[petsc-users] Changes on direct solver interface???
Xujun Zhao xzhao99 at gmail.com
Fri Apr 1 17:30:18 CDT 2016
No dbg version complied now, but will do now.
A first look with -info shows something is wrong when SetUpPC for
superLU_dist:
[1] PetscCommDuplicate(): Using internal PETSc communicator 1140850688
-2080374782
[2] PetscCommDuplicate(): Using internal PETSc communicator 1140850688
-2080374782
[0] PetscCommDuplicate(): Using internal PETSc communicator 1140850688
-2080374780
[3] PetscCommDuplicate(): Using internal PETSc communicator 1140850688
-2080374782
[0] MatStashScatterBegin_Private(): No of messages: 0
[0] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
[1] MatStashScatterBegin_Private(): No of messages: 1
[1] MatStashScatterBegin_Private(): Mesg_to: 0: size: 28160 bytes
[1] MatAssemblyBegin_MPIAIJ(): Stash has 1760 entries, uses 0 mallocs.
[3] MatStashScatterBegin_Private(): No of messages: 2
[3] MatStashScatterBegin_Private(): Mesg_to: 0: size: 22528 bytes
[2] MatStashScatterBegin_Private(): No of messages: 2
[2] MatStashScatterBegin_Private(): Mesg_to: 0: size: 1056 bytes
[3] MatStashScatterBegin_Private(): Mesg_to: 2: size: 18656 bytes
[3] MatAssemblyBegin_MPIAIJ(): Stash has 2574 entries, uses 0 mallocs.
[2] MatStashScatterBegin_Private(): Mesg_to: 1: size: 36960 bytes
[2] MatAssemblyBegin_MPIAIJ(): Stash has 2376 entries, uses 0 mallocs.
[3] MatAssemblyEnd_SeqAIJ(): Matrix size: 504 X 504; storage space: 0
unneeded,17634 used
[3] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[3] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 59
[3] MatCheckCompressedRow(): Found the ratio (num_zerorows
0)/(num_localrows 504) < 0.6. Do not use CompressedRow routines.
[3] MatSeqAIJCheckInode(): Found 278 nodes of 504. Limit used: 5. Using
Inode routines
[2] MatAssemblyEnd_SeqAIJ(): Matrix size: 495 X 495; storage space: 355
unneeded,17115 used
[2] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[2] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 59
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 605 X 605; storage space: 1017
unneeded,22159 used
[0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 59
[2] MatCheckCompressedRow(): Found the ratio (num_zerorows
0)/(num_localrows 495) < 0.6. Do not use CompressedRow routines.
[0] MatCheckCompressedRow(): Found the ratio (num_zerorows
0)/(num_localrows 605) < 0.6. Do not use CompressedRow routines.
[3] PetscCommDuplicate(): Using internal PETSc communicator 1140850689
-2080374780
[1] MatAssemblyEnd_SeqAIJ(): Matrix size: 574 X 574; storage space: 795
unneeded,20096 used
[1] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[1] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 59
[1] MatCheckCompressedRow(): Found the ratio (num_zerorows
0)/(num_localrows 574) < 0.6. Do not use CompressedRow routines.
[2] MatSeqAIJCheckInode(): Found 261 nodes of 495. Limit used: 5. Using
Inode routines
[0] MatSeqAIJCheckInode(): Found 327 nodes of 605. Limit used: 5. Using
Inode routines
[1] MatSeqAIJCheckInode(): Found 298 nodes of 574. Limit used: 5. Using
Inode routines
[2] PetscCommDuplicate(): Using internal PETSc communicator 1140850689
-2080374780
[0] PetscCommDuplicate(): Using internal PETSc communicator 1140850689
-2080374777
[1] PetscCommDuplicate(): Using internal PETSc communicator 1140850689
-2080374780
-2080374780
-2080374780
-2080374780
-2080374777
[0] VecScatterCreateCommon_PtoS(): Using blocksize 1 scatter
[0] VecScatterCreate(): General case: MPI to Seq
[2] MatAssemblyEnd_SeqAIJ(): Matrix size: 495 X 146; storage space: 15
unneeded,1754 used
[2] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 40
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 605 X 181; storage space: 30
unneeded,1703 used
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 37
512)/(num_localrows 605) > 0.6. Use CompressedRow routines.
[1] MatAssemblyEnd_SeqAIJ(): Matrix size: 574 X 140; storage space: 15
unneeded,1945 used
[1] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 31
409)/(num_localrows 574) > 0.6. Use CompressedRow routines.
378)/(num_localrows 495) > 0.6. Use CompressedRow routines.
[3] MatAssemblyEnd_SeqAIJ(): Matrix size: 504 X 78; storage space: 0
unneeded,1378 used
[3] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 23
378)/(num_localrows 504) > 0.6. Use CompressedRow routines.
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 605 X 605; storage space: 0
unneeded,22159 used
[1] MatStashScatterBegin_Private(): No of messages: 0
[1] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 605 X 181; storage space: 0
unneeded,1703 used
[1] MatAssemblyEnd_SeqAIJ(): Matrix size: 574 X 574; storage space: 0
unneeded,20096 used
[2] MatStashScatterBegin_Private(): No of messages: 0
[2] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
[2] MatAssemblyEnd_SeqAIJ(): Matrix size: 495 X 495; storage space: 0
unneeded,17115 used
[3] MatStashScatterBegin_Private(): No of messages: 0
[3] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
unneeded,17634 used
[1] MatAssemblyEnd_SeqAIJ(): Matrix size: 574 X 140; storage space: 0
unneeded,1945 used
[2] MatAssemblyEnd_SeqAIJ(): Matrix size: 495 X 146; storage space: 0
unneeded,1754 used
unneeded,1378 used
[0] VecAssemblyBegin_MPI(): Stash has 0 entries, uses 0 mallocs.
[0] VecAssemblyBegin_MPI(): Block-Stash has 0 entries, uses 0 mallocs.
[0] PCSetUp(): Setting up PC for first time
-2080374777
-2080374777
-2080374780
-2080374780
-2080374780
-2080374780
-2080374780
-2080374780
-2080374777
-2080374777
-2080374780
-2080374780
-2080374780
-2080374780
-2080374780
-2080374780
-2080374780
-2080374780
-2080374777
-2080374780
-2080374780
-2080374780
-2080374780
-2080374777
[1]PETSC ERROR:
[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[1]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
to find memory corruption errors
[1]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
run
[1]PETSC ERROR: to get more information on the crash.
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Signal received
[1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.6.3, unknown
[1]PETSC ERROR: ./example-opt on a arch-darwin-c-opt named
mcswl105.mcs.anl.gov by xzhao Fri Apr  1 17:26:55 2016
[1]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
--with-fc=gfortran --with-cxx-dialect=C++11 --download-mpich
--download-fblaslapack --download-scalapack --download-mumps
--download-superlu_dist --download-hypre --download-ml --download-metis
--download-parmetis --download-triangle --download-chaco
--download-elemental --with-debugging=0
[1]PETSC ERROR: #1 User provided function() line 0 in  unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 1
[cli_1]: aborting job:
[3]PETSC ERROR:
[3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
[3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[3]PETSC ERROR: or see
[3]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
[3]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
run
[3]PETSC ERROR: to get more information on the crash.
[3]PETSC ERROR: --------------------- Error Message
[3]PETSC ERROR: Signal received
[3]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[3]PETSC ERROR: Petsc Release Version 3.6.3, unknown
[3]PETSC ERROR: ./example-opt on a arch-darwin-c-opt named
[3]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
[3]PETSC ERROR: #1 User provided function() line 0 in  unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 3
[cli_3]: aborting job:
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
[0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
run
[0]PETSC ERROR: to get more information on the crash.
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.6.3, unknown
[0]PETSC ERROR: ./example-opt on a arch-darwin-c-opt named
[0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
[0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
[cli_0]: aborting job:
[2]PETSC ERROR:
[2]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
[2]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[2]PETSC ERROR: or see
[2]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
[2]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
run
[2]PETSC ERROR: to get more information on the crash.
[2]PETSC ERROR: --------------------- Error Message
[2]PETSC ERROR: Signal received
[2]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[2]PETSC ERROR: Petsc Release Version 3.6.3, unknown
[2]PETSC ERROR: ./example-opt on a arch-darwin-c-opt named
[2]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
[2]PETSC ERROR: #1 User provided function() line 0 in  unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 2
[cli_2]: aborting job:
On Fri, Apr 1, 2016 at 5:13 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> please run the code in debugger and obtain a stack trace.
> Satish
> On Fri, 1 Apr 2016, Xujun Zhao wrote:
> > Hi all,
> > Are there any changes on the PETSc direct solver interface, for example,
> > with superLU_dist and MUMPS. I found that my libMesh code failed with
> both
> > of them, but still works with iterative solver (GMRES by default).
> Thanks a
> > lot.
> > Best,
> > Xujun
> > [0]PETSC ERROR:
> OS X
> and
> > run
> for
> > trouble shooting.
> > mcswl105.mcs.anl.gov by xzhao Fri Apr  1 15:57:40 2016
> > [1]PETSC ERROR:
> OS X
> and
> > run
> for
> > trouble shooting.
> > | Processor id:   0
> > | Num Processors: 4
> > | Time:           Fri Apr  1 15:57:40 2016
> > | OS:             Darwin
> > | HostName:       mcswl105.mcs.anl.gov
> > | OS Release:     15.2.0
> > | OS Version:     Darwin Kernel Version 15.2.0: Fri Nov 13 19:56:56 PST
> > 2015; root:xnu-3248.20.55~2/RELEASE_X86_64  |
> > | Machine:        x86_64
> > | Username:       xzhao
> > | Configuration:  ./configure
> > '--prefix=/Users/xzhao/software/libmesh/libmesh-dev'
> > |  '--with-methods=opt'
> > |  '--enable-everything'
> > |  '--enable-parmesh'
> > |  '--disable-strict-lgpl'
> > |  '--with-vtk-include=/usr/local/include/vtk-6.2'
> > |  '--with-vtk-lib=/usr/local/lib'
> > |  'PETSC_DIR=/Users/xzhao/software/petsc/petsc-dev'
> > |  'PETSC_ARCH=arch-darwin-c-opt'
> > |  'SLEPC_DIR=/Users/xzhao/software/slepc/slepc-3.6'
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160401/3810e778/attachment-0001.html>
