[petsc-users] PCFIELDSPLIT question
Hom Nath Gharti hng.email at gmail.com
Mon Feb 8 11:20:08 CST 2016
Hi Matt, Hi all,
I am trying to have some feel for PCFIELDSPLIT testing on a very small
matrix (attached below). I have 4 degrees of freedoms. I use 4
processors. I want to split 4 dofs into two fields each having two
dofs. I don't know whether this my be a problem for petsc. When I use
the command:
srun -n 4 ./xtestfs -ksp_monitor -ksp_view
It runs fine.
But when I want to use field split options using the command:
srun -n 4 ./xtestfs -ksp_monitor -ksp_type fgmres -pc_type fieldsplit
-fieldsplit_0_ksp_type gmres -fieldsplit_0_pc_type bjacobi
-fieldsplit_1_pc_type jacobi
I get the following error message:
[0]PETSC ERROR: Petsc has generated inconsistent data
[0]PETSC ERROR: Unhandled case, must have at least two fields, not 1
[0]PETSC ERROR: See
http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
shooting.
[0]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
[0]PETSC ERROR: /tigress/hgharti/test/testfs/./xtestfs on a
arch-linux2-c-debug named tiger-r11n1 by hgharti Mon Feb  8 11:40:03
[0]PETSC ERROR: Configure options
--with-blas-lapack-dir=/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64/
--with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
--with-mpiexec=mpiexec --with-debugging=1 --download-scalapack
--download-mumps --download-pastix --download-superlu
--download-superlu_dist --download-metis --download-parmetis
--download-ptscotch --download-hypre
[0]PETSC ERROR: #1 PCFieldSplitSetDefaults() line 469 in
/home/hgharti/lsoft/petsc-3.6.3-intel16-mpi5/src/ksp/pc/impls/fieldsplit/fieldsplit.c
[0]PETSC ERROR: #2 PCSetUp_FieldSplit() line 486 in
[0]PETSC ERROR: #3 PCSetUp() line 983 in
/home/hgharti/lsoft/petsc-3.6.3-intel16-mpi5/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #4 KSPSetUp() line 332 in
/home/hgharti/lsoft/petsc-3.6.3-intel16-mpi5/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #5 KSPSolve() line 546 in
WARNING! There are options you set that were not used!
WARNING! could be spelling mistake, etc!
Option left: name:-fieldsplit_0_ksp_type value: gmres
Option left: name:-fieldsplit_0_pc_type value: bjacobi
Option left: name:-fieldsplit_1_pc_type value: jacobi
forrtl: error (76): Abort trap signal
I tried several trials but could not fix the problem. Is it the
FORTRAN problem or am I doing something wrong? Any suggestions would
be greatly appreciated.
For your information I use:
PETSc-3.6.3
intel-16.0 compiler
intel-mpi-5.1.1
Program
Best,
Hom Nath
! simple test case for PCFIELDSPLIT
program testfs
implicit none
#include "petsc/finclude/petscsys.h"
#include "petsc/finclude/petscvec.h"
#include "petsc/finclude/petscvec.h90"
#include "petsc/finclude/petscmat.h"
#include "petsc/finclude/petscksp.h"
#include "petsc/finclude/petscpc.h"
#include "petsc/finclude/petscviewer.h"
#include "petsc/finclude/petscviewer.h90"
Vec              x,b,u
Mat              A
KSP              ksp
PC               pc
PetscErrorCode   ierr
PetscBool        flg
PetscInt         errcode,its,maxitr,myrank,nproc
PetscInt         nedof,nelmt,ndof,nenod,ngdof,fixdof,nsparse,neq
PetscInt,allocatable  :: krow_sparse(:),ggdof_elmt(:,:),           &
inode_elmt(:,:)
PetscReal,allocatable :: storef(:,:),storekmat(:,:,:)
PetscInt gdof0(2),gdof1(2)
! initialize MPI
call MPI_INIT(errcode)
if(errcode /= 0)stop 'ERROR: cannot initialize MPI!'
call MPI_COMM_RANK(MPI_COMM_WORLD,myrank,errcode)
if(errcode /= 0)stop 'ERROR: cannot find processor ID'
call MPI_COMM_SIZE(MPI_COMM_WORLD,nproc,errcode)
if(errcode /= 0)stop 'ERROR: cannot find number of processors!'
! define some parameters
! 1D model with 4 elements. Each elements consits of 2 nodes. Node 0 is fixed.
! 1-----------2-----------3-----------4-----------5
nelmt=1 ! per processor
nenod=2 ! number of nodes per element
nedof=2 ! number of DOFs per element
ndof=2  ! number of DOFs
ngdof=4 ! total number of global DOFs
fixdof=1
if(myrank==0)then
  neq=1 ! number of equations
  nsparse=1
else
  neq=2 ! number of equations
  nsparse=4
endif
allocate(storef(nedof,nelmt),storekmat(nedof,nedof,nelmt),                     &
ggdof_elmt(nedof,nelmt),inode_elmt(nenod,nelmt),krow_sparse(nsparse))
storef=0.0_8 ! local RHS vector
storekmat=0.0_8 ! local stiffness matrix
if(myrank==0)then
  krow_sparse(:)=1
  storef(:,1)=(/12.5000_8, 12.5000_8/)
  storekmat(:,:,1) = reshape((/1.2333333332_8, 0.0166666667_8, &
                               0.0166666667_8, 1.2333333332_8/),(/nedof,nedof/))
  inode_elmt(:,1)  = (/1,2/)
  ggdof_elmt(:,1)  = (/0,1/) ! 0 because left node is fixed
elseif(myrank==1)then
  krow_sparse(:)=(/1,1,2,2/)
  ggdof_elmt(:,1)  = (/1,2/)
elseif(myrank==2)then
  ggdof_elmt(:,1)  = (/2,3/)
elseif(myrank==3)then
  storef(:,1)=(/12.5000_8, 22.5000_8/)
  ggdof_elmt(:,1)  = (/3,4/)
endif
call petsc_initialize
call petsc_set_matrix
call petsc_set_vector
call petsc_solve
call petsc_finalize
! deallocate
deallocate(storef,storekmat,ggdof_elmt,inode_elmt)
deallocate(krow_sparse)
contains
subroutine petsc_initialize()
implicit none
PetscInt :: istart,iend
PetscInt :: nzeros_max,nzeros_min
PetscReal :: atol,dtol,rtol
PetscInt,allocatable :: nzeros(:)
IS gdof0_is,gdof1_is
call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
call PetscOptionsGetInt(PETSC_NULL_CHARACTER,'-n',ngdof,flg,ierr)
! count number of nonzeros per row
allocate(nzeros(neq))
nzeros=0
nzeros(krow_sparse)=nzeros(krow_sparse)+1
nzeros_max=maxval(nzeros)
nzeros_min=minval(nzeros)
! create matrix
call MatCreate(PETSC_COMM_WORLD,A,ierr)
call MatSetType(A,MATMPIAIJ,ierr)
CHKERRQ(ierr)
call MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,ngdof,ngdof,ierr)
CHKERRQ(ierr)
! preallocation
call MatMPIAIJSetPreallocation(A,nzeros_max,PETSC_NULL_INTEGER,nzeros_max,     &
PETSC_NULL_INTEGER,ierr)
CHKERRQ(ierr)
call MatGetOwnershipRange(A,istart,iend,ierr)
CHKERRQ(ierr)
print*,'ownership:',myrank,istart,iend
! create vector
call VecCreate(PETSC_COMM_WORLD,x,ierr)
call VecSetSizes(x,PETSC_DECIDE,ngdof,ierr)
call VecSetType(x,VECMPI,ierr)
call VecDuplicate(x,b,ierr)
call VecDuplicate(x,u,ierr)
! get IS for split fields
gdof0=(/0,1/)
gdof1=(/2,3/)
call ISCreateGeneral(PETSC_COMM_WORLD,2,gdof0,PETSC_COPY_VALUES,gdof0_is,ierr)
CHKERRQ(ierr)
call ISCreateGeneral(PETSC_COMM_WORLD,2,gdof1,PETSC_COPY_VALUES,gdof1_is,ierr)
CHKERRQ(ierr)
! Create linear solver context
call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
call KSPSetOperators(ksp,A,A,ierr)
call KSPGetPC(ksp,pc,ierr)
CHKERRQ(ierr)
! split PC
call PCFieldSplitSetIS(pc,"0",gdof0_is,ierr);
CHKERRQ(ierr)
call ISDestroy(gdof0_is,ierr)
CHKERRQ(ierr)
call PCFieldSplitSetIS(pc,"1",gdof1_is,ierr);
CHKERRQ(ierr)
call ISDestroy(gdof1_is,ierr)
CHKERRQ(ierr)
rtol = 1.0d-6
atol = 1.0d-6
dtol = 1.0d10
maxitr = 1000
call KSPSetTolerances(ksp,rtol,atol,dtol,maxitr,ierr)
CHKERRQ(ierr)
call KSPSetFromOptions(ksp,ierr)
end subroutine petsc_initialize
subroutine petsc_set_matrix()
implicit none
integer :: i,i_elmt,j,ncount
integer :: ggdof(NEDOF),idof(NEDOF),igdof(NEDOF)
! Set and assemble matrix.
call MatZeroEntries(A,ierr)
CHKERRQ(ierr)
do i_elmt=1,nelmt
  ggdof(:)=ggdof_elmt(:,i_elmt)
  ggdof(:)=ggdof(:)-1 ! petsc index starts from 0
  ncount=0; idof=-1; igdof=-1
  do i=1,NEDOF
    do j=1,NEDOF
    if(ggdof(i).ge.0.and.ggdof(j).ge.0)then
      call MatSetValues(A,1,ggdof(i),1,ggdof(j),storekmat(i,j,i_elmt),
      ADD_VALUES,ierr)
      CHKERRQ(ierr)
    endif
    enddo
  enddo
enddo
call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
if(myrank==0)print*,'matrix setting & assembly complete!'
end subroutine petsc_set_matrix
subroutine petsc_set_vector()
implicit none
PetscScalar      zero
integer :: i,i_elmt,ncount
! set vector
zero=0.0_8
call VecSet(b,zero,ierr)
do i_elmt=1,nelmt
  do i=1,NEDOF
    if(ggdof(i).ge.0)then
      call VecSetValues(b,1,ggdof(i),storef(i,i_elmt),ADD_VALUES,ierr);
      CHKERRQ(ierr)
    endif
  enddo
enddo
! assemble vector
call VecAssemblyBegin(b,ierr)
call VecAssemblyEnd(b,ierr)
if(myrank==0)print*,'vector setting & assembly complete!'
end subroutine petsc_set_vector
subroutine petsc_solve()
implicit none
PetscInt ireason
PetscScalar a_v(1)
PetscOffset a_i
PetscInt n
PetscReal,allocatable :: sdata(:)
call VecGetSize(b,n,ierr)
CHKERRQ(ierr)
allocate(sdata(n))
sdata=0.0_8
call VecGetArray(b,a_v,a_i,ierr)
CHKERRQ(ierr)
sdata(1:n)=a_v(a_i+1:a_i+n)
call VecRestoreArray(b,a_v,a_i,ierr)
CHKERRQ(ierr)
print*,'rhs:',sdata
call KSPSolve(ksp,b,x,ierr)
sdata=0.0_8
call VecGetArray(x,a_v,a_i,ierr)
CHKERRQ(ierr)
CHKERRQ(ierr)
print*,'solution:',sdata
! Check convergence
call KSPGetConvergedReason(ksp,ireason,ierr)
if(myrank==0)print*,'converges reason',myrank,ireason
call KSPGetIterationNumber(ksp,its,ierr)
if(myrank==0)print*,'Iterations:',its
deallocate(sdata)
end subroutine petsc_solve
subroutine petsc_finalize()
implicit none
! Free work space.
call VecDestroy(x,ierr)
call VecDestroy(u,ierr)
call VecDestroy(b,ierr)
call MatDestroy(A,ierr)
call KSPDestroy(ksp,ierr)
call PetscFinalize(ierr)
CHKERRQ(ierr)
end subroutine petsc_finalize
end program testfs
On Tue, Feb 2, 2016 at 4:54 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Feb 2, 2016 at 3:11 PM, Hom Nath Gharti <hng.email at gmail.com> wrote:
>> Thanks a lot. I will try.
> Also, if you send a small test case, we can run it and tell you the problem.
>   Matt
>> Hom Nath
>> On Tue, Feb 2, 2016 at 4:02 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> > On Tue, Feb 2, 2016 at 3:01 PM, Hom Nath Gharti <hng.email at gmail.com>
>> > wrote:
>> >> Thanks again Matt. Unfortunately got the same errors with '0'. I think
>> >> both are valid in Fortran.
>> > Then you will have to go in the debugger and see why its not creating 4
>> > splits, since this is exactly
>> > what it does in our tests. This is how all the SNES tests that I use
>> > work. I
>> > am sure its a Fortran
>> > problem.
>> >   Thanks,
>> >      Matt
>> >> Hom Nath
>> >> On Tue, Feb 2, 2016 at 3:42 PM, Matthew Knepley <knepley at gmail.com>
>> >> wrote:
>> >> > On Tue, Feb 2, 2016 at 2:35 PM, Hom Nath Gharti <hng.email at gmail.com>
>> >> > wrote:
>> >> >> Thank you so much Matt.
>> >> >> I now tried the following:
>> >> >> call PCFieldSplitSetIS(pc,"0",gdofu_is,ierr);
>> >> >> call ISDestroy(gdofu_is,ierr)
>> >> >> call PCFieldSplitSetIS(pc,"1",gdofchi_is,ierr);
>> >> >> call ISDestroy(gdofchi_is,ierr)
>> >> >> call PCFieldSplitSetIS(pc,"2",gdofp_is,ierr);
>> >> >> call ISDestroy(gdofp_is,ierr)
>> >> >> call PCFieldSplitSetIS(pc,"3",gdofphi_is,ierr);
>> >> >> call ISDestroy(gdofphi_is,ierr)
>> >> >> ! Amat changes in each time steps
>> >> >> call KSPSetOperators(ksp,Amat,Amat,ierr) !version >= 3.5.0
>> >> >> call KSPSolve(ksp,bvec,xvec,ierr)
>> >> > I am guessing that "0" is not a valid string for your Fortran
>> >> > compiler.
>> >> > Are
>> >> > you sure
>> >> > its not single quotes '0'?
>> >> >   Matt
>> >> >> But I get the following error:
>> >> >> [0]PETSC ERROR: --------------------- Error Message
>> >> >> [0]PETSC ERROR: See
>> >> >> shooting.
>> >> >> [0]PETSC ERROR:
>> >> >> /tigress/hgharti/gitwork/SPECFEM3D_GLOBEVSPP/./bin/xspecfem3D on a
>> >> >> arch-linux2-c-debug named tiger-r3c1n7 by hgharti Tue Feb  2 15:
>> >> >> 29:30 2016
>> >> >> h-fc=mpif90 --with-mpiexec=mpiexec --with-debugging=1
>> >> >> --download-scalapack --download-mumps --download-pastix
>> >> >> --download-superlu --download-superlu_dist --download-metis
>> >> >> --download-parmetis --download-ptscotch --download-hypre
>> >> >> Am I missing something?
>> >> >> Thanks,
>> >> >> Hom Nath
>> >> >> On Tue, Feb 2, 2016 at 3:24 PM, Matthew Knepley <knepley at gmail.com>
>> >> >> wrote:
>> >> >> > On Tue, Feb 2, 2016 at 2:20 PM, Hom Nath Gharti
>> >> >> > wrote:
>> >> >> >> Hi Matt, hi all,
>> >> >> >> I am trying to use PCFIELDSPLIT for my solver which consists of 4
>> >> >> >> different variables, namely, u (displacement vector), \chi
>> >> >> >> (displacement potential), p(pressure), and \phi (gravity
>> >> >> >> potential).
>> >> >> >> My code segment looks like the following:
>> >> >> >> nsplit=4
>> >> >> >> call PCFieldSplitSetBlockSize(pc,nsplit,ierr);
>> >> >> > You do not need the statement above.
>> >> >> >> call PCFieldSplitGetSubKSP(pc,nsplit,subksp,ierr);
>> >> >> > These SetOperators() calls are wrong. I am not sure why you want
>> >> >> > them
>> >> >> > here.
>> >> >> > Also, that means you do not need the call above.
>> >> >> >   Thanks,
>> >> >> >      Matt
>> >> >> >> call KSPSetOperators(subksp(1),Amat,Amat,ierr);
>> >> >> >> call KSPSetOperators(subksp(2),Amat,Amat,ierr);
>> >> >> >> call KSPSetOperators(subksp(3),Amat,Amat,ierr);
>> >> >> >> call KSPSetOperators(subksp(4),Amat,Amat,ierr);
>> >> >> >> But I am getting the following error:
>> >> >> >> [79]PETSC ERROR: Null argument, when expecting valid pointer
>> >> >> >> [79]PETSC ERROR: Null Object: Parameter # 1
>> >> >> >> [79]PETSC ERROR: #1 KSPSetOperators() line 536 in
>> >> >> >> It looks like I am doing something wrong in "call
>> >> >> >> KSPSetOperators"
>> >> >> >> but
>> >> >> >> I could not figure that out.
>> >> >> >> Could anybody help me to fix this problem? I looked into almost
>> >> >> >> all
>> >> >> >> related examples but I could not really figure out the correct
>> >> >> >> steps
>> >> >> >> after "call PCFieldSplitSetIS".
>> >> >> >> Any help will be greatly appreciated.
>> >> >> >> Best,
>> >> >> >> Hom nath
>> >> >> >> On Sun, Jan 24, 2016 at 7:14 PM, Hom Nath Gharti
>> >> >> >> wrote:
>> >> >> >> > Thank you so much Matt! I will try.
>> >> >> >> > Hom Nath
>> >> >> >> > On Sun, Jan 24, 2016 at 6:26 AM, Matthew Knepley
>> >> >> >> > wrote:
>> >> >> >> >> On Fri, Jan 22, 2016 at 2:19 PM, Hom Nath Gharti
>> >> >> >> >> wrote:
>> >> >> >> >>> Dear all,
>> >> >> >> >>> I am new to PcFieldSplit.
>> >> >> >> >>> I have a matrix formed using MATMPIAIJ. Is it possible to use
>> >> >> >> >>> PCFIELDSPLIT operations in this type of matrix? Or does it
>> >> >> >> >>> have
>> >> >> >> >>> to
>> >> >> >> >>> be
>> >> >> >> >>> MATMPIBIJ or MATNEST format?
>> >> >> >> >> Yes, you can split AIJ.
>> >> >> >> >>> If possible for MATMPIAIJ, could anybody provide me a simple
>> >> >> >> >>> example
>> >> >> >> >>> or few steps? Variables in the equations are displacement
>> >> >> >> >>> vector,
>> >> >> >> >>> scalar potential and pressure.
>> >> >> >> >> If you do not have a collocated discretization, then you have
>> >> >> >> >> to
>> >> >> >> >> use
>> >> >> >> >> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetIS.html
>> >> >> >> >>   Thanks,
>> >> >> >> >>      Matt
>> >> >> >> >>> Thanks for help.
>> >> >> >> >>> Hom Nath
>> >> >> >> >> What most experimenters take for granted before they begin
>> >> >> >> >> their
>> >> >> >> >> experiments
>> >> >> >> >> is infinitely more interesting than any results to which their
>> >> >> >> >> experiments
>> >> >> >> >> lead.
>> >> >> >> >> -- Norbert Wiener
>> >> >> > What most experimenters take for granted before they begin their
>> >> >> > experiments
>> >> >> > experiments
>> >> >> > lead.
>> >> >> > -- Norbert Wiener
>> >> > experiments
>> >> > experiments
>> >> > lead.
>> >> > -- Norbert Wiener
>> > experiments
>> > experiments
>> > lead.
>> > -- Norbert Wiener
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
