[petsc-users] petsc externalpackage directory
Tue Feb 2 14:08:47 CST 2016
On Tue, Feb 2, 2016 at 2:06 PM, Xiangdong <epscodes at gmail.com> wrote:
> On Tue, Feb 2, 2016 at 2:27 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> On Tue, 2 Feb 2016, Barry Smith wrote:
>> > > On Feb 2, 2016, at 9:21 AM, Xiangdong <epscodes at gmail.com> wrote:
>> > > the package is untar and compiled in $PETSC_ARCH/externalpackages,
>> but the original tarball .tar file is deleted. Is it correct?
>> >    Yes
>> >   When you ran the successful configure it printed to the screen where
>> the tar file came from. You should use curl or wget to get the tarball and
>> then copy it over to the machine you want it on.
>> Or you can copy the whole '$PETSC_ARCH/externalpackages' dir over to
>> this other machine [and place in the same location - for any
>> PETSC_ARCH you plan to use..]
> If I have 15 packages to install, this method would be easy. Once I copied
> this folder to the new machine, do I use
> --with-pastix-dir=$PETSC_ARCH/externalpackages/pastix_5.2  or
> --download-pastix=$PETSC_ARCH/externalpackages/pastix_5.2? The first may
> fail due to the different libraries installed on that machine. For the
> second one, can --download-pastix take the directory path instead of the
> tarball file?
Just use the regular --download-* options. It will find the downloaded
packages and rebuild them.
  Matt
> Thanks.
> Xiangdong
>> Satish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160202/f2d39f7a/attachment.html>
