[petsc-users] Problem setting Jacobian matrix in complementarity problem
Mon Apr 11 16:04:39 CDT 2016
   Does your matrix have entries all along the diagonal? If not you need to preallocate for even the 0 locations and set the value of 0 in there specifically.
   Barry
> On Apr 11, 2016, at 3:59 PM, Christopher Athaide <cnathaide at yahoo.com> wrote:
> Hi Barry,
> Thank you for taking a look at the issue I am having. I followed your
> suggestion and made the following changes:
> main()
> 	ierr = MatDuplicate(data.A, MAT_SHARE_NONZERO_PATTERN, &J);
> CHKERRQ(ierr);
> 	ierr = MatCopy(data.A, J, SAME_NONZERO_PATTERN); CHKERRQ(ierr);
> PetscErrorCode FormJacobian(Tao, Vec, Mat, Mat, void*)
> 	PetscFunctionBegin;
> 	PetscFunctionReturn(0);
> But I get a bunch of errors - I am not sure why.
> Problem size : 259 rows
> [0]PETSC ERROR : -------------------- - Error
> Message--------------------------------------------------------------
> [0]PETSC ERROR : Argument out of range
> [0]PETSC ERROR : New nonzero at(0, 0) caused a malloc
> Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn off
> this check
> [0]PETSC ERROR : See http ://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR : Petsc Release Version 3.6.3, Dec, 03, 2015
> [0]PETSC ERROR : Unknown Name on a arch - mswin - c - debug named LAGRANGE
> by Christopher Mon Apr 11 21 : 50 : 06 2016
> [0]PETSC ERROR : Configure options --with - cc = "win32fe cl" --with - fc =
> 0 --with - mpi = 0 --download - f2cblaslapack = 1 --with - debugging = 1
> [0]PETSC ERROR : #1 MatSetValues_SeqAIJ() line 485 in C :
> \Apps\Projects\petsc - 3.6.3\src\mat\impls\aij\seq\aij.c
> [0]PETSC ERROR : #2 MatSetValues() line 1173 in C : \Apps\Projects\petsc -
> 3.6.3\src\mat\interface\matrix.c
> [0]PETSC ERROR : #3 MatDiagonalSet_Default() line 198 in C :
> \Apps\Projects\petsc - 3.6.3\src\mat\utils\axpy.c
> [0]PETSC ERROR : #4 MatDiagonalSet_SeqAIJ() line 194 in C :
> [0]PETSC ERROR : #5 MatDiagonalSet() line 242 in C : \Apps\Projects\petsc -
> [0]PETSC ERROR : #6 Tao_SSLS_FunctionGradient() line 66 in C :
> \Apps\Projects\petsc - 3.6.3\src\tao\complementarity\impls\ssls\ssls.c
> [0]PETSC ERROR : #7 TaoLineSearchComputeObjectiveAndGradient() line 941 in C
> : \Apps\Projects\petsc - 3.6.3\src\tao\linesearch\interface\taolinesearch.c
> [0]PETSC ERROR : #8 TaoSolve_SSILS() line 64 in C : \Apps\Projects\petsc -
> 3.6.3\src\tao\complementarity\impls\ssls\ssils.c
> [0]PETSC ERROR : #9 TaoSolve() line 204 in C : \Apps\Projects\petsc -
> 3.6.3\src\tao\interface\taosolver.c
> [0]PETSC ERROR : #10 run_complementarity() line 290 in c :
> \apps\projects\complementarity.cpp
> I appreciate your help in this matter.
> Thanks
> Chris
> -----Original Message-----
> From: Barry Smith [mailto:bsmith at mcs.anl.gov]
> Sent: Monday, April 11, 2016 3:16 PM
> To: Christopher Athaide <cnathaide at yahoo.com>
> Cc: petsc-users at mcs.anl.gov
> Subject: Re: [petsc-users] Problem setting Jacobian matrix in
>> On Apr 11, 2016, at 2:04 PM, Christopher Athaide <cnathaide at yahoo.com>
> wrote:
>> Hi,
>> I am trying to solve a mixed complementarity problem using the TAO SSILS
> Solver .
>> C(x) = A x + d ,    l <= x <= u
>> where A = n x n matrix
>>               D = n x 1 vector
>> The Jacobian matrix is equal to the matrix A and is constant at each
> iteration.
>> I have setup the Jacobian update function
>> PetscErrorCode FormJacobian(Tao, Vec X, Mat H, Mat, void *ptr) {
>> AppCtx         *data = (AppCtx *)ptr;
>>                PetscErrorCode ierr;
>>                PetscInt       N;
>>                PetscInt       zero = 0;
>>                PetscScalar    *d, v;
>>                PetscBool      assembled;
>>                PetscFunctionBegin;
>>                ierr = MatAssembled(H, &assembled); CHKERRQ(ierr);
>>                if (assembled) { ierr = MatZeroEntries(H);
>> CHKERRQ(ierr); }
>>                /* Get pointers to vector data */
>>                VecGetSize(X, &N);
>>                for (auto i = zero; i != N; ++i)
>>                                for (auto j = zero; j != N; ++j)
>>                                                ierr =
> MatGetValue(data->A, i, j, &v);
>>                                                ierr = MatSetValue(H, i,
> j, v, INSERT_VALUES);
>>                /* Assemble the matrix */
>>                ierr = MatSetOption(H, MAT_IGNORE_ZERO_ENTRIES,
> PETSC_TRUE); CHKERRQ(ierr);
>>                ierr = MatAssemblyBegin(H, MAT_FINAL_ASSEMBLY);
> CHKERRQ(ierr);
>>                ierr = MatAssemblyEnd(H, MAT_FINAL_ASSEMBLY);
> CHKERRQ(ierr);
>> In this case, after iterating over all the row and column indexes and
> assembling the matrix the function seems to run correctly.
>> But when I try to copy the matrix
>> ierr = MatAssembled(H, &assembled); CHKERRQ(ierr); if (assembled) {
>> ierr = MatZeroEntries(H); CHKERRQ(ierr); } ierr = MatConvert(data->A,
>> MATSAME, MatReuse::MAT_INITIAL_MATRIX, &H); CHKERRQ(ierr);
>   You cannot do this because you are creating an entirely new H matrix here
> in the subroutine that TAO won't know about.
>   You should use MatCopy(data->A, H, SAME_NONZERO_PATTERN);
>   But since H is constant why have a copy? Just set the values in H
> initially and don't have a data->A matrix at all. Then your FormJacobian()
> doesn't need to do anything since H is already set with proper values and H
> remains the same through all iterations.
>   Barry
> CHKERRQ(ierr);
> CHKERRQ(ierr);
>>                PetscFunctionReturn(0); }
>> I get the following error messages.
>> Problem size: 259 rows
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Object is in wrong state [0]PETSC ERROR: Not for
>> unassembled matrix [0]PETSC ERROR: See
>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015 [0]PETSC
>> ERROR: Unknown Name on a arch-mswin-c-debug named LAGRANGE by
>> Christopher Mon Apr 11 19:57:37 2016 [0]PETSC ERROR: Configure options
>> --with-cc="win32fe cl" --with-fc=0 --with-mpi=0
>> --download-f2cblaslapack=1 --with-debugging=1 [0]PETSC ERROR: #1
>> MatMult() line 2210 in
>> C:\Apps\Projects\petsc-3.6.3\src\mat\interface\matrix.c
>> [0]PETSC ERROR: #2 MatDFischer() line 284 in C:\Apps\Projects
>> \petsc-3.6.3\src\tao\util\tao_util.c
>> [0]PETSC ERROR: #3 Tao_SSLS_FunctionGradient() line 64 in
>> C:\Apps\Projects
>> \petsc-3.6.3\src\tao\complementarity\impls\ssls\ssls.c
>> [0]PETSC ERROR: #4 TaoLineSearchComputeObjectiveAndGradient() line 941
>> in C:\Apps\Projects
>> \petsc-3.6.3\src\tao\linesearch\interface\taolinesearch.c
>> [0]PETSC ERROR: #5 TaoSolve_SSILS() line 64 in C:\Apps\Projects
>> \petsc-3.6.3\src\tao\complementarity\impls\ssls\ssils.c
>> [0]PETSC ERROR: #6 TaoSolve() line 204 in C:\Apps\Projects\
>> petsc-3.6.3\src\tao\interface\taosolver.c
>> [0]PETSC ERROR: #7 run_complementarity() line 394 in c:\apps\projects
>> I am new to PETSC. Can anyone help me?
>> Thanks
>> Chris Athiade
