[petsc-users] Editor for PETSc
Kaushik Kulkarni kaushikggg at gmail.com
Fri Feb 5 11:27:42 CST 2016
Thank you very much it works, and is even giving auto-completion options.!!
*Kaushik KulkarniThird Year Undergraduate*
*Department of Mechanical EngineeringIndian Institute of Technology Bombay*
*Mumbai, Indiahttp://home.iitb.ac.in/~kaushikkulkarni/
<http://home.iitb.ac.in/~kaushikkulkarni/>*
*Contact: +91-9967687150*
On Fri, Feb 5, 2016 at 10:43 PM, Jed Brown <jed at jedbrown.org> wrote:
> Kaushik Kulkarni <kaushikggg at gmail.com> writes:
> > Hey Jed,
> > Thanks for your response. But a small doubt.
> > Am I supposed to add these two lines to the list of flags.
> > '-I$PETSC_DIR/include',
> >  '-I$PETSC_DIR/$PETSC_ARCH/include',
> > Because I did so, and still it was not working.
> The above probably doesn't expand those variables and they might not be
> set in the editor's environment anyway.  Expand them manually if you need.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160205/fb442dfb/attachment.html>
