[petsc-users] local dimensions
Sun Dec 11 17:30:52 CST 2016
On Sun, Dec 11, 2016 at 5:19 PM, Massoud Rezavand <msdrezavand at gmail.com>
wrote:
> Dear PETSc team,
> What is the difference between the following two methods to get the local
> dimensions of a square matrix A? If they do the same, which one is
> recommended? Should I use MPI_Scan after both?
> 1)
> PetscInt local_size = PETSC_DECIDE;
> MatSetSizes(A, local_size, local_size, N, N);
> 2)
> PetscSplitOwnership(PETSC_COMM_WORLD, &local_size, &N);
> MPI_Scan(&local_size, &end_row, 1, MPIU_INT, MPI_SUM, PETSC_COMM_WORLD);
> begin_row = end_row - local_size;
They do the same thing. You only need to second if you want that
information before matrix setup happens, such as to preallocate.
   Matt
> Thanks in advance,
> Massoud
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161211/7c6f8fd7/attachment.html>
