[petsc-users] fstack-array issue
Sun Feb 7 10:13:02 CST 2016
It seems like that you have exceeded stack space with your local array. Did
you run under valgrind?
  Matt
On Sun, Feb 7, 2016 at 3:51 AM, Adrian Jackson <adrianj at epcc.ed.ac.uk>
wrote:
> Hi,
> We're using PETSc in a fortran code and get an error if we compile the
> code using the -fstack-arrays flag when using the GNU fortran compilers.
>  This is the error we are getting:
> [22]PETSC ERROR: --------------------- Error Message
> [22]PETSC ERROR: Arguments are incompatible
> [22]PETSC ERROR: Zero diagonal on row 23003
> [22]PETSC ERROR: #1 MatInvertDiagonal_SeqAIJ() line 1841 in
> /b/cray-petsc/.cray-build/GNU/49/sandybridge/cray-petsc-base-dynamic/petsc-3.5.2/src/mat/impls/aij/seq/aij.c
> [22]PETSC ERROR: #2 MatSOR_SeqAIJ() line 1873 in
> [22]PETSC ERROR: #14 KSPSolve() line 459 in
> /b/cray-petsc/.cray-build/GNU/49/sandybridge/cray-petsc-base-dynamic/petsc-3.5.2/src/ksp/ksp/interface/itfunc.c
>  WARNING: Failed to converge.
>  PETSc did not converge for matrix solve of: DeltaU
>  Reason for non-convergence is undefined:            0
>  Number of iterations:            0
>  Sending signal to dump and finish
> I've checked the right hand side vector passed to KSPSolve in both cases
> and it's the same.  I've not fully verified the ksp context is exactly
> the same but it doesn't seem to be corrupted when using -fstack-arrays.
>  Is this a problem people have encountered before?
> thanks
> adrianj
> The University of Edinburgh is a charitable body, registered in
> Scotland, with registration number SC005336.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160207/14efc3c4/attachment.html>
