[petsc-users] How to extract array portions
Dave May dave.mayhem23 at gmail.com
Wed Apr 6 07:38:12 CDT 2016
On 6 April 2016 at 14:12, FRANCAVILLA MATTEO ALESSANDRO <d019598 at polito.it>
wrote:
> Thanks Dave, that's exactly what I was looking for, and it (partially)
> solved my problem.
> The MatMult operation now works fine, unfortunately not for every number
> of MPI processes (while the MatMult involving each submatrix works fine for
> any number of processes):
> matArray(1) = L_discretized
> matArray(2) = K_discretized
> matArray(3) = L_MR
> matArray(4) = K_MR
> CALL
> MatCreateNest(PETSC_COMM_WORLD,2,PETSC_NULL_OBJECT,2,PETSC_NULL_OBJECT,matArray,TheMatrix,IERR)
> CALL MatSetFromOptions(TheMatrix,IERR)
> CALL VecCreate(PETSC_COMM_WORLD,x,IERR)
> CALL VecSetSizes(x,PETSC_DECIDE,2*NumberOfUnknowns,IERR)
> CALL VecSetFromOptions(x,IERR)
> CALL VecSet(x,0.+0.*PETSC_i,IERR)
> CALL VecSetValues(x,1,0,1.+0.*PETSC_i,INSERT_VALUES,IERR)
> CALL VecAssemblyBegin(x,IERR)
> CALL VecAssemblyEnd(x,IERR)
> CALL VecCreate(PETSC_COMM_WORLD,y,IERR)
> CALL VecSetSizes(y,PETSC_DECIDE,NumberOfUnknowns+NumberOfMeasures,IERR)
> CALL VecSetFromOptions(y,IERR)
> CALL MatMult(TheMatrix,x,y,IERR)
> I guess there is something wrong with the distribution of vectors between
> the MPI processes. With the specific sizes of my problem everything works
> fine with 1-2-3-6 processes, otherwise I get "Nonconforming object sizes"
> error, e.g. with 8 processes:
> [2]PETSC ERROR: --------------------- Error Message
> [2]PETSC ERROR: Nonconforming object sizes
> [2]PETSC ERROR: Mat mat,Vec y: local dim 383 382
> [2]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
> ./ISS on a arch-linux2-c-debug named alessandro-HP-ProDesk-490-G2-MT by
> alessandro Wed Apr  6 13:31:45 2016
> [2]PETSC ERROR: Configure options
> --with-blas-lapack-dir=/opt/intel/composer_xe_2015.2.164/mkl
> --with-mpi-cc=/home/alessandro/.openmpi-1.8.3/bin/mpicc
> --with-mpi-f90=/home/alessandro/.openmpi-1.8.3/bin/mpif90
> --with-mpiexec=/home/alessandro/.openmpi-1.8.3/bin/mpiexec
> --with-scalar-type=complex
> [2]PETSC ERROR: #1 MatMult() line 2216 in
> /home/alessandro/CODE/PETSc/petsc-3.6.3/src/mat/interface/matrix.c
> [6]PETSC ERROR: Mat mat,Vec y: local dim 381 382
> [7]PETSC ERROR: Mat mat,Vec y: local dim 381 382
> [1]PETSC ERROR: Mat mat,Vec y: local dim 383 382
> I noticed that the code works (runs and provides correct results) when the
> number of processes divides the length of y2 (number of rows of A21 and
> A22); however when I apply MatMult separately on A21 and A22 everything
> works fine with any number of processes
> Any idea where I'm messing up here?
Sounds like the large vector you are using to multiple with the matnest
object wasn't created via MatCreateVecs(). If you use this method you will
obtain a vector with the correct local and global sizes.
> Thanks,
> Alessandro
> On Wed, 6 Apr 2016 11:16:43 +0200
>  Dave May <dave.mayhem23 at gmail.com> wrote:
>> On 6 April 2016 at 11:08, FRANCAVILLA MATTEO ALESSANDRO <
>> wrote:
>> Hi,
>>> I'm trying to set a linear problem with a 2x2 block matrix (say A=[A11
>>> A12; A21 A22] in matlab notation). Obviously I could generate a single
>>> matrix, but I would like to keep it as a 2x2 block matrix with the 4
>>> blocks
>>> generated and used independently (e.g., because at some point I need to
>>> change some of those blocks to matrix-free). My plan was then to
>>> generate a
>>> MatShell and set a MATOP_MULT shell operation to explicitly compute y=A*x
>>> by splitting x=[x1;x2] and y=[y1;y2] and carrying out the single
>>> matrix-vector multiplications, and reassembling the final result.
>> Take a look at MatNest - it does exactly what you want.
>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateNest.html
>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MATNEST.html#MATNEST
>> Thanks,
>>  Dave
>> My problem is that my efforts in extracting x1 and x2 from the original x
>>> vector have failed. The following Fortran code is what seemed to me the
>>> most reasonable thing to do to set the matrix-vector multiplication, but
>>> it
>>> does not work
>>> subroutine MyMult(A,x,y,IERR)
>>> implicit none
>>> #include <petsc/finclude/petscsys.h>
>>> #include <petsc/finclude/petscvec.h>
>>> #include <petsc/finclude/petscvec.h90>
>>> #include <petsc/finclude/petscmat.h>
>>> Mat     A
>>> Vec     x,y, x1, x2, y1, y2
>>> IS      :: ix1, ix2, iy1, iy2
>>> PetscErrorCode ierr
>>> PetscInt    M, N, II, NumberOfUnknowns, NumberOfMeasures
>>> PetscInt, ALLOCATABLE         :: INDICES(:)
>>> PetscMPIInt                   :: RANK
>>> CALL VecGetSize(x,N,IERR)
>>> NumberOfUnknowns = N / 2
>>> CALL VecGetSize(y,N,IERR)
>>> NumberOfMeasures = N - NumberOfUnknowns
>>> N = NumberOfUnknowns + MAX(NumberOfUnknowns,NumberOfMeasures)
>>> ALLOCATE(INDICES(N))
>>> INDICES = (/ (ii, ii=0, N-1) /)
>>> CALL
>>> ISCreateGeneral(MPI_COMM_SELF,NumberOfUnknowns,INDICES(1:NumberOfUnknowns),PETSC_COPY_VALUES,ix1,IERR)
>>> CALL VecGetSubVector(x,ix1,x1,IERR)
>>> CALL
>>> ISCreateGeneral(MPI_COMM_SELF,NumberOfUnknowns,INDICES(NumberOfUnknowns+1:2*NumberOfUnknowns),PETSC_COPY_VALUES,ix2,IERR)
>>> CALL VecGetSubVector(x,ix2,x2,IERR)
>>> CALL
>>> ISCreateGeneral(MPI_COMM_SELF,NumberOfUnknowns,INDICES(1:NumberOfUnknowns),PETSC_COPY_VALUES,iy1,IERR)
>>> CALL VecGetSubVector(y,iy1,y1,IERR)
>>> CALL
>>> ISCreateGeneral(MPI_COMM_SELF,NumberOfUnknowns,INDICES(NumberOfUnknowns+1:NumberOfUnknowns+NumberOfMeasures),PETSC_COPY_VALUES,iy2,IERR)
>>> CALL VecGetSubVector(y,iy2,y2,IERR)
>>> CALL MatMult(L_discretized,x1,y1,IERR)
>>> CALL MatMultAdd(K_discretized,x2,y1,y1,IERR)
>>> CALL MatMult(L_MR,x1,y2,IERR)
>>> CALL MatMultAdd(K_MR,x2,y2,y2,IERR)
>>> CALL VecRestoreSubVector(y,iy1,y1,IERR)
>>> CALL VecRestoreSubVector(y,iy2,y2,IERR)
>>> return
>>> end subroutine MyMult
>>> Obviously the sequence of calls to ISCreateGeneral and VecGetSubVector
>>> does not do what I expect, as the errors I'm getting are in the following
>>> MatMult multiplications (the global sizes of x1 and x2 SHOULD BE both
>>> 771,
>>> while y1 and y2 should be 771 and 2286):
>>> 1) executed with 1 MPI process:
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: Nonconforming object sizes
>>> [0]PETSC ERROR: Mat mat,Vec y: global dim 2286 771
>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>> for trouble shooting.
>>> [0]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
>>> [0]PETSC ERROR: ./ISS on a arch-linux2-c-debug named
>>> alessandro-HP-ProDesk-490-G2-MT by alessandro Wed Apr  6 10:54:03 2016
>>> [0]PETSC ERROR: Configure options
>>> [0]PETSC ERROR: #1 MatMult() line 2215 in
>>> [0]PETSC ERROR: Mat mat,Vec v3: local dim 2286 771
>>> [0]PETSC ERROR: #2 MatMultAdd() line 2396 in
>>> 2) executed with 4 MPI processes (I'm copying the output of process 0
>>> only, they're all the same):
>>> [0]PETSC ERROR: Mat mat,Vec x: global dim 771 3084
>>> alessandro-HP-ProDesk-490-G2-MT by alessandro Wed Apr  6 10:49:13 2016
>>> [0]PETSC ERROR: #1 MatMult() line 2214 in
>>> [0]PETSC ERROR: Mat mat,Vec v1: global dim 771 3084
>>> [0]PETSC ERROR: #2 MatMultAdd() line 2393 in
>>> [0]PETSC ERROR: #3 MatMult() line 2214 in
>>> [0]PETSC ERROR: #4 MatMultAdd() line 2393 in
>>> Any idea? I would like to keep the flexibility of having a sequence of
>>> mat-vec multiplications as in
>>> but for doing that I need to be able to extract x1 and x2, and to
>>> reassemble the partial results into y.
>>> Thanks in advance,
>>> Alessandro
> ___________________________________
> Matteo Alessandro Francavilla, PhD
> Antenna and EMC Lab (LACE)
> Istituto Superiore Mario Boella (ISMB)
> Torino, Italy
> phone +39 011 2276 711
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160406/a99dfd8f/attachment-0001.html>
