[petsc-users] PCFIELDSPLIT on a MATNEST with MATSHELL off-diagonal blocks
Fri Apr 29 07:42:16 CDT 2016
On Fri, Apr 29, 2016 at 7:34 AM, Le Chenadec, Vincent <vlc at illinois.edu>
wrote:
> Dear all,
> I'm trying to use PCFIELDSPLIT as a preconditioner on a block matrix A,
> [A_{00}   A_{01}]
> [A_{10}   A_{11}]
> where the diagonal blocks (A_{00} and A_{11}) are diagonally dominant. I
> would like to use either one of the block preconditioners (not even based
> on the Schur complement, simply either one of the Jacobi/Gauss-Seidel ones).
For any questions about solvers, we need to see the output of -ksp_view.
Below, it seems clear that either a) One of your diagonal blocks is a
MatShell, or b) you are trying to invert
an off-diagonal block.
   Matt
> The issue I'm running into concerns the formats I would like to use, so
> I'll start with that:
>    1. A_{00} and A_{11} are both in MATMPIAIJ format (created using
>    DMCreateMatrix on 2D DMDAs of different sizes),
>    2. A_{10} and A_{01} are both in MATSHELL format (created using
>    DMCreateShell). The reason why I used this format is that it seemed
>    convenient, since the 2D DMDAs are of different sizes and I assumed I had
>    to provide the MATOP_MULT operation only,
>    3. Finally the blocks are stored in MATNEST format (MatCreateNest).
> With this choice, matrix-vector multiplications work fine (the DMDAs being
> packed in a DMComposite), which makes me think that so far the code is ok.
> Also, when I attempt to invert the matrix without preconditioner, I get
> the correct result.
> Now here is where things do not work: if I try to use a preconditioner, I
> get the error pasted below (for a simple PCJACOBI)
> [0]PETSC ERROR: No support for this operation for this object type
> [0]PETSC ERROR: Mat type shell
> [0]PETSC ERROR: #1 MatGetDiagonal() line 4306 in
> petsc/3.6.3_dbg/src/mat/interface/matrix.c
> [0]PETSC ERROR: #2 PCSetUp_Jacobi() line 180 in
> petsc/3.6.3_dbg/src/ksp/pc/impls/jacobi/jacobi.c
> [0]PETSC ERROR: #3 PCSetUp_Jacobi_NonSymmetric() line 261 in
> [0]PETSC ERROR: #4 PCApply_Jacobi() line 286 in
> [0]PETSC ERROR: #5 PCApply() line 483 in
> petsc/3.6.3_dbg/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #6 KSP_PCApply() line 242 in
> petsc/3.6.3_dbg/include/petsc/private/kspimpl.h
> [0]PETSC ERROR: #7 KSPSolve_CG() line 139 in
> petsc/3.6.3_dbg/src/ksp/ksp/impls/cg/cg.c
> [0]PETSC ERROR: #8 KSPSolve() line 604 in
> petsc/3.6.3_dbg/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #9 PCApply_FieldSplit() line 988 in
> petsc/3.6.3_dbg/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> [0]PETSC ERROR: #10 PCApply() line 483 in
> [0]PETSC ERROR: #11 KSP_PCApply() line 242 in
> [0]PETSC ERROR: #12 KSPSolve_CG() line 139 in
> [0]PETSC ERROR: #13 KSPSolve() line 604 in
> I may not be calling the appropriate routines, here is what I'm basically
> doing:
>    1. KSP type set to KSPCG (A is symmetric), PC type to PCFIELDSPLIT,
>    2. I then use MatNestGetISs on A to supply the ISs to
>    PCFieldSplitSetIS,
>    3. Finally I use PCFieldSplitGetSubKSP to use set the subKSP for each
>    diagonal block.
> As I mentioned, as long as the subKSPs don't have any preconditioning
> (PCNONE), KSPSolve does not complain, only when I try to using one (even
> PCJACOBI) do I get similar errors). That makes me suspect that I'm doing
> something wrong, but I could not find an example that was doing the same
> thing...
> Any pointers would be much appreciated!
> Thanks,
> Vincent
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160429/d6352beb/attachment.html>
