[petsc-users] PetscDSSetJacobianPreconditioner causing DIVERGED_LINE_SEARCH for multi-field problem
Sun Apr 3 09:53:56 CDT 2016
Go ahead and add it. I will review everything.
    Matt
On Sun, Apr 3, 2016 at 9:26 AM, Sander Arens <Sander.Arens at ugent.be> wrote:
> No problem. I think I solved the problem with the block size, so I wanted
> to know if I should also add this to my pull request or if I should make a
> separate one?
> Thanks,
> Sander
> On 3 April 2016 at 15:17, Matthew Knepley <knepley at gmail.com> wrote:
>> On Sun, Apr 3, 2016 at 6:55 AM, Sander Arens <Sander.Arens at ugent.be>
>> wrote:
>>> Any thoughts on this, Matt?
>> Shoot, this fell out of my working set, and I am behind on incorporating
>> your pull request. I will
>> look at both this week.
>>   Thanks,
>>      Matt
>>> Thanks,
>>> Sander
>>> On 21 March 2016 at 09:49, Sander Arens <Sander.Arens at ugent.be> wrote:
>>>> Matt,
>>>> I think the problem is in DMCreateSubDM_Section_Private. The block size
>>>> can be counted there (very similar as in DMCreateMatrix_Plex) and then
>>>> passed down to the IS. I can create a pull request for this if you'd like
>>>> (or should I just add this to my other pull request for the Neumann bc's)?
>>>> On 3 March 2016 at 18:02, Sander Arens <Sander.Arens at ugent.be> wrote:
>>>>> Ok, thanks for clearing that up!
>>>>> On 3 March 2016 at 18:00, Matthew Knepley <knepley at gmail.com> wrote:
>>>>>> On Thu, Mar 3, 2016 at 10:48 AM, Sander Arens <Sander.Arens at ugent.be>
>>>>>> wrote:
>>>>>>> So is the block size here refering to the dimension of the
>>>>>>> near-nullspace or has it something to do with the coarsening?
>>>>>>> I would have thought to also see the block size in this part:
>>>>>> Dang, that is a problem. It should have the correct block size when
>>>>>> FS pulls it out of the overall matrix. This should be
>>>>>> passed down using the block size of the IS. Something has been broken
>>>>>> here. I will put it on my list of things to look at.
>>>>>>   Thanks,
>>>>>>     Matt
>>>>>>>                   Mat Object:                           1 MPI
>>>>>>> processes
>>>>>>>                   type: seqaij
>>>>>>>                   rows=1701, cols=1701
>>>>>>>                   total: nonzeros=109359, allocated nonzeros=109359
>>>>>>>                   total number of mallocs used during MatSetValues
>>>>>>> calls =0
>>>>>>>                   has attached near null space
>>>>>>>                      using I-node routines: found 567 nodes, limit
>>>>>>> used is 5
>>>>>>> Thanks,
>>>>>>> Sander
>>>>>>> On 3 March 2016 at 17:29, Matthew Knepley <knepley at gmail.com> wrote:
>>>>>>>> You can see the block size in the output
>>>>>>>>                   Mat Object:                   1 MPI processes
>>>>>>>>                     type: seqaij
>>>>>>>>                     rows=12, cols=12, bs=6
>>>>>>>>                     total: nonzeros=144, allocated nonzeros=144
>>>>>>>> MatSetValues calls =0
>>>>>>>>                       using I-node routines: found 3 nodes, limit
>>>>>>>> used is 5
>>>>>>>>               linear system matrix = precond matrix:
>>>>>>>>                 type: seqaij
>>>>>>>> calls =0
>>>>>>>>                   using I-node routines: found 3 nodes, limit used
>>>>>>>> is 5
>>>>>>>>   Thanks,
>>>>>>>>     Matt
>>>>>>>> On Thu, Mar 3, 2016 at 10:28 AM, Sander Arens <
>>>>>>>>> Sure, here it is.
>>>>>>>>> Thanks,
>>>>>>>>> Sander
>>>>>>>>> On 3 March 2016 at 15:33, Matthew Knepley <knepley at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> On Thu, Mar 3, 2016 at 8:05 AM, Sander Arens <
>>>>>>>>>>> Yes, the matrix is created by one of the assembly functions in
>>>>>>>>>>> Plex, so that answers my question. I was confused by this because I
>>>>>>>>>>> couldn't see this information when using -snes_view.
>>>>>>>>>> Hmm, then something is wrong because the block size should be
>>>>>>>>>> printed for the matrix at the end of the solver in -snes_view, Can you
>>>>>>>>>> send that to me?
>>>>>>>>>>   Thanks,
>>>>>>>>>>      Matt
>>>>>>>>>>> Thanks for the helpful replies,
>>>>>>>>>>> Sander
>>>>>>>>>>> On 3 March 2016 at 14:52, Matthew Knepley <knepley at gmail.com>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> On Thu, Mar 3, 2016 at 7:49 AM, Sander Arens <
>>>>>>>>>>>>> And how can I do this? Because when I look at all the options
>>>>>>>>>>>>> with -help I can strangely enough only find
>>>>>>>>>>>>> -fieldsplit_pressure_mat_block_size and not
>>>>>>>>>>>>> -fieldsplit_displacement_mat_block_size.
>>>>>>>>>>>> Maybe I am missing something here. The matrix from which you
>>>>>>>>>>>> calculate the preconditioner using GAMG must be created somewhere. Why
>>>>>>>>>>>> is the block size not specified at creation time? If the matrix
>>>>>>>>>>>> is created by one of the assembly functions in Plex, and the PetscSection
>>>>>>>>>>>> has
>>>>>>>>>>>> a number of field components, then the block size will already
>>>>>>>>>>>> be set.
>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>      Matt
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Sander
>>>>>>>>>>>>> On 3 March 2016 at 14:21, Matthew Knepley <knepley at gmail.com>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> On Thu, Mar 3, 2016 at 6:20 AM, Sander Arens <
>>>>>>>>>>>>>>> Ok, I forgot to call SNESSetJacobian(snes, J, P, NULL, NULL)
>>>>>>>>>>>>>>> with J != P, which caused to write the mass matrix into the (otherwise
>>>>>>>>>>>>>>> zero) (1,1) block of the Jacobian and which was the reason for the
>>>>>>>>>>>>>>> linesearch to fail.
>>>>>>>>>>>>>>> However, after fixing that and trying to solve it with
>>>>>>>>>>>>>>> FieldSplit with LU factorization for the (0,0) block it failed because
>>>>>>>>>>>>>>> there were zero pivots for all rows.
>>>>>>>>>>>>>>> Anyway, I found out that attaching the mass matrix to the
>>>>>>>>>>>>>>> Lagrange multiplier field also worked.
>>>>>>>>>>>>>>> Another related question for my elasticity problem: after
>>>>>>>>>>>>>>> creating the rigid body modes with DMPlexCreateRigidBody and attaching it
>>>>>>>>>>>>>>> to the displacement field, does the matrix block size of the (0,0) block
>>>>>>>>>>>>>>> still have to be set for good performance with gamg? If so, how can I do
>>>>>>>>>>>>>>> this?
>>>>>>>>>>>>>> Yes, it should be enough to set the block size of the
>>>>>>>>>>>>>> preconditioner matrix.
>>>>>>>>>>>>>>   Matt
>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>> Sander
>>>>>>>>>>>>>>> On 2 March 2016 at 12:25, Matthew Knepley <knepley at gmail.com
>>>>>>>>>>>>>>> > wrote:
>>>>>>>>>>>>>>>> On Wed, Mar 2, 2016 at 5:13 AM, Sander Arens <
>>>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>>>> I'm trying to set a mass matrix preconditioner for the
>>>>>>>>>>>>>>>>> Schur complement of an incompressible finite elasticity problem. I tried
>>>>>>>>>>>>>>>>> using the command PetscDSSetJacobianPreconditioner(prob, 1, 1,
>>>>>>>>>>>>>>>>> g0_pre_mass_pp, NULL, NULL, NULL) (field 1 is the Lagrange multiplier
>>>>>>>>>>>>>>>>> field).
>>>>>>>>>>>>>>>>> However, this causes a DIVERGED_LINE_SEARCH due to to Nan
>>>>>>>>>>>>>>>>> or Inf in the function evaluation after Newton iteration 1. (Btw, I'm using
>>>>>>>>>>>>>>>>> the next branch).
>>>>>>>>>>>>>>>>> Is this because I didn't use
>>>>>>>>>>>>>>>>> PetscDSSetJacobianPreconditioner for the other blocks (which uses the
>>>>>>>>>>>>>>>>> Jacobian itself for preconditioning)? If so, how can I tell Petsc to use
>>>>>>>>>>>>>>>>> the Jacobian for those blocks?
>>>>>>>>>>>>>>>> 1) I put that code in very recently, and do not even have
>>>>>>>>>>>>>>>> sufficient test, so it may be buggy
>>>>>>>>>>>>>>>> 2) If you are using FieldSplit, you can control which
>>>>>>>>>>>>>>>> blocks come from A and which come from the preconditioner P
>>>>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetDiagUseAmat.html#PCFieldSplitSetDiagUseAmat
>>>>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetOffDiagUseAmat.html#PCFieldSplitSetOffDiagUseAmat
>>>>>>>>>>>>>>>>> I guess when using PetscDSSetJacobianPreconditioner the
>>>>>>>>>>>>>>>>> preconditioner is recomputed at every Newton step, so for a constant mass
>>>>>>>>>>>>>>>>> matrix this might not be ideal. How can I avoid recomputing this at every
>>>>>>>>>>>>>>>>> Newton iteration?
>>>>>>>>>>>>>>>> Maybe we need another flag like
>>>>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESSetLagPreconditioner.html
>>>>>>>>>>>>>>>> or we need to expand
>>>>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESSetLagJacobian.html
>>>>>>>>>>>>>>>> to separately cover the preconditioner matrix. However,
>>>>>>>>>>>>>>>> both matrices are computed by one call so this would
>>>>>>>>>>>>>>>> involve interface changes to user code, which we do not
>>>>>>>>>>>>>>>> like to do. Right now it seems like a small optimization.
>>>>>>>>>>>>>>>> I would want to wait and see whether it would really be
>>>>>>>>>>>>>>>> maningful.
>>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>>     Matt
>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>> Sander
>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160403/fde525b5/attachment.html>
