[petsc-users] Problem setting Jacobian matrix in complementarity problem
Christopher Athaide cnathaide at yahoo.com
Mon Apr 11 15:59:30 CDT 2016
Hi Barry,
Thank you for taking a look at the issue I am having. I followed your
suggestion and made the following changes:
main()
	ierr = MatDuplicate(data.A, MAT_SHARE_NONZERO_PATTERN, &J);
CHKERRQ(ierr);
	ierr = MatCopy(data.A, J, SAME_NONZERO_PATTERN); CHKERRQ(ierr);
PetscErrorCode FormJacobian(Tao, Vec, Mat, Mat, void*)
	PetscFunctionBegin;
	PetscFunctionReturn(0);
But I get a bunch of errors - I am not sure why.
Problem size : 259 rows
[0]PETSC ERROR : -------------------- - Error
Message--------------------------------------------------------------
[0]PETSC ERROR : Argument out of range
[0]PETSC ERROR : New nonzero at(0, 0) caused a malloc
Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn off
this check
[0]PETSC ERROR : See http ://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR : Petsc Release Version 3.6.3, Dec, 03, 2015
[0]PETSC ERROR : Unknown Name on a arch - mswin - c - debug named LAGRANGE
by Christopher Mon Apr 11 21 : 50 : 06 2016
[0]PETSC ERROR : Configure options --with - cc = "win32fe cl" --with - fc =
0 --with - mpi = 0 --download - f2cblaslapack = 1 --with - debugging = 1
[0]PETSC ERROR : #1 MatSetValues_SeqAIJ() line 485 in C :
\Apps\Projects\petsc - 3.6.3\src\mat\impls\aij\seq\aij.c
[0]PETSC ERROR : #2 MatSetValues() line 1173 in C : \Apps\Projects\petsc -
3.6.3\src\mat\interface\matrix.c
[0]PETSC ERROR : #3 MatDiagonalSet_Default() line 198 in C :
\Apps\Projects\petsc - 3.6.3\src\mat\utils\axpy.c
[0]PETSC ERROR : #4 MatDiagonalSet_SeqAIJ() line 194 in C :
[0]PETSC ERROR : #5 MatDiagonalSet() line 242 in C : \Apps\Projects\petsc -
[0]PETSC ERROR : #6 Tao_SSLS_FunctionGradient() line 66 in C :
\Apps\Projects\petsc - 3.6.3\src\tao\complementarity\impls\ssls\ssls.c
[0]PETSC ERROR : #7 TaoLineSearchComputeObjectiveAndGradient() line 941 in C
: \Apps\Projects\petsc - 3.6.3\src\tao\linesearch\interface\taolinesearch.c
[0]PETSC ERROR : #8 TaoSolve_SSILS() line 64 in C : \Apps\Projects\petsc -
3.6.3\src\tao\complementarity\impls\ssls\ssils.c
[0]PETSC ERROR : #9 TaoSolve() line 204 in C : \Apps\Projects\petsc -
3.6.3\src\tao\interface\taosolver.c
[0]PETSC ERROR : #10 run_complementarity() line 290 in c :
\apps\projects\complementarity.cpp
I appreciate your help in this matter.
Thanks
Chris
-----Original Message-----
Sent: Monday, April 11, 2016 3:16 PM
To: Christopher Athaide <cnathaide at yahoo.com>
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] Problem setting Jacobian matrix in
> On Apr 11, 2016, at 2:04 PM, Christopher Athaide <cnathaide at yahoo.com>
wrote:
> Hi,
> I am trying to solve a mixed complementarity problem using the TAO SSILS
Solver .
> C(x) = A x + d ,    l <= x <= u
> where A = n x n matrix
>                D = n x 1 vector
> The Jacobian matrix is equal to the matrix A and is constant at each
iteration.
> I have setup the Jacobian update function
> PetscErrorCode FormJacobian(Tao, Vec X, Mat H, Mat, void *ptr) {
> AppCtx         *data = (AppCtx *)ptr;
>                 PetscErrorCode ierr;
>                 PetscInt       N;
>                 PetscInt       zero = 0;
>                 PetscScalar    *d, v;
>                 PetscBool      assembled;
>                 PetscFunctionBegin;
>                 ierr = MatAssembled(H, &assembled); CHKERRQ(ierr);
>                 if (assembled) { ierr = MatZeroEntries(H);
> CHKERRQ(ierr); }
>                 /* Get pointers to vector data */
>                 VecGetSize(X, &N);
>                 for (auto i = zero; i != N; ++i)
>                                 for (auto j = zero; j != N; ++j)
>                                                 ierr =
MatGetValue(data->A, i, j, &v);
>                                                 ierr = MatSetValue(H, i,
j, v, INSERT_VALUES);
>                 /* Assemble the matrix */
>                 ierr = MatSetOption(H, MAT_IGNORE_ZERO_ENTRIES,
PETSC_TRUE); CHKERRQ(ierr);
>                 ierr = MatAssemblyBegin(H, MAT_FINAL_ASSEMBLY);
CHKERRQ(ierr);
>                 ierr = MatAssemblyEnd(H, MAT_FINAL_ASSEMBLY);
CHKERRQ(ierr);
> In this case, after iterating over all the row and column indexes and
assembling the matrix the function seems to run correctly.
> But when I try to copy the matrix
> ierr = MatAssembled(H, &assembled); CHKERRQ(ierr); if (assembled) {
> ierr = MatZeroEntries(H); CHKERRQ(ierr); } ierr = MatConvert(data->A,
> MATSAME, MatReuse::MAT_INITIAL_MATRIX, &H); CHKERRQ(ierr);
   You cannot do this because you are creating an entirely new H matrix here
in the subroutine that TAO won't know about.
   You should use MatCopy(data->A, H, SAME_NONZERO_PATTERN);
   But since H is constant why have a copy? Just set the values in H
initially and don't have a data->A matrix at all. Then your FormJacobian()
doesn't need to do anything since H is already set with proper values and H
remains the same through all iterations.
   Barry
CHKERRQ(ierr);
CHKERRQ(ierr);
>                 PetscFunctionReturn(0); }
> I get the following error messages.
> Problem size: 259 rows
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Object is in wrong state [0]PETSC ERROR: Not for
> unassembled matrix [0]PETSC ERROR: See
> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015 [0]PETSC
> ERROR: Unknown Name on a arch-mswin-c-debug named LAGRANGE by
> Christopher Mon Apr 11 19:57:37 2016 [0]PETSC ERROR: Configure options
> --with-cc="win32fe cl" --with-fc=0 --with-mpi=0
> --download-f2cblaslapack=1 --with-debugging=1 [0]PETSC ERROR: #1
> MatMult() line 2210 in
> C:\Apps\Projects\petsc-3.6.3\src\mat\interface\matrix.c
> [0]PETSC ERROR: #2 MatDFischer() line 284 in C:\Apps\Projects
> \petsc-3.6.3\src\tao\util\tao_util.c
> [0]PETSC ERROR: #3 Tao_SSLS_FunctionGradient() line 64 in
> C:\Apps\Projects
> \petsc-3.6.3\src\tao\complementarity\impls\ssls\ssls.c
> [0]PETSC ERROR: #4 TaoLineSearchComputeObjectiveAndGradient() line 941
> in C:\Apps\Projects
> \petsc-3.6.3\src\tao\linesearch\interface\taolinesearch.c
> [0]PETSC ERROR: #5 TaoSolve_SSILS() line 64 in C:\Apps\Projects
> \petsc-3.6.3\src\tao\complementarity\impls\ssls\ssils.c
> [0]PETSC ERROR: #6 TaoSolve() line 204 in C:\Apps\Projects\
> petsc-3.6.3\src\tao\interface\taosolver.c
> [0]PETSC ERROR: #7 run_complementarity() line 394 in c:\apps\projects
> I am new to PETSC. Can anyone help me?
> Thanks
> Chris Athiade
