[petsc-users] fstack-array issue
Adrian Jackson adrianj at epcc.ed.ac.uk
Sun Feb 7 03:51:53 CST 2016
We're using PETSc in a fortran code and get an error if we compile the
code using the -fstack-arrays flag when using the GNU fortran compilers.
 This is the error we are getting:
[22]PETSC ERROR: --------------------- Error Message
[22]PETSC ERROR: Arguments are incompatible
[22]PETSC ERROR: Zero diagonal on row 23003
[22]PETSC ERROR: #1 MatInvertDiagonal_SeqAIJ() line 1841 in
/b/cray-petsc/.cray-build/GNU/49/sandybridge/cray-petsc-base-dynamic/petsc-3.5.2/src/mat/impls/aij/seq/aij.c
[22]PETSC ERROR: #2 MatSOR_SeqAIJ() line 1873 in
[22]PETSC ERROR: #14 KSPSolve() line 459 in
/b/cray-petsc/.cray-build/GNU/49/sandybridge/cray-petsc-base-dynamic/petsc-3.5.2/src/ksp/ksp/interface/itfunc.c
 WARNING: Failed to converge.
 PETSc did not converge for matrix solve of: DeltaU
 Reason for non-convergence is undefined:            0
 Number of iterations:            0
 Sending signal to dump and finish
I've checked the right hand side vector passed to KSPSolve in both cases
and it's the same.  I've not fully verified the ksp context is exactly
the same but it doesn't seem to be corrupted when using -fstack-arrays.
 Is this a problem people have encountered before?
thanks
adrianj
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
