[petsc-users] Editor for PETSc
Patrick Sanan patrick.sanan at gmail.com
Fri Feb 5 10:31:08 CST 2016
If you're using vim, using ctags (you want "exuberant ctags") is a quick and handy way to
look around in the PETSc source (with its included man pages).
See the manual, http://www.mcs.anl.gov/petsc/petsc-current/docs/manual.pdf, Section 15.9 .
(and if you use emacs, see the preceding Section 15.8 for instructions on tags and more).
On Fri, Feb 05, 2016 at 02:27:49PM +0530, Kaushik Kulkarni wrote:
> Hello,
> I am a newbie to PETSc. I am going thorugh the tutorials right now. But I
> am struggling a bit in finding the correct editor for me. Till now I was
> fine with VIM, as it gave me a bunch of completions options in the form of
> a drop down box. And using the Clang support feature it would also
> highlight the errors hence drastically decreasing my errors. Is there any
> way I could continue working on such environment.
> I was using the "YouCompleteMe"  plugin with VIM which had all of these
> features.
> Thanks,
> *Kaushik*
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160205/0732f916/attachment.pgp>
