[petsc-users] PetscDSSetJacobianPreconditioner causing DIVERGED_LINE_SEARCH for multi-field problem
Sander Arens Sander.Arens at UGent.be
Sun Apr 3 10:25:36 CDT 2016
Great! It's added.
Sander
On 3 April 2016 at 16:53, Matthew Knepley <knepley at gmail.com> wrote:
> Go ahead and add it. I will review everything.
>   Thanks,
>     Matt
> On Sun, Apr 3, 2016 at 9:26 AM, Sander Arens <Sander.Arens at ugent.be>
> wrote:
>> No problem. I think I solved the problem with the block size, so I wanted
>> to know if I should also add this to my pull request or if I should make a
>> separate one?
>> Thanks,
>> Sander
>> On 3 April 2016 at 15:17, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Sun, Apr 3, 2016 at 6:55 AM, Sander Arens <Sander.Arens at ugent.be>
>>> wrote:
>>>> Any thoughts on this, Matt?
>>> Shoot, this fell out of my working set, and I am behind on incorporating
>>> your pull request. I will
>>> look at both this week.
>>>   Thanks,
>>>      Matt
>>>> Thanks,
>>>> Sander
>>>> On 21 March 2016 at 09:49, Sander Arens <Sander.Arens at ugent.be> wrote:
>>>>> Matt,
>>>>> I think the problem is in DMCreateSubDM_Section_Private. The block
>>>>> size can be counted there (very similar as in DMCreateMatrix_Plex) and then
>>>>> passed down to the IS. I can create a pull request for this if you'd like
>>>>> (or should I just add this to my other pull request for the Neumann bc's)?
>>>>> On 3 March 2016 at 18:02, Sander Arens <Sander.Arens at ugent.be> wrote:
>>>>>> Ok, thanks for clearing that up!
>>>>>> On 3 March 2016 at 18:00, Matthew Knepley <knepley at gmail.com> wrote:
>>>>>>> On Thu, Mar 3, 2016 at 10:48 AM, Sander Arens <Sander.Arens at ugent.be
>>>>>>> > wrote:
>>>>>>>> So is the block size here refering to the dimension of the
>>>>>>>> near-nullspace or has it something to do with the coarsening?
>>>>>>>> I would have thought to also see the block size in this part:
>>>>>>> Dang, that is a problem. It should have the correct block size when
>>>>>>> FS pulls it out of the overall matrix. This should be
>>>>>>> passed down using the block size of the IS. Something has been
>>>>>>> broken here. I will put it on my list of things to look at.
>>>>>>>   Thanks,
>>>>>>>     Matt
>>>>>>>>                   Mat Object:                           1 MPI
>>>>>>>> processes
>>>>>>>>                   type: seqaij
>>>>>>>>                   rows=1701, cols=1701
>>>>>>>>                   total: nonzeros=109359, allocated nonzeros=109359
>>>>>>>>                   total number of mallocs used during MatSetValues
>>>>>>>> calls =0
>>>>>>>>                   has attached near null space
>>>>>>>>                      using I-node routines: found 567 nodes, limit
>>>>>>>> used is 5
>>>>>>>> Thanks,
>>>>>>>> Sander
>>>>>>>> On 3 March 2016 at 17:29, Matthew Knepley <knepley at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> You can see the block size in the output
>>>>>>>>>                   Mat Object:                   1 MPI processes
>>>>>>>>>                     type: seqaij
>>>>>>>>>                     rows=12, cols=12, bs=6
>>>>>>>>>                     total: nonzeros=144, allocated nonzeros=144
>>>>>>>>> MatSetValues calls =0
>>>>>>>>>                       using I-node routines: found 3 nodes, limit
>>>>>>>>> used is 5
>>>>>>>>>               linear system matrix = precond matrix:
>>>>>>>>>                 type: seqaij
>>>>>>>>> calls =0
>>>>>>>>>                   using I-node routines: found 3 nodes, limit used
>>>>>>>>> is 5
>>>>>>>>>   Thanks,
>>>>>>>>>     Matt
>>>>>>>>> On Thu, Mar 3, 2016 at 10:28 AM, Sander Arens <
>>>>>>>>>> Sure, here it is.
>>>>>>>>>> Thanks,
>>>>>>>>>> Sander
>>>>>>>>>> On 3 March 2016 at 15:33, Matthew Knepley <knepley at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> On Thu, Mar 3, 2016 at 8:05 AM, Sander Arens <
>>>>>>>>>>>> Yes, the matrix is created by one of the assembly functions in
>>>>>>>>>>>> Plex, so that answers my question. I was confused by this because I
>>>>>>>>>>>> couldn't see this information when using -snes_view.
>>>>>>>>>>> Hmm, then something is wrong because the block size should be
>>>>>>>>>>> printed for the matrix at the end of the solver in -snes_view, Can you
>>>>>>>>>>> send that to me?
>>>>>>>>>>>   Thanks,
>>>>>>>>>>>      Matt
>>>>>>>>>>>> Thanks for the helpful replies,
>>>>>>>>>>>> Sander
>>>>>>>>>>>> On 3 March 2016 at 14:52, Matthew Knepley <knepley at gmail.com>
>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> On Thu, Mar 3, 2016 at 7:49 AM, Sander Arens <
>>>>>>>>>>>>>> And how can I do this? Because when I look at all the options
>>>>>>>>>>>>>> with -help I can strangely enough only find
>>>>>>>>>>>>>> -fieldsplit_pressure_mat_block_size and not
>>>>>>>>>>>>>> -fieldsplit_displacement_mat_block_size.
>>>>>>>>>>>>> Maybe I am missing something here. The matrix from which you
>>>>>>>>>>>>> calculate the preconditioner using GAMG must be created somewhere. Why
>>>>>>>>>>>>> is the block size not specified at creation time? If the
>>>>>>>>>>>>> matrix is created by one of the assembly functions in Plex, and the
>>>>>>>>>>>>> PetscSection has
>>>>>>>>>>>>> a number of field components, then the block size will already
>>>>>>>>>>>>> be set.
>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> Sander
>>>>>>>>>>>>>> On 3 March 2016 at 14:21, Matthew Knepley <knepley at gmail.com>
>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>> On Thu, Mar 3, 2016 at 6:20 AM, Sander Arens <
>>>>>>>>>>>>>>>> Ok, I forgot to call SNESSetJacobian(snes, J, P, NULL,
>>>>>>>>>>>>>>>> NULL) with J != P, which caused to write the mass matrix into the
>>>>>>>>>>>>>>>> (otherwise zero) (1,1) block of the Jacobian and which was the reason for
>>>>>>>>>>>>>>>> the linesearch to fail.
>>>>>>>>>>>>>>>> However, after fixing that and trying to solve it with
>>>>>>>>>>>>>>>> FieldSplit with LU factorization for the (0,0) block it failed because
>>>>>>>>>>>>>>>> there were zero pivots for all rows.
>>>>>>>>>>>>>>>> Anyway, I found out that attaching the mass matrix to the
>>>>>>>>>>>>>>>> Lagrange multiplier field also worked.
>>>>>>>>>>>>>>>> Another related question for my elasticity problem: after
>>>>>>>>>>>>>>>> creating the rigid body modes with DMPlexCreateRigidBody and attaching it
>>>>>>>>>>>>>>>> to the displacement field, does the matrix block size of the (0,0) block
>>>>>>>>>>>>>>>> still have to be set for good performance with gamg? If so, how can I do
>>>>>>>>>>>>>>>> this?
>>>>>>>>>>>>>>> Yes, it should be enough to set the block size of the
>>>>>>>>>>>>>>> preconditioner matrix.
>>>>>>>>>>>>>>>   Matt
>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>> Sander
>>>>>>>>>>>>>>>> On 2 March 2016 at 12:25, Matthew Knepley <
>>>>>>>>>>>>>>>>> On Wed, Mar 2, 2016 at 5:13 AM, Sander Arens <
>>>>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>>>>> I'm trying to set a mass matrix preconditioner for the
>>>>>>>>>>>>>>>>>> Schur complement of an incompressible finite elasticity problem. I tried
>>>>>>>>>>>>>>>>>> using the command PetscDSSetJacobianPreconditioner(prob, 1, 1,
>>>>>>>>>>>>>>>>>> g0_pre_mass_pp, NULL, NULL, NULL) (field 1 is the Lagrange multiplier
>>>>>>>>>>>>>>>>>> field).
>>>>>>>>>>>>>>>>>> However, this causes a DIVERGED_LINE_SEARCH due to to Nan
>>>>>>>>>>>>>>>>>> or Inf in the function evaluation after Newton iteration 1. (Btw, I'm using
>>>>>>>>>>>>>>>>>> the next branch).
>>>>>>>>>>>>>>>>>> Is this because I didn't use
>>>>>>>>>>>>>>>>>> PetscDSSetJacobianPreconditioner for the other blocks (which uses the
>>>>>>>>>>>>>>>>>> Jacobian itself for preconditioning)? If so, how can I tell Petsc to use
>>>>>>>>>>>>>>>>>> the Jacobian for those blocks?
>>>>>>>>>>>>>>>>> 1) I put that code in very recently, and do not even have
>>>>>>>>>>>>>>>>> sufficient test, so it may be buggy
>>>>>>>>>>>>>>>>> 2) If you are using FieldSplit, you can control which
>>>>>>>>>>>>>>>>> blocks come from A and which come from the preconditioner P
>>>>>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetDiagUseAmat.html#PCFieldSplitSetDiagUseAmat
>>>>>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetOffDiagUseAmat.html#PCFieldSplitSetOffDiagUseAmat
>>>>>>>>>>>>>>>>>> I guess when using PetscDSSetJacobianPreconditioner the
>>>>>>>>>>>>>>>>>> preconditioner is recomputed at every Newton step, so for a constant mass
>>>>>>>>>>>>>>>>>> matrix this might not be ideal. How can I avoid recomputing this at every
>>>>>>>>>>>>>>>>>> Newton iteration?
>>>>>>>>>>>>>>>>> Maybe we need another flag like
>>>>>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESSetLagPreconditioner.html
>>>>>>>>>>>>>>>>> or we need to expand
>>>>>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESSetLagJacobian.html
>>>>>>>>>>>>>>>>> to separately cover the preconditioner matrix. However,
>>>>>>>>>>>>>>>>> both matrices are computed by one call so this would
>>>>>>>>>>>>>>>>> involve interface changes to user code, which we do not
>>>>>>>>>>>>>>>>> like to do. Right now it seems like a small optimization.
>>>>>>>>>>>>>>>>> I would want to wait and see whether it would really be
>>>>>>>>>>>>>>>>> maningful.
>>>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>>>     Matt
>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>> Sander
>>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160403/d17648a7/attachment-0001.html>
