[petsc-users] petsc externalpackage directory
Jed Brown jed at jedbrown.org
Tue Feb 2 23:02:50 CST 2016
Satish Balay <balay at mcs.anl.gov> writes:
>> > Well my recommendation was for this use case of "same install on a different machine"
>> If you're installing to the same location on equivalently-configured
>> machines,
> I presumed the copy is to a different machine - perhaps with different file system/organization.
Like different versions of compilers or different library versions?
Then the failure mode I mentioned is possible.
>> And it breaks _constantly_.  It must be like 30% of petsc-maint traffic
>> in the past year; advice being "delete PETSC_ARCH and reconfigure".
> All of these breakages are usually due to 2 different cases.
> - [as mentioned before] - due to 'git pull' changing dependencies
> - [without git pull or equivalent] conflict between switching from say
>  --download-mpich to --download-openmpi - in install location
>  [PETSC_ARCH/include] and not sources in PETSC_ARCH/externalpackages
> I agree starting from tarballs is the recommended way - but this copy
> [of petsc+externalpackages together] will also work.
I said it was unreliable, not that it would necessarily fail.  I don't
think we can claim this is supported behavior without a way to ensure
clean build directories.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160202/08523eb6/attachment.pgp>
