016 at 3:01 PM, Hom Nath Gharti
>>> >>> >> >>>>> wrote:
>>> >>> >> >>>>>> Thanks again Matt. Unfortunately got the same errors with
>>> >>> >> >>>>>> '0'. I
>>> >>> >> >>>>>> think
>>> >>> >> >>>>>> both are valid in Fortran.
>>> >>> >> >>>>> Then you will have to go in the debugger and see why its not
>>> >>> >> >>>>> creating 4
>>> >>> >> >>>>> splits, since this is exactly
>>> >>> >> >>>>> what it does in our tests. This is how all the SNES tests
>>> >>> >> >>>>> that I
>>> >>> >> >>>>> use
>>> >>> >> >>>>> work. I
>>> >>> >> >>>>> am sure its a Fortran
>>> >>> >> >>>>> problem.
>>> >>> >> >>>>>  Thanks,
>>> >>> >> >>>>>     Matt
>>> >>> >> >>>>>> Hom Nath
>>> >>> >> >>>>>> On Tue, Feb 2, 2016 at 3:42 PM, Matthew Knepley
>>> >>> >> >>>>>> wrote:
>>> >>> >> >>>>>>> On Tue, Feb 2, 2016 at 2:35 PM, Hom Nath Gharti
>>> >>> >> >>>>>>> wrote:
>>> >>> >> >>>>>>>> Thank you so much Matt.
>>> >>> >> >>>>>>>> I now tried the following:
>>> >>> >> >>>>>>>> call PCFieldSplitSetIS(pc,"0",gdofu_is,ierr);
>>> >>> >> >>>>>>>> call ISDestroy(gdofu_is,ierr)
>>> >>> >> >>>>>>>> call PCFieldSplitSetIS(pc,"1",gdofchi_is,ierr);
>>> >>> >> >>>>>>>> call ISDestroy(gdofchi_is,ierr)
>>> >>> >> >>>>>>>> call PCFieldSplitSetIS(pc,"2",gdofp_is,ierr);
>>> >>> >> >>>>>>>> call ISDestroy(gdofp_is,ierr)
>>> >>> >> >>>>>>>> call PCFieldSplitSetIS(pc,"3",gdofphi_is,ierr);
>>> >>> >> >>>>>>>> call ISDestroy(gdofphi_is,ierr)
>>> >>> >> >>>>>>>> ! Amat changes in each time steps
>>> >>> >> >>>>>>>> call KSPSetOperators(ksp,Amat,Amat,ierr) !version >= 3.5.0
>>> >>> >> >>>>>>>> call KSPSolve(ksp,bvec,xvec,ierr)
>>> >>> >> >>>>>>> I am guessing that "0" is not a valid string for your
>>> >>> >> >>>>>>> Fortran
>>> >>> >> >>>>>>> compiler.
>>> >>> >> >>>>>>> Are
>>> >>> >> >>>>>>> you sure
>>> >>> >> >>>>>>> its not single quotes '0'?
>>> >>> >> >>>>>>>  Matt
>>> >>> >> >>>>>>>> But I get the following error:
>>> >>> >> >>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>> >>> >> >>>>>>>> fields,
>>> >>> >> >>>>>>>> not 1
>>> >>> >> >>>>>>>> [0]PETSC ERROR: See
>>> >>> >> >>>>>>>> trouble
>>> >>> >> >>>>>>>> shooting.
>>> >>> >> >>>>>>>> [0]PETSC ERROR:
>>> >>> >> >>>>>>>> /tigress/hgharti/gitwork/SPECFEM3D_GLOBEVSPP/./bin/xspecfem3D
>>> >>> >> >>>>>>>> on
>>> >>> >> >>>>>>>> a
>>> >>> >> >>>>>>>> arch-linux2-c-debug named tiger-r3c1n7 by hgharti Tue Feb
>>> >>> >> >>>>>>>> 2
>>> >>> >> >>>>>>>> 15:
>>> >>> >> >>>>>>>> 29:30 2016
>>> >>> >> >>>>>>>> h-fc=mpif90 --with-mpiexec=mpiexec --with-debugging=1
>>> >>> >> >>>>>>>> --download-scalapack --download-mumps --download-pastix
>>> >>> >> >>>>>>>> --download-superlu --download-superlu_dist
>>> >>> >> >>>>>>>> --download-metis
>>> >>> >> >>>>>>>> --download-parmetis --download-ptscotch --download-hypre
>>> >>> >> >>>>>>>> Am I missing something?
>>> >>> >> >>>>>>>> Thanks,
>>> >>> >> >>>>>>>> Hom Nath
>>> >>> >> >>>>>>>> On Tue, Feb 2, 2016 at 3:24 PM, Matthew Knepley
>>> >>> >> >>>>>>>> wrote:
>>> >>> >> >>>>>>>>> On Tue, Feb 2, 2016 at 2:20 PM, Hom Nath Gharti
>>> >>> >> >>>>>>>>> wrote:
>>> >>> >> >>>>>>>>>> Hi Matt, hi all,
>>> >>> >> >>>>>>>>>> I am trying to use PCFIELDSPLIT for my solver which
>>> >>> >> >>>>>>>>>> consists
>>> >>> >> >>>>>>>>>> of
>>> >>> >> >>>>>>>>>> 4
>>> >>> >> >>>>>>>>>> different variables, namely, u (displacement vector),
>>> >>> >> >>>>>>>>>> \chi
>>> >>> >> >>>>>>>>>> (displacement potential), p(pressure), and \phi (gravity
>>> >>> >> >>>>>>>>>> potential).
>>> >>> >> >>>>>>>>>> My code segment looks like the following:
>>> >>> >> >>>>>>>>>> nsplit=4
>>> >>> >> >>>>>>>>>> call PCFieldSplitSetBlockSize(pc,nsplit,ierr);
>>> >>> >> >>>>>>>>> You do not need the statement above.
>>> >>> >> >>>>>>>>>> call PCFieldSplitGetSubKSP(pc,nsplit,subksp,ierr);
>>> >>> >> >>>>>>>>> These SetOperators() calls are wrong. I am not sure why
>>> >>> >> >>>>>>>>> you
>>> >>> >> >>>>>>>>> want
>>> >>> >> >>>>>>>>> them
>>> >>> >> >>>>>>>>> here.
>>> >>> >> >>>>>>>>> Also, that means you do not need the call above.
>>> >>> >> >>>>>>>>>  Thanks,
>>> >>> >> >>>>>>>>>     Matt
>>> >>> >> >>>>>>>>>> call KSPSetOperators(subksp(1),Amat,Amat,ierr);
>>> >>> >> >>>>>>>>>> call KSPSetOperators(subksp(2),Amat,Amat,ierr);
>>> >>> >> >>>>>>>>>> call KSPSetOperators(subksp(3),Amat,Amat,ierr);
>>> >>> >> >>>>>>>>>> call KSPSetOperators(subksp(4),Amat,Amat,ierr);
>>> >>> >> >>>>>>>>>> But I am getting the following error:
>>> >>> >> >>>>>>>>>> [79]PETSC ERROR: Null argument, when expecting valid
>>> >>> >> >>>>>>>>>> pointer
>>> >>> >> >>>>>>>>>> [79]PETSC ERROR: Null Object: Parameter # 1
>>> >>> >> >>>>>>>>>> [79]PETSC ERROR: #1 KSPSetOperators() line 536 in
>>> >>> >> >>>>>>>>>> It looks like I am doing something wrong in "call
>>> >>> >> >>>>>>>>>> KSPSetOperators"
>>> >>> >> >>>>>>>>>> but
>>> >>> >> >>>>>>>>>> I could not figure that out.
>>> >>> >> >>>>>>>>>> Could anybody help me to fix this problem? I looked into
>>> >>> >> >>>>>>>>>> almost
>>> >>> >> >>>>>>>>>> all
>>> >>> >> >>>>>>>>>> related examples but I could not really figure out the
>>> >>> >> >>>>>>>>>> correct
>>> >>> >> >>>>>>>>>> steps
>>> >>> >> >>>>>>>>>> after "call PCFieldSplitSetIS".
>>> >>> >> >>>>>>>>>> Any help will be greatly appreciated.
>>> >>> >> >>>>>>>>>> Best,
>>> >>> >> >>>>>>>>>> Hom nath
>>> >>> >> >>>>>>>>>> On Sun, Jan 24, 2016 at 7:14 PM, Hom Nath Gharti
>>> >>> >> >>>>>>>>>> wrote:
>>> >>> >> >>>>>>>>>>> Thank you so much Matt! I will try.
>>> >>> >> >>>>>>>>>>> Hom Nath
>>> >>> >> >>>>>>>>>>> On Sun, Jan 24, 2016 at 6:26 AM, Matthew Knepley
>>> >>> >> >>>>>>>>>>> wrote:
>>> >>> >> >>>>>>>>>>>> On Fri, Jan 22, 2016 at 2:19 PM, Hom Nath Gharti
>>> >>> >> >>>>>>>>>>>> wrote:
>>> >>> >> >>>>>>>>>>>>> Dear all,
>>> >>> >> >>>>>>>>>>>>> I am new to PcFieldSplit.
>>> >>> >> >>>>>>>>>>>>> I have a matrix formed using MATMPIAIJ. Is it
>>> >>> >> >>>>>>>>>>>>> possible to
>>> >>> >> >>>>>>>>>>>>> use
>>> >>> >> >>>>>>>>>>>>> PCFIELDSPLIT operations in this type of matrix? Or
>>> >>> >> >>>>>>>>>>>>> does
>>> >>> >> >>>>>>>>>>>>> it
>>> >>> >> >>>>>>>>>>>>> have
>>> >>> >> >>>>>>>>>>>>> to
>>> >>> >> >>>>>>>>>>>>> be
>>> >>> >> >>>>>>>>>>>>> MATMPIBIJ or MATNEST format?
>>> >>> >> >>>>>>>>>>>> Yes, you can split AIJ.
>>> >>> >> >>>>>>>>>>>>> If possible for MATMPIAIJ, could anybody provide me a
>>> >>> >> >>>>>>>>>>>>> simple
>>> >>> >> >>>>>>>>>>>>> example
>>> >>> >> >>>>>>>>>>>>> or few steps? Variables in the equations are
>>> >>> >> >>>>>>>>>>>>> displacement
>>> >>> >> >>>>>>>>>>>>> vector,
>>> >>> >> >>>>>>>>>>>>> scalar potential and pressure.
>>> >>> >> >>>>>>>>>>>> If you do not have a collocated discretization, then
>>> >>> >> >>>>>>>>>>>> you
>>> >>> >> >>>>>>>>>>>> have
>>> >>> >> >>>>>>>>>>>> to
>>> >>> >> >>>>>>>>>>>> use
>>> >>> >> >>>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetIS.html
>>> >>> >> >>>>>>>>>>>>  Thanks,
>>> >>> >> >>>>>>>>>>>>     Matt
>>> >>> >> >>>>>>>>>>>>> Thanks for help.
>>> >>> >> >>>>>>>>>>>>> Hom Nath
>>> >>> >> >>>>>>>>>>>> What most experimenters take for granted before they
>>> >>> >> >>>>>>>>>>>> begin
>>> >>> >> >>>>>>>>>>>> their
>>> >>> >> >>>>>>>>>>>> experiments
>>> >>> >> >>>>>>>>>>>> is infinitely more interesting than any results to
>>> >>> >> >>>>>>>>>>>> which
>>> >>> >> >>>>>>>>>>>> their
>>> >>> >> >>>>>>>>>>>> experiments
>>> >>> >> >>>>>>>>>>>> lead.
>>> >>> >> >>>>>>>>>>>> -- Norbert Wiener
>>> >>> >> >>>>>>>>> begin
>>> >>> >> >>>>>>>>> their
>>> >>> >> >>>>>>>>> experiments
>>> >>> >> >>>>>>>>> is infinitely more interesting than any results to which
>>> >>> >> >>>>>>>>> their
>>> >>> >> >>>>>>>>> experiments
>>> >>> >> >>>>>>>>> lead.
>>> >>> >> >>>>>>>>> -- Norbert Wiener
>>> >>> >> >>>>>>> What most experimenters take for granted before they begin
>>> >>> >> >>>>>>> their
>>> >>> >> >>>>>>> experiments
>>> >>> >> >>>>>>> their
>>> >>> >> >>>>>>> experiments
>>> >>> >> >>>>>>> lead.
>>> >>> >> >>>>>>> -- Norbert Wiener
>>> >>> >> >>>>> their
>>> >>> >> >>>>> experiments
>>> >>> >> >>>>> their
>>> >>> >> >>>>> experiments
>>> >>> >> >>>>> lead.
>>> >>> >> >>>>> -- Norbert Wiener
>>> >>> >> >>> their
>>> >>> >> >>> experiments
>>> >>> >> >>> is infinitely more interesting than any results to which their
>>> >>> >> >>> experiments
>>> >>> >> >>> lead.
>>> >>> >> >>> -- Norbert Wiener
>>> >>> > What most experimenters take for granted before they begin their
>>> >>> > experiments
>>> >>> > experiments
>>> >>> > lead.
>>> >>> > -- Norbert Wiener
>>> >> experiments
>>> >> experiments
>>> >> lead.
>>> >> -- Norbert Wiener
>> What most experimenters take for granted before they begin their experiments
>> is infinitely more interesting than any results to which their experiments
>> lead.
>> -- Norbert Wiener
