[petsc-users] SCALAPACK compilation error
Norihiro Watanabe norihiro.w at gmail.com
Wed Apr 13 01:05:21 CDT 2016
Thank you, Satish! LIBS=-lgfortran worked for me. There is no critical
reason to keep using the old version. I'm just lazy to update it
because the PETSc interface sometimes changes (didn't check 3.6 yet)
and I need to change my program as well to support multiple PETSc
versions (we need to maintain multiple computers and cannot update
PETSc on every computer at once).
Best,
Nori
On Wed, Apr 13, 2016 at 7:42 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> Any perticular reason for using 3.5 instead of currently supported 3.6 releasE?
> If you have  system fortran blas installed - suggest using it
> [i.e don't specify any blas/lapack option]
> or use --download-fblaslapack [not --download-f2cblaslapack=1]
> or use LIBS=-lgfortran
> Satish
> On Wed, 13 Apr 2016, Norihiro Watanabe wrote:
>> Hi,
>> I'm trying to compile PETSc v3.5.2 with "--download-scalapack". The
>> full command is
>> ./configure PETSC_ARCH=gcc-release --download-f2cblaslapack=1
>> -with-debugging=0 --download-superlu_dist --download-hypre=1
>> --download-ml=1 --download-parmetis --download-metis --download-mumps
>> --download-suitesparse --download-scalapack --with-fc=mpif90
>> --with-cc=mpicc --with-cxx=mpicxx
>> Unfortunately it fails because linking to gfortran library is missing
>> (see partial log below). Do you have any idea how to fix it? I found
>> "-lgfortran" is used in several other places in configure.log but not
>> for the below particular compilation. conf/scalapack also doesn't have
>> "-lgfortran".
>> Executing: mpicc  -o /tmp/petsc-THHgOH/config.libraries/conftest
>> -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
>> -O /tmp/petsc-THHgOH/config.libraries/conftest.o
>> -Wl,-rpath,/home/localadmin/tools/petsc/petsc-3.5.2/gcc-release/lib64
>> -L/home/localadmin/tools/petsc/petsc-3.5.2/gcc-release/lib64
>> -lscalapack -Wl,-rpath,/home/localadmin/tools/petsc/petsc-3.5.2/gcc-release/lib
>> -L/home/localadmin/tools/petsc/petsc-3.5.2/gcc-release/lib -lf2clapack
>> -L/home/localadmin/tools/petsc/petsc-3.5.2/gcc-release/lib -lf2cblas
>> -lm -Wl,-rpath,/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib
>> -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.8
>> -L/usr/lib/gcc/x86_64-linux-gnu/4.8
>> -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu
>> -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu
>> -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl
>> -lmpi -lhwloc -lgcc_s -lpthread -ldl
>> Possible ERROR while running linker: exit code 256
>> stderr:
>> /home/localadmin/tools/petsc/petsc-3.5.2/gcc-release/lib/libscalapack.a(pxerbla.o):
>> In function `pxerbla_':
>> pxerbla.f:(.text+0x7d): undefined reference to `_gfortran_st_write'
>> pxerbla.f:(.text+0x8d): undefined reference to
>> `_gfortran_transfer_integer_write'
>> pxerbla.f:(.text+0x9d): undefined reference to
>> pxerbla.f:(.text+0xab): undefined reference to
>> `_gfortran_transfer_character_write'
>> pxerbla.f:(.text+0xbb): undefined reference to
>> pxerbla.f:(.text+0xc3): undefined reference to `_gfortran_st_write_done'
>> collect2: error: ld returned 1 exit status
>> Thanks,
>> Nori
Norihiro Watanabe
