[petsc-users] petsc externalpackage directory
Tue Feb 2 13:27:17 CST 2016
On Tue, 2 Feb 2016, Barry Smith wrote:
> > On Feb 2, 2016, at 9:21 AM, Xiangdong <epscodes at gmail.com> wrote:
> > the package is untar and compiled in $PETSC_ARCH/externalpackages, but the original tarball .tar file is deleted. Is it correct?
>    Yes
>   When you ran the successful configure it printed to the screen where the tar file came from. You should use curl or wget to get the tarball and then copy it over to the machine you want it on.
Or you can copy the whole '$PETSC_ARCH/externalpackages' dir over to
this other machine [and place in the same location - for any
PETSC_ARCH you plan to use..]
Satish
