[petsc-users] Error with SuperLU_DIST (mkl related?)
Eric Chamberland Eric.Chamberland at giref.ulaval.ca
Sat Dec 31 12:10:34 CST 2016
ok I will test with 5.1.3 with the option you gave me
(--download-superlu_dit-commit=v5.1.3).
But from what you and Matthew said, I should have 5.1.3 with
petsc-master, but the last night log shows me library file name 5.1.0:
http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2016.12.31.02h00m01s_configure.log
So I am a bit confused: Why did I got 5.1.0 last night? (I use the
petsc-master tarball, is it the reason?)
Eric
Le 2016-12-31 à 11:52, Satish Balay a écrit :
> On Sat, 31 Dec 2016, Eric Chamberland wrote:
>> Hi,
>> I am just starting to debug a bug encountered with and only with SuperLU_Dist
>> combined with MKL on a 2 processes validation test.
>> (the same test works fine with MUMPS on 2 processes).
>> I just noticed that the SuperLU_Dist version installed by PETSc configure
>> script is 5.1.0 and the latest SuperLU_DIST is 5.1.3.
> If you use petsc-master - it will install 5.1.3 by default.
>> Before going further, I just want to ask:
>> Is there any specific reason to stick to 5.1.0?
> We don't usually upgrade externalpackage version in PETSc releases
> [unless its tested to work and fixes known bugs]. There could be API
> changes - or build changes that can potentially conflict.
> >From what I know - 5.1.3 should work with petsc-3.7 [it fixes a couple of bugs].
> You might be able to do the following with petsc-3.7 [with git externalpackage repos]
> --download-superlu_dist --download-superlu_dit-commit=v5.1.3
> Satish
>> Here is some more information:
>> On process 2 I have this printed in stdout:
>> Intel MKL ERROR: Parameter 6 was incorrect on entry to DTRSM .
>> and in stderr:
>> Test.ProblemeEFGen.opt: malloc.c:2369: sysmalloc: Assertion `(old_top ==
>> (((mbinptr) (((char *) &((av)->bins[((1) - 1) * 2])) - __builtin_offsetof
>> (struct malloc_chunk, fd)))) && old_size == 0) || ((unsigned long) (old_size)
>>> = (unsigned long)((((__builtin_offsetof (struct malloc_chunk,
>> fd_nextsize))+((2 *(sizeof(size_t))) - 1)) & ~((2 *(sizeof(size_t))) - 1))) &&
>> ((old_top)->size & 0x1) && ((unsigned long) old_end & pagemask) == 0)' failed.
>> [saruman:15771] *** Process received signal ***
>> This is the 7th call to KSPSolve in the same execution. Here is the last
>> KSPView:
>> KSP Object:(o_slin) 2 MPI processes
>>    type: preonly
>>    maximum iterations=10000, initial guess is zero
>>    tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>    left preconditioning
>>    using NONE norm type for convergence test
>> PC Object:(o_slin) 2 MPI processes
>>    type: lu
>>      LU: out-of-place factorization
>>      tolerance for zero pivot 2.22045e-14
>>      matrix ordering: natural
>>      factor fill ratio given 0., needed 0.
>>        Factored matrix follows:
>>          Mat Object:         2 MPI processes
>>            type: mpiaij
>>            rows=382, cols=382
>>            package used to perform factorization: superlu_dist
>>            total: nonzeros=0, allocated nonzeros=0
>>            total number of mallocs used during MatSetValues calls =0
>>              SuperLU_DIST run parameters:
>>                Process grid nprow 2 x npcol 1
>>                Equilibrate matrix TRUE
>>                Matrix input mode 1
>>                Replace tiny pivots FALSE
>>                Use iterative refinement FALSE
>>                Processors in row 2 col partition 1
>>                Row permutation LargeDiag
>>                Column permutation METIS_AT_PLUS_A
>>                Parallel symbolic factorization FALSE
>>                Repeated factorization SamePattern
>>    linear system matrix = precond matrix:
>>    Mat Object:  (o_slin)   2 MPI processes
>>      type: mpiaij
>>      rows=382, cols=382
>>      total: nonzeros=4458, allocated nonzeros=4458
>>        using I-node (on process 0) routines: found 109 nodes, limit used is 5
>> I know this information is not enough to help debug, but I would like to know
>> if PETSc guys will upgrade to 5.1.3 before trying to debug anything.
>> Thanks,
>> Eric
