[petsc-users] Doubt related to MatSetValues()
Sat Feb 13 09:44:02 CST 2016
On Sat, Feb 13, 2016 at 2:19 AM, Kaushik Kulkarni <kaushikggg at gmail.com>
wrote:
> After preallocating a matrix do I have to change the way in which I have
> to use the function MatSetValues(). The reason I am asking this is that
> when I am executing the code with the line "
> *MatMPIAIJSetPreallocation(A,dnz,PETSC_NULL,0,PETSC_NULL);*" in which dnz
> is computed for each row and all the off diagonal terms are zero I am
> getting an error:
> *[0]PETSC ERROR:Argument out of range[0]PETSC ERROR: New nonzero at (0,4)
> caused a malloc*"
It sounds like (0,4) is an off-diagonal.
   Matt
> But when I am commenting the line corresponding to the Preallocation, the
> code is running fine.
> Thank you,
> *Kaushik*
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160213/9b31c8a8/attachment.html>
