[petsc-users] snes options for rough solution
Mon Dec 12 01:04:42 CST 2016
On Mon, Dec 12, 2016 at 12:56 AM, Praveen C <cpraveen at gmail.com> wrote:
> Increasing number of snes iterations, I get convergence.
> So it is a problem of initial guess being too far from the solution of the
> nonlinear equation.
> Solution can be seen here
> https://github.com/cpraveen/fenics/blob/master/1d/cosmic_
> ray/cosmic_ray.ipynb
> Green curve is solution after two time steps.
> It took about 100 snes iterations in first time step and about 50 in
> second time step.
> I use exact Jacobian and direct LU solve.
I do not believe its the correct Jacobian. Did you test it as I asked? Also
run with
  -snes_monitor -ksp_monitor_true_residual -snes_view -snes_converged_reason
and then
  -snes_fd
and send all the output
   Matt
> Thanks
> praveen
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161212/354c4059/attachment.html>
