[petsc-users] Editor for PETSc
Kaushik Kulkarni kaushikggg at gmail.com
Fri Feb 5 10:59:24 CST 2016
Hey Jed,
Thanks for your response. But a small doubt.
Am I supposed to add these two lines to the list of flags.
'-I$PETSC_DIR/include',
 '-I$PETSC_DIR/$PETSC_ARCH/include',
Because I did so, and still it was not working.
Kaushik.
*Kaushik KulkarniThird Year Undergraduate*
*Department of Mechanical EngineeringIndian Institute of Technology Bombay*
*Mumbai, Indiahttp://home.iitb.ac.in/~kaushikkulkarni/
<http://home.iitb.ac.in/~kaushikkulkarni/>*
*Contact: +91-9967687150*
On Fri, Feb 5, 2016 at 10:01 PM, Patrick Sanan <patrick.sanan at gmail.com>
wrote:
> If you're using vim, using ctags (you want "exuberant ctags") is a quick
> and handy way to
> look around in the PETSc source (with its included man pages).
> See the manual, http://www.mcs.anl.gov/petsc/petsc-current/docs/manual.pdf,
> Section 15.9 .
> (and if you use emacs, see the preceding Section 15.8 for instructions on
> tags and more).
> On Fri, Feb 05, 2016 at 02:27:49PM +0530, Kaushik Kulkarni wrote:
> > Hello,
> > I am a newbie to PETSc. I am going thorugh the tutorials right now. But I
> > am struggling a bit in finding the correct editor for me. Till now I was
> > fine with VIM, as it gave me a bunch of completions options in the form
> of
> > a drop down box. And using the Clang support feature it would also
> > highlight the errors hence drastically decreasing my errors. Is there any
> > way I could continue working on such environment.
> > I was using the "YouCompleteMe"  plugin with VIM which had all of these
> > features.
> > Thanks,
> > *Kaushik*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160205/00f27a3a/attachment.html>
