[petsc-users] PCFIELDSPLIT question
Tue Feb 2 15:54:31 CST 2016
On Tue, Feb 2, 2016 at 3:11 PM, Hom Nath Gharti <hng.email at gmail.com> wrote:
> Thanks a lot. I will try.
Also, if you send a small test case, we can run it and tell you the problem.
  Matt
> Hom Nath
> On Tue, Feb 2, 2016 at 4:02 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Tue, Feb 2, 2016 at 3:01 PM, Hom Nath Gharti <hng.email at gmail.com>
> wrote:
> >> Thanks again Matt. Unfortunately got the same errors with '0'. I think
> >> both are valid in Fortran.
> > Then you will have to go in the debugger and see why its not creating 4
> > splits, since this is exactly
> > what it does in our tests. This is how all the SNES tests that I use
> work. I
> > am sure its a Fortran
> > problem.
> >   Thanks,
> >      Matt
> >> Hom Nath
> >> On Tue, Feb 2, 2016 at 3:42 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> >> > On Tue, Feb 2, 2016 at 2:35 PM, Hom Nath Gharti <hng.email at gmail.com>
> >> > wrote:
> >> >> Thank you so much Matt.
> >> >> I now tried the following:
> >> >> call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
> >> >> call KSPGetPC(ksp,pc,ierr)
> >> >> call PCFieldSplitSetIS(pc,"0",gdofu_is,ierr);
> >> >> call ISDestroy(gdofu_is,ierr)
> >> >> call PCFieldSplitSetIS(pc,"1",gdofchi_is,ierr);
> >> >> call ISDestroy(gdofchi_is,ierr)
> >> >> call PCFieldSplitSetIS(pc,"2",gdofp_is,ierr);
> >> >> call ISDestroy(gdofp_is,ierr)
> >> >> call PCFieldSplitSetIS(pc,"3",gdofphi_is,ierr);
> >> >> call ISDestroy(gdofphi_is,ierr)
> >> >> ! Amat changes in each time steps
> >> >> call KSPSetOperators(ksp,Amat,Amat,ierr) !version >= 3.5.0
> >> >> call KSPSolve(ksp,bvec,xvec,ierr)
> >> > I am guessing that "0" is not a valid string for your Fortran
> compiler.
> >> > Are
> >> > you sure
> >> > its not single quotes '0'?
> >> >   Matt
> >> >> But I get the following error:
> >> >> [0]PETSC ERROR: --------------------- Error Message
> >> >> [0]PETSC ERROR: Petsc has generated inconsistent data
> >> >> [0]PETSC ERROR: Unhandled case, must have at least two fields, not 1
> >> >> [0]PETSC ERROR: See
> >> >> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
> >> >> shooting.
> >> >> [0]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
> >> >> [0]PETSC ERROR:
> >> >> /tigress/hgharti/gitwork/SPECFEM3D_GLOBEVSPP/./bin/xspecfem3D on a
> >> >> arch-linux2-c-debug named tiger-r3c1n7 by hgharti Tue Feb  2 15:
> >> >> 29:30 2016
> >> >> [0]PETSC ERROR: Configure options
> --with-blas-lapack-dir=/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64/
> >> >> --with-cc=mpicc --with-cxx=mpicxx --wit
> >> >> h-fc=mpif90 --with-mpiexec=mpiexec --with-debugging=1
> >> >> --download-scalapack --download-mumps --download-pastix
> >> >> --download-superlu --download-superlu_dist --download-metis
> >> >> --download-parmetis --download-ptscotch --download-hypre
> >> >> [0]PETSC ERROR: #1 PCFieldSplitSetDefaults() line 469 in
> /home/hgharti/lsoft/petsc-3.6.3-intel16-mpi5/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> >> >> [0]PETSC ERROR: #2 PCSetUp_FieldSplit() line 486 in
> >> >> [0]PETSC ERROR: #3 PCSetUp() line 983 in
> /home/hgharti/lsoft/petsc-3.6.3-intel16-mpi5/src/ksp/pc/interface/precon.c
> >> >> [0]PETSC ERROR: #4 KSPSetUp() line 332 in
> /home/hgharti/lsoft/petsc-3.6.3-intel16-mpi5/src/ksp/ksp/interface/itfunc.c
> >> >> [0]PETSC ERROR: #5 KSPSolve() line 546 in
> >> >> forrtl: error (76): Abort trap signal
> >> >> Am I missing something?
> >> >> Thanks,
> >> >> Hom Nath
> >> >> On Tue, Feb 2, 2016 at 3:24 PM, Matthew Knepley <knepley at gmail.com>
> >> >> wrote:
> >> >> > On Tue, Feb 2, 2016 at 2:20 PM, Hom Nath Gharti <
> >> >> > wrote:
> >> >> >> Hi Matt, hi all,
> >> >> >> I am trying to use PCFIELDSPLIT for my solver which consists of 4
> >> >> >> different variables, namely, u (displacement vector), \chi
> >> >> >> (displacement potential), p(pressure), and \phi (gravity
> potential).
> >> >> >> My code segment looks like the following:
> >> >> >> nsplit=4
> >> >> >> call PCFieldSplitSetBlockSize(pc,nsplit,ierr);
> >> >> > You do not need the statement above.
> >> >> >> call PCFieldSplitGetSubKSP(pc,nsplit,subksp,ierr);
> >> >> > These SetOperators() calls are wrong. I am not sure why you want
> them
> >> >> > here.
> >> >> > Also, that means you do not need the call above.
> >> >> >   Thanks,
> >> >> >      Matt
> >> >> >> call KSPSetOperators(subksp(1),Amat,Amat,ierr);
> >> >> >> call KSPSetOperators(subksp(2),Amat,Amat,ierr);
> >> >> >> call KSPSetOperators(subksp(3),Amat,Amat,ierr);
> >> >> >> call KSPSetOperators(subksp(4),Amat,Amat,ierr);
> >> >> >> But I am getting the following error:
> >> >> >> [79]PETSC ERROR: Null argument, when expecting valid pointer
> >> >> >> [79]PETSC ERROR: Null Object: Parameter # 1
> >> >> >> [79]PETSC ERROR: #1 KSPSetOperators() line 536 in
> >> >> >> It looks like I am doing something wrong in "call KSPSetOperators"
> >> >> >> but
> >> >> >> I could not figure that out.
> >> >> >> Could anybody help me to fix this problem? I looked into almost
> all
> >> >> >> related examples but I could not really figure out the correct
> steps
> >> >> >> after "call PCFieldSplitSetIS".
> >> >> >> Any help will be greatly appreciated.
> >> >> >> Best,
> >> >> >> Hom nath
> >> >> >> On Sun, Jan 24, 2016 at 7:14 PM, Hom Nath Gharti
> >> >> >> wrote:
> >> >> >> > Thank you so much Matt! I will try.
> >> >> >> > Hom Nath
> >> >> >> > On Sun, Jan 24, 2016 at 6:26 AM, Matthew Knepley
> >> >> >> > wrote:
> >> >> >> >> On Fri, Jan 22, 2016 at 2:19 PM, Hom Nath Gharti
> >> >> >> >> wrote:
> >> >> >> >>> Dear all,
> >> >> >> >>> I am new to PcFieldSplit.
> >> >> >> >>> I have a matrix formed using MATMPIAIJ. Is it possible to use
> >> >> >> >>> PCFIELDSPLIT operations in this type of matrix? Or does it
> have
> >> >> >> >>> to
> >> >> >> >>> be
> >> >> >> >>> MATMPIBIJ or MATNEST format?
> >> >> >> >> Yes, you can split AIJ.
> >> >> >> >>> If possible for MATMPIAIJ, could anybody provide me a simple
> >> >> >> >>> example
> >> >> >> >>> or few steps? Variables in the equations are displacement
> >> >> >> >>> vector,
> >> >> >> >>> scalar potential and pressure.
> >> >> >> >> If you do not have a collocated discretization, then you have
> to
> >> >> >> >> use
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetIS.html
> >> >> >> >>   Thanks,
> >> >> >> >>      Matt
> >> >> >> >>> Thanks for help.
> >> >> >> >>> Hom Nath
> >> >> >> >> What most experimenters take for granted before they begin
> their
> >> >> >> >> experiments
> >> >> >> >> is infinitely more interesting than any results to which their
> >> >> >> >> experiments
> >> >> >> >> lead.
> >> >> >> >> -- Norbert Wiener
> >> >> > What most experimenters take for granted before they begin their
> >> >> > experiments
> >> >> > experiments
> >> >> > lead.
> >> >> > -- Norbert Wiener
> >> > experiments
> >> > experiments
> >> > lead.
> >> > -- Norbert Wiener
> experiments
> experiments
> > lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160202/01acd536/attachment.html>
