[petsc-users] petsc externalpackage directory
Jed Brown jed at jedbrown.org
Tue Feb 2 22:38:40 CST 2016
Satish Balay <balay at mcs.anl.gov> writes:
> Well my recommendation was for this use case of "same install on a different machine"
If you're installing to the same location on equivalently-configured
machines, you can just copy $prefix (optionally by using DESTDIR to
install to a temporary directory that you tar up).  If you need to
rebuild, then the old build artifacts are flawed.
> And currently we do kinda support inplace repeated install of the same
> package
And it breaks _constantly_.  It must be like 30% of petsc-maint traffic
in the past year; advice being "delete PETSC_ARCH and reconfigure".
> I sure would like a common cache [for any build/arch/version] for both
> tarballs and git repos - so network traffic can be cut down. [say in
> ~/.local/petsc/cache].
We need checksums for this.  (We should always have checksums anyway.)
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160202/e35396c5/attachment.pgp>
