[petsc-users] eigensolution error with slepc
Manav Bhatia bhatiamanav at gmail.com
Sun Apr 3 15:17:42 CDT 2016
I just send you the matrices.
Manav
> On Apr 3, 2016, at 3:03 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
>> El 3 abr 2016, a las 21:45, Manav Bhatia <bhatiamanav at gmail.com> escribió:
>> Hi Jose,
>>   I did not specify Arnoldi. I am running on a single CPU, so maybe Arnoldi is the default for 1 cpu runs?
> No. Maybe you set it in code or maybe the option is being picked from PETSC_OPTIONS or petscrc file.
>>   How would you like me to send you the matrices? Is there a specific format you would like?
> Better in PETSc binary format. If calling EPSSolve() only once, the easiest way is running with
> -eps_view_mat0 binary:A.petsc -eps_view_mat1 binary:B.petsc
>> Thanks,
>> Manav
