[petsc-users] Scaling with number of cores
Sat Oct 31 11:47:51 CDT 2015
On Sat, Oct 31, 2015 at 11:34 AM, TAY wee-beng <zonexo at gmail.com> wrote:
> Hi,
> I understand that as mentioned in the faq, due to the limitations in
> memory, the scaling is not linear. So, I am trying to write a proposal to
> use a supercomputer.
> Its specs are:
> Compute nodes: 82,944 nodes (SPARC64 VIIIfx; 16GB of memory per node)
> 8 cores / processor
> Interconnect: Tofu (6-dimensional mesh/torus) Interconnect
> Each cabinet contains 96 computing nodes,
> One of the requirement is to give the performance of my current code with
> my current set of data, and there is a formula to calculate the estimated
> parallel efficiency when using the new large set of data
> There are 2 ways to give performance:
> 1. Strong scaling, which is defined as how the elapsed time varies with
> the number of processors for a fixed
> problem.
> 2. Weak scaling, which is defined as how the elapsed time varies with the
> fixed problem size per processor.
> I ran my cases with 48 and 96 cores with my current cluster, giving 140
> and 90 mins respectively. This is classified as strong scaling.
> Cluster specs:
> CPU: AMD 6234 2.4GHz
> 8 cores / processor (CPU)
> 6 CPU / node
> So 48 Cores / CPU
> Not sure abt the memory / node
> The parallel efficiency ‘En’ for a given degree of parallelism ‘n’
> indicates how much the program is
> efficiently accelerated by parallel processing. ‘En’ is given by the
> following formulae. Although their
> derivation processes are different depending on strong and weak scaling,
> derived formulae are the
> same.
> From the estimated time, my parallel efficiency using  Amdahl's law on the
> current old cluster was 52.7%.
> So is my results acceptable?
> For the large data set, if using 2205 nodes (2205X8cores), my expected
> parallel efficiency is only 0.5%. The proposal recommends value of > 50%.
> The problem with this analysis is that the estimated serial fraction from
Amdahl's Law  changes as a function
of problem size, so you cannot take the strong scaling from one problem and
apply it to another without a
model of this dependence.
Weak scaling does model changes with problem size, so I would measure weak
scaling on your current
cluster, and extrapolate to the big machine. I realize that this does not
make sense for many scientific
applications, but neither does requiring a certain parallel efficiency.
     Matt
> Is it possible for this type of scaling in PETSc (>50%), when using 17640
> (2205X8) cores?
> Btw, I do not have access to the system.
> Sent using CloudMagic Email
> <https://cloudmagic.com/k/d/mailapp?ct=pa&cv=7.4.10&pv=5.0.2&source=email_footer_2>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151031/e1778def/attachment.html>
