[petsc-users] snes options for rough solution
Mon Dec 12 01:11:10 CST 2016
On Mon, Dec 12, 2016 at 1:04 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Dec 12, 2016 at 12:56 AM, Praveen C <cpraveen at gmail.com> wrote:
>> Increasing number of snes iterations, I get convergence.
>> So it is a problem of initial guess being too far from the solution of
>> the nonlinear equation.
>> Solution can be seen here
>> https://github.com/cpraveen/fenics/blob/master/1d/cosmic_ray
>> /cosmic_ray.ipynb
Also, how is this a parabolic equation? It looks like u/|u'| to me, which
does not look parabolic at all.
  Matt
> Green curve is solution after two time steps.
>> It took about 100 snes iterations in first time step and about 50 in
>> second time step.
>> I use exact Jacobian and direct LU solve.
> I do not believe its the correct Jacobian. Did you test it as I asked?
> Also run with
>   -snes_monitor -ksp_monitor_true_residual -snes_view
> -snes_converged_reason
> and then
>   -snes_fd
> and send all the output
>    Matt
>> Thanks
>> praveen
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161212/cb48b1ae/attachment.html>
