[petsc-users] SCALAPACK compilation error
Wed Apr 13 10:14:33 CDT 2016
Glad it worked.
Generally we recommend upgrading to latest release of PETSc - as thats
what we primarily support. And some of the issues such as this one
might be fixed in it [so its best not to revisit such issues with
older versions].  If not already fixed - we would look at fixing the
issue in the latest version.
Wrt your specific usage - we recommend using --download-fblaslapack [and
not --download-f2cblaslapack=1] when you have a fortran compiler available
[except when using quad precision build]
It does mean you would have to put some effort updating your code to
use the latest version. We do help with installation issues that you
might encounter. Usually you can grab the 'reconfigure_PETSC_ARCH.py'
script from the previous install and reuse it to build any new
versions.  [yes there can be API changes with configure aswell - so
there could be corner cases with this process]
Satish
On Wed, 13 Apr 2016, Norihiro Watanabe wrote:
> Thank you, Satish! LIBS=-lgfortran worked for me. There is no critical
> reason to keep using the old version. I'm just lazy to update it
> because the PETSc interface sometimes changes (didn't check 3.6 yet)
> and I need to change my program as well to support multiple PETSc
> versions (we need to maintain multiple computers and cannot update
> PETSc on every computer at once).
> Best,
> Nori
> On Wed, Apr 13, 2016 at 7:42 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > Any perticular reason for using 3.5 instead of currently supported 3.6 releasE?
> > If you have  system fortran blas installed - suggest using it
> > [i.e don't specify any blas/lapack option]
> > or use --download-fblaslapack [not --download-f2cblaslapack=1]
> > or use LIBS=-lgfortran
> > Satish
> >> Hi,
> >> I'm trying to compile PETSc v3.5.2 with "--download-scalapack". The
> >> full command is
> >> ./configure PETSC_ARCH=gcc-release --download-f2cblaslapack=1
> >> -with-debugging=0 --download-superlu_dist --download-hypre=1
> >> --download-ml=1 --download-parmetis --download-metis --download-mumps
> >> --download-suitesparse --download-scalapack --with-fc=mpif90
> >> --with-cc=mpicc --with-cxx=mpicxx
> >> Unfortunately it fails because linking to gfortran library is missing
> >> (see partial log below). Do you have any idea how to fix it? I found
> >> "-lgfortran" is used in several other places in configure.log but not
> >> for the below particular compilation. conf/scalapack also doesn't have
> >> "-lgfortran".
> >> Executing: mpicc  -o /tmp/petsc-THHgOH/config.libraries/conftest
> >> -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
> >> -O /tmp/petsc-THHgOH/config.libraries/conftest.o
> >> -Wl,-rpath,/home/localadmin/tools/petsc/petsc-3.5.2/gcc-release/lib64
> >> -L/home/localadmin/tools/petsc/petsc-3.5.2/gcc-release/lib64
> >> -lscalapack -Wl,-rpath,/home/localadmin/tools/petsc/petsc-3.5.2/gcc-release/lib
> >> -L/home/localadmin/tools/petsc/petsc-3.5.2/gcc-release/lib -lf2clapack
> >> -L/home/localadmin/tools/petsc/petsc-3.5.2/gcc-release/lib -lf2cblas
> >> -lm -Wl,-rpath,/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib
> >> -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.8
> >> -L/usr/lib/gcc/x86_64-linux-gnu/4.8
> >> -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu
> >> -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu
> >> -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl
> >> -lmpi -lhwloc -lgcc_s -lpthread -ldl
> >> Possible ERROR while running linker: exit code 256
> >> stderr:
> >> /home/localadmin/tools/petsc/petsc-3.5.2/gcc-release/lib/libscalapack.a(pxerbla.o):
> >> In function `pxerbla_':
> >> pxerbla.f:(.text+0x7d): undefined reference to `_gfortran_st_write'
> >> pxerbla.f:(.text+0x8d): undefined reference to
> >> `_gfortran_transfer_integer_write'
> >> pxerbla.f:(.text+0x9d): undefined reference to
> >> pxerbla.f:(.text+0xab): undefined reference to
> >> `_gfortran_transfer_character_write'
> >> pxerbla.f:(.text+0xbb): undefined reference to
> >> pxerbla.f:(.text+0xc3): undefined reference to `_gfortran_st_write_done'
> >> collect2: error: ld returned 1 exit status
> >> Thanks,
> >> Nori
