[petsc-users] How to extract array portions
FRANCAVILLA MATTEO ALESSANDRO d019598 at polito.it
Wed Apr 6 09:20:36 CDT 2016
Fantastic, it definitely solved my problem! Thank you!
Should I always create the vectors with MatCreateVecs when I use them for
matrix-vector multiplications? I used to create vectors with VecCreate, and
it has always worked fine with "standard" matrices (matrices not created
with MATNEST structure).
In the example at
http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex2.c.html
I read the following:
"PETSc automatically generates appropriately partitioned matrices and
vectors when MatCreate() and VecCreate() are used with the same
communicator."
It is not clear to me when I can simply use VecCreate (as I've always done
so far), and when to use MatCreateVecs...
On Wed, 6 Apr 2016 14:38:12 +0200
  Dave May <dave.mayhem23 at gmail.com> wrote:
> On 6 April 2016 at 14:12, FRANCAVILLA MATTEO ALESSANDRO
><d019598 at polito.it>
> wrote:
>> Thanks Dave, that's exactly what I was looking for, and
>>it (partially)
>> solved my problem.
>> The MatMult operation now works fine, unfortunately not
>>for every number
>> of MPI processes (while the MatMult involving each
>>submatrix works fine for
>> any number of processes):
>> matArray(1) = L_discretized
>> matArray(2) = K_discretized
>> matArray(3) = L_MR
>> matArray(4) = K_MR
>> CALL
>> MatCreateNest(PETSC_COMM_WORLD,2,PETSC_NULL_OBJECT,2,PETSC_NULL_OBJECT,matArray,TheMatrix,IERR)
>> CALL MatSetFromOptions(TheMatrix,IERR)
>> CALL VecCreate(PETSC_COMM_WORLD,x,IERR)
>> CALL VecSetSizes(x,PETSC_DECIDE,2*NumberOfUnknowns,IERR)
>> CALL VecSetFromOptions(x,IERR)
>> CALL VecSet(x,0.+0.*PETSC_i,IERR)
>> CALL
>>VecSetValues(x,1,0,1.+0.*PETSC_i,INSERT_VALUES,IERR)
>> CALL VecAssemblyBegin(x,IERR)
>> CALL VecAssemblyEnd(x,IERR)
>> CALL VecCreate(PETSC_COMM_WORLD,y,IERR)
>> CALL
>>VecSetSizes(y,PETSC_DECIDE,NumberOfUnknowns+NumberOfMeasures,IERR)
>> CALL VecSetFromOptions(y,IERR)
>> CALL MatMult(TheMatrix,x,y,IERR)
>> I guess there is something wrong with the distribution
>>of vectors between
>> the MPI processes. With the specific sizes of my problem
>>everything works
>> fine with 1-2-3-6 processes, otherwise I get
>>"Nonconforming object sizes"
>> error, e.g. with 8 processes:
>> [2]PETSC ERROR: --------------------- Error Message
>> [2]PETSC ERROR: Nonconforming object sizes
>> [2]PETSC ERROR: Mat mat,Vec y: local dim 383 382
>> [2]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03,
>>2015
>> ./ISS on a arch-linux2-c-debug named
>>alessandro-HP-ProDesk-490-G2-MT by
>> alessandro Wed Apr  6 13:31:45 2016
>> [2]PETSC ERROR: Configure options
>> --with-blas-lapack-dir=/opt/intel/composer_xe_2015.2.164/mkl
>> --with-mpi-cc=/home/alessandro/.openmpi-1.8.3/bin/mpicc
>> --with-mpi-f90=/home/alessandro/.openmpi-1.8.3/bin/mpif90
>> --with-mpiexec=/home/alessandro/.openmpi-1.8.3/bin/mpiexec
>> --with-scalar-type=complex
>> [2]PETSC ERROR: #1 MatMult() line 2216 in
>> /home/alessandro/CODE/PETSc/petsc-3.6.3/src/mat/interface/matrix.c
>> [6]PETSC ERROR: Mat mat,Vec y: local dim 381 382
>> [7]PETSC ERROR: Mat mat,Vec y: local dim 381 382
>> [1]PETSC ERROR: Mat mat,Vec y: local dim 383 382
>> I noticed that the code works (runs and provides correct
>>results) when the
>> number of processes divides the length of y2 (number of
>>rows of A21 and
>> A22); however when I apply MatMult separately on A21 and
>>A22 everything
>> works fine with any number of processes
>> Any idea where I'm messing up here?
> Sounds like the large vector you are using to multiple
>with the matnest
> object wasn't created via MatCreateVecs(). If you use
>this method you will
> obtain a vector with the correct local and global sizes.
>> Thanks,
>> Alessandro
>> On Wed, 6 Apr 2016 11:16:43 +0200
>>> On 6 April 2016 at 11:08, FRANCAVILLA MATTEO ALESSANDRO
>>> wrote:
>>> Hi,
>>>> I'm trying to set a linear problem with a 2x2 block
>>>>matrix (say A=[A11
>>>> A12; A21 A22] in matlab notation). Obviously I could
>>>>generate a single
>>>> matrix, but I would like to keep it as a 2x2 block
>>>>matrix with the 4
>>>> blocks
>>>> generated and used independently (e.g., because at some
>>>>point I need to
>>>> change some of those blocks to matrix-free). My plan was
>>>>then to
>>>> generate a
>>>> MatShell and set a MATOP_MULT shell operation to
>>>>explicitly compute y=A*x
>>>> by splitting x=[x1;x2] and y=[y1;y2] and carrying out
>>>>the single
>>>> matrix-vector multiplications, and reassembling the
>>>>final result.
>>> Take a look at MatNest - it does exactly what you want.
>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateNest.html
>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MATNEST.html#MATNEST
>>> Thanks,
>>>  Dave
>>> My problem is that my efforts in extracting x1 and x2
>>>from the original x
>>>> vector have failed. The following Fortran code is what
>>>>seemed to me the
>>>> most reasonable thing to do to set the matrix-vector
>>>>multiplication, but
>>>> it
>>>> does not work
>>>> subroutine MyMult(A,x,y,IERR)
>>>> implicit none
>>>> #include <petsc/finclude/petscsys.h>
>>>> #include <petsc/finclude/petscvec.h>
>>>> #include <petsc/finclude/petscvec.h90>
>>>> #include <petsc/finclude/petscmat.h>
>>>> Mat     A
>>>> Vec     x,y, x1, x2, y1, y2
>>>> IS      :: ix1, ix2, iy1, iy2
>>>> PetscErrorCode ierr
>>>> PetscInt    M, N, II, NumberOfUnknowns, NumberOfMeasures
>>>> PetscInt, ALLOCATABLE         :: INDICES(:)
>>>> PetscMPIInt                   :: RANK
>>>> CALL VecGetSize(x,N,IERR)
>>>> NumberOfUnknowns = N / 2
>>>> CALL VecGetSize(y,N,IERR)
>>>> NumberOfMeasures = N - NumberOfUnknowns
>>>> N = NumberOfUnknowns +
>>>>MAX(NumberOfUnknowns,NumberOfMeasures)
>>>> ALLOCATE(INDICES(N))
>>>> INDICES = (/ (ii, ii=0, N-1) /)
>>>> CALL
>>>> ISCreateGeneral(MPI_COMM_SELF,NumberOfUnknowns,INDICES(1:NumberOfUnknowns),PETSC_COPY_VALUES,ix1,IERR)
>>>> CALL VecGetSubVector(x,ix1,x1,IERR)
>>>> CALL
>>>> ISCreateGeneral(MPI_COMM_SELF,NumberOfUnknowns,INDICES(NumberOfUnknowns+1:2*NumberOfUnknowns),PETSC_COPY_VALUES,ix2,IERR)
>>>> CALL VecGetSubVector(x,ix2,x2,IERR)
>>>> CALL
>>>> ISCreateGeneral(MPI_COMM_SELF,NumberOfUnknowns,INDICES(1:NumberOfUnknowns),PETSC_COPY_VALUES,iy1,IERR)
>>>> CALL VecGetSubVector(y,iy1,y1,IERR)
>>>> CALL
>>>> ISCreateGeneral(MPI_COMM_SELF,NumberOfUnknowns,INDICES(NumberOfUnknowns+1:NumberOfUnknowns+NumberOfMeasures),PETSC_COPY_VALUES,iy2,IERR)
>>>> CALL VecGetSubVector(y,iy2,y2,IERR)
>>>> CALL MatMult(L_discretized,x1,y1,IERR)
>>>> CALL MatMultAdd(K_discretized,x2,y1,y1,IERR)
>>>> CALL MatMult(L_MR,x1,y2,IERR)
>>>> CALL MatMultAdd(K_MR,x2,y2,y2,IERR)
>>>> CALL VecRestoreSubVector(y,iy1,y1,IERR)
>>>> CALL VecRestoreSubVector(y,iy2,y2,IERR)
>>>> return
>>>> end subroutine MyMult
>>>> Obviously the sequence of calls to ISCreateGeneral and
>>>>VecGetSubVector
>>>> does not do what I expect, as the errors I'm getting are
>>>>in the following
>>>> MatMult multiplications (the global sizes of x1 and x2
>>>>SHOULD BE both
>>>> 771,
>>>> while y1 and y2 should be 771 and 2286):
>>>> 1) executed with 1 MPI process:
>>>> [0]PETSC ERROR: --------------------- Error Message
>>>> [0]PETSC ERROR: Nonconforming object sizes
>>>> [0]PETSC ERROR: Mat mat,Vec y: global dim 2286 771
>>>> [0]PETSC ERROR: See
>>>>http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>> for trouble shooting.
>>>> [0]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03,
>>>>2015
>>>> [0]PETSC ERROR: ./ISS on a arch-linux2-c-debug named
>>>> alessandro-HP-ProDesk-490-G2-MT by alessandro Wed Apr  6
>>>>10:54:03 2016
>>>> [0]PETSC ERROR: Configure options
>>>> [0]PETSC ERROR: #1 MatMult() line 2215 in
>>>> [0]PETSC ERROR: Mat mat,Vec v3: local dim 2286 771
>>>> [0]PETSC ERROR: See
>>>>2015
>>>>10:54:03 2016
>>>> [0]PETSC ERROR: #2 MatMultAdd() line 2396 in
>>>> 2) executed with 4 MPI processes (I'm copying the output
>>>>of process 0
>>>> only, they're all the same):
>>>> [0]PETSC ERROR: Mat mat,Vec x: global dim 771 3084
>>>> [0]PETSC ERROR: See
>>>>2015
>>>>10:49:13 2016
>>>> [0]PETSC ERROR: #1 MatMult() line 2214 in
>>>> [0]PETSC ERROR: Mat mat,Vec v1: global dim 771 3084
>>>> [0]PETSC ERROR: See
>>>>2015
>>>>10:49:13 2016
>>>> [0]PETSC ERROR: #2 MatMultAdd() line 2393 in
>>>> [0]PETSC ERROR: See
>>>>2015
>>>>10:49:13 2016
>>>> [0]PETSC ERROR: #3 MatMult() line 2214 in
>>>> [0]PETSC ERROR: See
>>>>2015
>>>>10:49:13 2016
>>>> [0]PETSC ERROR: #4 MatMultAdd() line 2393 in
>>>> Any idea? I would like to keep the flexibility of having
>>>>a sequence of
>>>> mat-vec multiplications as in
>>>> but for doing that I need to be able to extract x1 and
>>>>x2, and to
>>>> reassemble the partial results into y.
>>>> Thanks in advance,
>>>> Alessandro
>> ___________________________________
>> Matteo Alessandro Francavilla, PhD
>> Antenna and EMC Lab (LACE)
>> Istituto Superiore Mario Boella (ISMB)
>> Torino, Italy
>> phone +39 011 2276 711
Torino, Italy
