[petsc-users] snes options for rough solution
Mon Dec 12 00:54:01 CST 2016
On Mon, Dec 12, 2016 at 12:41 AM, Praveen C <cpraveen at gmail.com> wrote:
> Sorry for being incomplete. I use backward euler and snes. The figure I
> sent shows solution changes by a large amount in each time step. The major
> change is at extrema. The change in one time step
> u^{n+1} - u^n
> which must come from snes is not a smooth function of x.
> If I use dt = dx, then snes does not converge even after 50 iterations,
> here is output (Fenics code)
>   0 SNES Function norm 1.977638959494e+00
>   1 SNES Function norm 1.924169835496e+00
>   2 SNES Function norm 1.922201608879e+00
>   3 SNES Function norm 1.920237421814e+00
>   4 SNES Function norm 1.918277062381e+00
>   5 SNES Function norm 1.916320289472e+00
>   6 SNES Function norm 1.914366865403e+00
>   7 SNES Function norm 1.912416585240e+00
>   8 SNES Function norm 1.910469283868e+00
>   9 SNES Function norm 1.899960770375e+00
>  10 SNES Function norm 1.879131065459e+00
>  11 SNES Function norm 1.857531063656e+00
>  12 SNES Function norm 1.836809521483e+00
>  13 SNES Function norm 1.816709863124e+00
>  14 SNES Function norm 1.797014998190e+00
>  15 SNES Function norm 1.777737697197e+00
>  16 SNES Function norm 1.758825541543e+00
>  17 SNES Function norm 1.740232061718e+00
>  18 SNES Function norm 1.721929885464e+00
>  19 SNES Function norm 1.703895519687e+00
>  20 SNES Function norm 1.686113465512e+00
>  21 SNES Function norm 1.668566528915e+00
>  22 SNES Function norm 1.651247832992e+00
>  23 SNES Function norm 1.634150402758e+00
>  24 SNES Function norm 1.617265971731e+00
>  25 SNES Function norm 1.600589248992e+00
>  26 SNES Function norm 1.584114929900e+00
>  27 SNES Function norm 1.567836662164e+00
>  28 SNES Function norm 1.551748332761e+00
>  29 SNES Function norm 1.535845822400e+00
>  30 SNES Function norm 1.520125060009e+00
>  31 SNES Function norm 1.504582049738e+00
>  32 SNES Function norm 1.489213340181e+00
>  33 SNES Function norm 1.474015969067e+00
>  34 SNES Function norm 1.458987020278e+00
>  35 SNES Function norm 1.444123487154e+00
>  36 SNES Function norm 1.429422455304e+00
>  37 SNES Function norm 1.414881258532e+00
>  38 SNES Function norm 1.400497521029e+00
>  39 SNES Function norm 1.386269021843e+00
>  40 SNES Function norm 1.372193573931e+00
>  41 SNES Function norm 1.358269024537e+00
>  42 SNES Function norm 1.344493290602e+00
>  43 SNES Function norm 1.330864378208e+00
>  44 SNES Function norm 1.317380313100e+00
>  45 SNES Function norm 1.304039060314e+00
>  46 SNES Function norm 1.290838655798e+00
>  47 SNES Function norm 1.277777248327e+00
>  48 SNES Function norm 1.264853054978e+00
>  49 SNES Function norm 1.252064339134e+00
>  50 SNES Function norm 1.239409403964e+00
> Function norm is decreasing but very slowly. The initial guess for newton,
> which is just solution from old time, is too far from the solution.
> With dt = dx^2, it works fine, but this time step is too small.
1) Are you using TS? I am guessing the answer is no.
2) This looks like you have a bug in the Jacobian. A larger timestep just
gives you the elliptic operator.
Try
  a) Using -pc_type lu, which removes the linear solve as a variable
  b) Using -snes_fd on a small problem, which gives the correct Jacobian
   Matt
> Best
> praveen
> On Mon, Dec 12, 2016 at 11:50 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Sun, Dec 11, 2016 at 11:23 PM, Praveen C <cpraveen at gmail.com> wrote:
>>> Dear all
>>> I am solving a nonlinear parabolic problem with snes. The newton update
>>> is rather non-smooth and I have convergence problems when using default
>>> options.
>>> Attached figure shows how solution changes in two time steps.
>> It is not clear what you mean here. Newton does not solve timestepping
>> problems. Maybe you are using it
>> with an implicit timestepper, but its still not clear what you mean by
>> non-smooth updates. Did you try with
>> TS?
>>    Matt
>>> Are there any special algorithms/options in snes that I can use for such
>>> problem ?
>>> Thanks
>>> praveen
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161212/d758a8e2/attachment-0001.html>
