[petsc-users] PCFIELDSPLIT on a MATNEST with MATSHELL off-diagonal blocks
Le Chenadec, Vincent vlc at illinois.edu
Fri Apr 29 08:32:06 CDT 2016
Dear Matt,
thanks for your prompt response.
You are were right (KSPView output below): I was trying to precondition the off-diagonal blocks (I messed up the ordering of the blocks, stored as ((00), (01), (11, 10)) where I should have simply used row-major ordering).
One question: is PCFieldSplitSetIS is most effective way to go about this? Or is there a way to pass the DMDAs directly rather than extracting the ISs from A?
Thanks a lot,
Vincent
KSP Object: 8 MPI processes
  type: cg
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
  left preconditioning
  using PRECONDITIONED norm type for convergence test
PC Object: 8 MPI processes
  type: fieldsplit
    FieldSplit with MULTIPLICATIVE composition: total splits = 3
    Solver info for each split is in the following KSP objects:
    Split number 0 Defined by IS
    KSP Object:    (fieldsplit_0_)     8 MPI processes
      type: cg
      using DEFAULT norm type for convergence test
    PC Object:    (fieldsplit_0_)     8 MPI processes
      type: jacobi
      PC has not been set up so information may be incomplete
      linear system matrix = precond matrix:
      Mat Object:      (fieldsplit_0_)       8 MPI processes
        type: mpiaij
        rows=262144, cols=262144
        total: nonzeros=7.07789e+06, allocated nonzeros=7.07789e+06
        total number of mallocs used during MatSetValues calls =0
    Split number 1 Defined by IS
    KSP Object:    (fieldsplit_1_)     8 MPI processes
      type: cg
    PC Object:    (fieldsplit_1_)     8 MPI processes
      type: jacobi
      Mat Object:      (fieldsplit_1_)       8 MPI processes
        type: shell
    Split number 2 Defined by IS
    KSP Object:    (fieldsplit_2_)     8 MPI processes
      type: cg
    PC Object:    (fieldsplit_2_)     8 MPI processes
      type: jacobi
      Mat Object:      (fieldsplit_2_)       8 MPI processes
        type: shell
  Mat Object:   8 MPI processes
    type: nest
    rows=786432, cols=786432
      Matrix object:
        type=nest, rows=3, cols=3
        MatNest structure:
        (0,0) : prefix="fieldsplit_0_", type=mpiaij, rows=262144, cols=262144
        (0,1) : type=shell, rows=262144, cols=262144
        (0,2) : type=shell, rows=262144, cols=262144
        (1,0) : type=mpiaij, rows=262144, cols=262144
        (1,1) : prefix="fieldsplit_1_", type=shell, rows=262144, cols=262144
        (1,2) : type=shell, rows=262144, cols=262144
        (2,0) : type=mpiaij, rows=262144, cols=262144
        (2,1) : type=shell, rows=262144, cols=262144
        (2,2) : prefix="fieldsplit_2_", type=shell, rows=262144, cols=262144
Sent: Friday, April 29, 2016 7:42 AM
To: Le Chenadec, Vincent
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] PCFIELDSPLIT on a MATNEST with MATSHELL off-diagonal blocks
On Fri, Apr 29, 2016 at 7:34 AM, Le Chenadec, Vincent <vlc at illinois.edu<mailto:vlc at illinois.edu>> wrote:
Dear all,
I'm trying to use PCFIELDSPLIT as a preconditioner on a block matrix A,
[A_{00}   A_{01}]
[A_{10}   A_{11}]
where the diagonal blocks (A_{00} and A_{11}) are diagonally dominant. I would like to use either one of the block preconditioners (not even based on the Schur complement, simply either one of the Jacobi/Gauss-Seidel ones).
For any questions about solvers, we need to see the output of -ksp_view.
Below, it seems clear that either a) One of your diagonal blocks is a MatShell, or b) you are trying to invert
an off-diagonal block.
   Matt
The issue I'm running into concerns the formats I would like to use, so I'll start with that:
  1.  A_{00} and A_{11} are both in MATMPIAIJ format (created using DMCreateMatrix on 2D DMDAs of different sizes),
  2.  A_{10} and A_{01} are both in MATSHELL format (created using DMCreateShell). The reason why I used this format is that it seemed convenient, since the 2D DMDAs are of different sizes and I assumed I had to provide the MATOP_MULT operation only,
  3.  Finally the blocks are stored in MATNEST format (MatCreateNest).
With this choice, matrix-vector multiplications work fine (the DMDAs being packed in a DMComposite), which makes me think that so far the code is ok. Also, when I attempt to invert the matrix without preconditioner, I get the correct result.
Now here is where things do not work: if I try to use a preconditioner, I get the error pasted below (for a simple PCJACOBI)
[0]PETSC ERROR: No support for this operation for this object type
[0]PETSC ERROR: Mat type shell
[0]PETSC ERROR: #1 MatGetDiagonal() line 4306 in petsc/3.6.3_dbg/src/mat/interface/matrix.c
[0]PETSC ERROR: #2 PCSetUp_Jacobi() line 180 in petsc/3.6.3_dbg/src/ksp/pc/impls/jacobi/jacobi.c
[0]PETSC ERROR: #3 PCSetUp_Jacobi_NonSymmetric() line 261 in petsc/3.6.3_dbg/src/ksp/pc/impls/jacobi/jacobi.c
[0]PETSC ERROR: #4 PCApply_Jacobi() line 286 in petsc/3.6.3_dbg/src/ksp/pc/impls/jacobi/jacobi.c
[0]PETSC ERROR: #5 PCApply() line 483 in petsc/3.6.3_dbg/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #6 KSP_PCApply() line 242 in petsc/3.6.3_dbg/include/petsc/private/kspimpl.h
[0]PETSC ERROR: #7 KSPSolve_CG() line 139 in petsc/3.6.3_dbg/src/ksp/ksp/impls/cg/cg.c
[0]PETSC ERROR: #8 KSPSolve() line 604 in petsc/3.6.3_dbg/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #9 PCApply_FieldSplit() line 988 in petsc/3.6.3_dbg/src/ksp/pc/impls/fieldsplit/fieldsplit.c
[0]PETSC ERROR: #10 PCApply() line 483 in petsc/3.6.3_dbg/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #11 KSP_PCApply() line 242 in petsc/3.6.3_dbg/include/petsc/private/kspimpl.h
[0]PETSC ERROR: #12 KSPSolve_CG() line 139 in petsc/3.6.3_dbg/src/ksp/ksp/impls/cg/cg.c
[0]PETSC ERROR: #13 KSPSolve() line 604 in petsc/3.6.3_dbg/src/ksp/ksp/interface/itfunc.c
I may not be calling the appropriate routines, here is what I'm basically doing:
  1.  KSP type set to KSPCG (A is symmetric), PC type to PCFIELDSPLIT,
  2.  I then use MatNestGetISs on A to supply the ISs to PCFieldSplitSetIS,
  3.  Finally I use PCFieldSplitGetSubKSP to use set the subKSP for each diagonal block.
As I mentioned, as long as the subKSPs don't have any preconditioning (PCNONE), KSPSolve does not complain, only when I try to using one (even PCJACOBI) do I get similar errors). That makes me suspect that I'm doing something wrong, but I could not find an example that was doing the same thing...
Any pointers would be much appreciated!
Vincent
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160429/b62684ec/attachment-0001.html>
