[petsc-users] Error with SuperLU_DIST (mkl related?)
Sat Dec 31 12:14:35 CST 2016
On Sat, Dec 31, 2016 at 12:10 PM, Eric Chamberland <
Eric.Chamberland at giref.ulaval.ca> wrote:
> Hi,
> ok I will test with 5.1.3 with the option you gave me
> (--download-superlu_dit-commit=v5.1.3).
> But from what you and Matthew said, I should have 5.1.3 with petsc-master,
> but the last night log shows me library file name 5.1.0:
> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2016
> .12.31.02h00m01s_configure.log
> So I am a bit confused: Why did I got 5.1.0 last night? (I use the
> petsc-master tarball, is it the reason?)
We do not automatically upgrade the version of dependent packages. You have
to delete them and reconfigure
if you want us to download the new thing.
  Matt
> Thanks,
> Eric
> Le 2016-12-31 à 11:52, Satish Balay a écrit :
>> On Sat, 31 Dec 2016, Eric Chamberland wrote:
>> Hi,
>>> I am just starting to debug a bug encountered with and only with
>>> SuperLU_Dist
>>> combined with MKL on a 2 processes validation test.
>>> (the same test works fine with MUMPS on 2 processes).
>>> I just noticed that the SuperLU_Dist version installed by PETSc configure
>>> script is 5.1.0 and the latest SuperLU_DIST is 5.1.3.
>> If you use petsc-master - it will install 5.1.3 by default.
>>> Before going further, I just want to ask:
>>> Is there any specific reason to stick to 5.1.0?
>> We don't usually upgrade externalpackage version in PETSc releases
>> [unless its tested to work and fixes known bugs]. There could be API
>> changes - or build changes that can potentially conflict.
>> >From what I know - 5.1.3 should work with petsc-3.7 [it fixes a couple
>> of bugs].
>> You might be able to do the following with petsc-3.7 [with git
>> externalpackage repos]
>> --download-superlu_dist --download-superlu_dit-commit=v5.1.3
>> Satish
>> Here is some more information:
>>> On process 2 I have this printed in stdout:
>>> Intel MKL ERROR: Parameter 6 was incorrect on entry to DTRSM .
>>> and in stderr:
>>> Test.ProblemeEFGen.opt: malloc.c:2369: sysmalloc: Assertion `(old_top ==
>>> (((mbinptr) (((char *) &((av)->bins[((1) - 1) * 2])) - __builtin_offsetof
>>> (struct malloc_chunk, fd)))) && old_size == 0) || ((unsigned long)
>>> (old_size)
>>>> = (unsigned long)((((__builtin_offsetof (struct malloc_chunk,
>>> fd_nextsize))+((2 *(sizeof(size_t))) - 1)) & ~((2 *(sizeof(size_t))) -
>>> 1))) &&
>>> ((old_top)->size & 0x1) && ((unsigned long) old_end & pagemask) == 0)'
>>> failed.
>>> [saruman:15771] *** Process received signal ***
>>> This is the 7th call to KSPSolve in the same execution. Here is the last
>>> KSPView:
>>> KSP Object:(o_slin) 2 MPI processes
>>>    type: preonly
>>>    maximum iterations=10000, initial guess is zero
>>>    tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>>    left preconditioning
>>>    using NONE norm type for convergence test
>>> PC Object:(o_slin) 2 MPI processes
>>>    type: lu
>>>      LU: out-of-place factorization
>>>      tolerance for zero pivot 2.22045e-14
>>>      matrix ordering: natural
>>>      factor fill ratio given 0., needed 0.
>>>        Factored matrix follows:
>>>          Mat Object:         2 MPI processes
>>>            type: mpiaij
>>>            rows=382, cols=382
>>>            package used to perform factorization: superlu_dist
>>>            total: nonzeros=0, allocated nonzeros=0
>>>            total number of mallocs used during MatSetValues calls =0
>>>              SuperLU_DIST run parameters:
>>>                Process grid nprow 2 x npcol 1
>>>                Equilibrate matrix TRUE
>>>                Matrix input mode 1
>>>                Replace tiny pivots FALSE
>>>                Use iterative refinement FALSE
>>>                Processors in row 2 col partition 1
>>>                Row permutation LargeDiag
>>>                Column permutation METIS_AT_PLUS_A
>>>                Parallel symbolic factorization FALSE
>>>                Repeated factorization SamePattern
>>>    linear system matrix = precond matrix:
>>>    Mat Object:  (o_slin)   2 MPI processes
>>>      type: mpiaij
>>>      rows=382, cols=382
>>>      total: nonzeros=4458, allocated nonzeros=4458
>>>        using I-node (on process 0) routines: found 109 nodes, limit used
>>> is 5
>>> I know this information is not enough to help debug, but I would like to
>>> know
>>> if PETSc guys will upgrade to 5.1.3 before trying to debug anything.
>>> Thanks,
>>> Eric
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161231/35a98be2/attachment.html>
