[petsc-users] eigensolution error with slepc
Jose E. Roman jroman at dsic.upv.es
Sun Apr 3 15:03:29 CDT 2016
> El 3 abr 2016, a las 21:45, Manav Bhatia <bhatiamanav at gmail.com> escribió:
> Hi Jose,
>    I did not specify Arnoldi. I am running on a single CPU, so maybe Arnoldi is the default for 1 cpu runs?
No. Maybe you set it in code or maybe the option is being picked from PETSC_OPTIONS or petscrc file.
>    How would you like me to send you the matrices? Is there a specific format you would like?
Better in PETSc binary format. If calling EPSSolve() only once, the easiest way is running with
-eps_view_mat0 binary:A.petsc -eps_view_mat1 binary:B.petsc
> Thanks,
> Manav
